PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Knock Sensor
  2. cutout??
  3. Pro 5.0 NOISE
  4. Wow! Looky at what broke! (PIC)
  5. The Basics on a camshaft
  6. best lid?
  7. Mandrel exhaust pipe
  8. How bad is it to bounce off the rev limiter in an A4?
  9. speed limiter
  10. Rebuild bottom end for under 2K???
  11. Valve spring ?
  12. How much horsepower?
  13. lt1 catback to ls1
  14. 15 inch rims
  15. Maybe looking for a LS1
  16. What Is My Car Worth
  17. hypertech back to stock
  18. hurst shifter
  19. start up
  20. ses light, po122, po172 and po175
  21. LS1 axle swap
  22. What mileage to change spark plugs?
  23. Noise at shifting
  24. Shift stick boot
  25. QTP Headers... Worth the money?
  26. Gas pedal resistance during launch?
  27. How much....?
  28. window
  29. longtubes and still pass emissions
  30. Earls stainless steel brake line install question
  31. Need a little quick LS1 info to settle an argument
  32. I think I bent a valve/s
  33. WTF, o2 SENSOR NOISE "TYPICAL ENGINE NOISE" U GOTTA BE KIDDING ME!
  34. high hp 4l60e
  35. auto or M6 for a built engine??
  36. differant fuels....ffv
  37. BG Ram Air and SSRA?
  38. Lid problems?
  39. Stock vs Aftermarket R-A
  40. Pecesetter LT Dyno Results!!
  41. Free Mods?
  42. Gains from Holley Intake & BBK Throttle Body
  43. Nittos or BