PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. ABS problem with rear swap, HELLP!!!
  2. Finished Hooker LT Headers Install
  3. fuel pressure gauge
  4. Difference between carriers?
  5. Hockey Stripes
  6. fan switch mod
  7. 28.8 injectors
  8. How to launch?
  9. What to do to get in the 12's
  10. Newbie looking for a new car
  11. true duel exhaust
  12. Question about few mods, help please
  13. K&N FIPK on the LS1
  14. quarts of oil in an ls1??
  15. Let's talk driveshafts
  16. Does a 2002 M6 have stronger shift forks than older models have?
  17. Super Sucker Ram Air lower scoop for FTRA
  18. SPEC clutch identification
  19. Plug Wires
  20. supercharger vs single turbo kit
  21. Need help with headers quick
  22. How Can I Tell if I am buying a true SS or a car someone has aftermarketed?
  23. Wash the LS1 motor?
  24. codes
  25. Any new info on Comp's intake?
  26. Subframe Connector
  27. Superchips installation help
  28. F-body Potential
  29. What Next? Airflow?
  30. Question/People w/hooker LT & Magnaflow
  31. Those of you with cams - are you happy w/ the performance gain ?
  32. major car problem...bucks, dies, all the bad stuff
  33. Is ram-air really functional?
  34. Best deal on a killa I've seen.
  35. Firebird Formula VS Z28 SS (2002's)
  36. Can You Buy Just A ZL1 Motor Through GM?
  37. Problems with short stick shifters
  38. Worrisome info on our cars...
  39. Where do I jack up the front of my LS1?
  40. My reverse lights dont work!
  41. LT1 vs. LS1's T56
  42. converter install.. IS it hard?
  43. Will Stock Rearend Hold Up On 540rwhp!!!!
  44. What are the differences between the 98-02 Trans Ams?
  45. money too spend...
  46. Headers n 02's
  47. Stripper car weight
  48. 4L60E acting wierd
  49. Car seems slow w/MAC's and ORY???
  50. Found a 01 SS A4, is this a good deal?
  51. Installed Edelbrock Torque Arm
  52. LS1 Jeep Wrangler
  53. Do Convertables Leak a lot?
  54. Best Brake Pads???
  55. 98 Z28 dies on highway........
  56. Rear pinion seal install
  57. Spin tech?? or??
  58. Anyone using this cam
  59. 439.7 Hp /399.0 Tq
  60. Dyno results within...(cam/headers installed)
  61. How to remove EGR?
  62. Stereo problem 98 T/A NEED HELP FAST
  63. Different LS1's
  64. Looking for a parts list
  65. considering buying '98 Z, insider info?-->
  66. Do I need to connect the A.I.R. system to my LTs?
  67. bay area, CA guys in here
  68. Header questions
  69. Just bought 01 ss...have ?'s
  70. What mod should i do next
  71. Need help - Power steering died
  72. question re: bmr tubular SFC's
  73. Anomaly Guaranteed to Stump All
  74. How do i remove this fork?
  75. widest 17"
  76. $1,000 budget/ What should I do?
  77. my EBC pads wore out after only 13K? any others?
  78. longtubes or shorties
  79. Broken Mirror
  80. 2000-2002 Air Lid Question
  81. Dyno Results In
  82. TSP LID Gains
  83. Longtubes vs N20
  84. Auto in an SS?
  85. TB bypass
  86. can someone plz run a carfax report for me
  87. Need your help guys, whats wrong with my car
  88. Header questions?
  89. Transmission Drain Plug
  90. Help, car idles different!
  91. Question about Heads and Cam
  92. Winter Storage Questions
  93. Need rear help
  94. leaking from AC???
  95. Where to get wiring harness and computer
  96. which water pump??
  97. How would this sound?
  98. Who uses drag radials as their street tire
  99. Off road pipe ?
  100. What is the stock power Rating
  101. You ever read this?
  102. tb bypass connector size
  103. Anyone's car chatter when it's turned off?
  104. Look Inside if u own an LS1.
  105. Are There Any Legal Exhaust Systems As Quiet At The Stock Ss
  106. I definitely need a new clutch now.
  107. Won't start! Any ideas?
  108. Just did pushrod swap...BAD RESULTS...verrry bad
  109. Electrical problem. Any help
  110. Old rims on 02s? any info?
  111. drag Radial VS Street Tires
  112. Need help cleaning leather!!!!
  113. Pacesetter owners..login
  114. any one know how to install power windows??????
  115. Tie Rod end.
  116. no tail lights
  117. ripper or pro 5.0??
  118. Welcome all who are from LS1.Com!
  119. HELP I need to install headers by Friday
  120. Smething to check on your cars !
  121. goodyear f1 gs-d3 tires any comments?
  122. ready to purchase either the FIPK or the TSP air box
  123. 3.42s or 3.73s for automatic?
  124. RPM's when shifting
  125. radio wires
  126. finished my true dual exhaust, and it sounds AWESOME
  127. oil leak drive shaft
  128. Custom Y-Pipe and Cats installed, pics..., also need help!
  129. Urgent: Driving SS in Winter
  130. ls6 cam vs. Z06 cam which makes more?
  131. What does your blockoff plate look like for your SSRA
  132. smoke
  133. 2 questions about Lower Control Arms
  134. Car whining after reving it up
  135. Y-pipe or not?
  136. Question about SSRA
  137. Is there a switch to turn off traction control?
  138. 98' to 00' What Are Most Common Problems?
  139. Header Shootout!!! We need one.
  140. Question for the cutout people
  141. Anyone know how to turn the daytime running lights off?
  142. Headers = Too loud ?
  143. Sensor connector needs a home, HELP
  144. Weird!!! Had car dynoed yesterday and when I use the A/C the tach revs
  145. Car is too loud, will replacing the cats help
  146. hypertech question
  147. Stay with 3.42s or get 3.73s.......
  148. Arguein w/ a friend: what kinds rods/bottom end are on the LS1?
  149. oil filter change intervals
  150. QTEC headers & Dyno sheets
  151. is one year LS1 better than another?
  152. 02 Brickyard 400 35th SS?
  153. 6 sec ls1
  154. Cool Plate for you 35th ANNIV guys
  155. ceramic headers or not?
  156. Will 2 2.25" pipes flow better than a single 3"?
  157. GMHTP pg. 66, bad dyno?
  158. CAM or Headers first?
  159. i want headers
  160. rear end gears
  161. more of the same
  162. Need help fast! Interior question
  163. Falken tires
  164. ac on = loss of horse power?
  165. rotors ceramix pads
  166. loudmouth
  167. I Have A Question?
  168. Gauge Install
  169. CAGS trick to disable the dreaded 3-2 shift
  170. Posi Rear end question
  171. Question
  172. security light stuck on
  173. SpinTech mufflers
  174. Radiator fan/shroud?
  175. FOR SALE: '01 Z-28 LS1 A4 Coupe
  176. Lowering needs
  177. What's a good price for an '02?
  178. grilles
  179. lt1 guy with a question
  180. transmission
  181. Cutout or Exhaust system ?
  182. Air tubes off manifolds/headers, do I need them?
  183. Midwest TC 3000 Stall Track results
  184. S & W Racing SFCs
  185. What do you think of this combo?
  186. Are Thunder Racing brakes good for the money?
  187. 3 inch Y + Borla + Stock Manifolds?!
  188. Ring & Pinion Out
  189. 2001 a4 ws6
  190. squeak from front passanger side?
  191. SES light after Shaner S2 install....
  192. Flashing SES light, NEED HELP
  193. Help. Left bank O2 sensor keeps failing
  194. Loud ticking
  195. need advice about selling my car
  196. found very cheap 98 Z28. need to know about it....
  197. LS1 Edit vs. Autotap V5
  198. Need Help with driver side window!
  199. Should I trade the LT1 for the LS1?
  200. I think I found the perfect car....
  201. Cutouts
  202. To those with leaky windows...
  203. What lid is this???
  204. Strut Tower Brace question
  205. DMH electric cutout, LS1, ok to install?
  206. Help Need Feedback
  207. Is this true
  208. how often to check valve clearance?
  209. springs from an lt1 work with an ls1
  210. What makes an SS an SS?
  211. Is a lid really worth it?
  212. Free/ cheap mods?
  213. rough idle?
  214. Just Replaced My Pushrods, but now its ticking
  215. Bolt on SFC hardware
  216. Anyone Dynamatted their car?
  217. Running Temp question
  218. gains by swapping only mufflers?
  219. Air Bag light after accident
  220. Ss Convterbiles
  221. weird orange fluid leak
  222. Hooker Headers/y-pipe finally got here.
  223. Help My car is still acting stupid
  224. Do you have weatherstripping all the way around your rear glass?
  225. Aftermarket Lid or Stock 01 WS6 Induction
  226. Stock MAF
  227. Possible to find a 98 SS that does NOT have T-Tops?
  228. Mike Haufpauer?
  229. to all LS1 owners
  230. How to tell if LSD is gone
  231. Exciter wire from alternator HELP
  232. Rocker adjustment
  233. H E A D E R S ?
  234. Borla Adjustable Exhaust
  235. Has anyone sold or bought a z28 lately?
  236. Will Ws6 Highrise Airbox(PN#12455209) fit under SS Hood?
  237. a/c problem
  238. pacesetter headers any good?
  239. Alignment Question
  240. ls1 mods
  241. converter
  242. What are some good - Basic Mods for the LS1
  243. ACD Line Lock install kit?
  244. Where else can I find this Bad A**...
  245. Please answer some questions from over the pond
  246. keyyy scratches
  247. Ls1 is in block cam?
  248. I threw this code p1404....
  249. What do heads flow?
  250. Camshaft Install Questions
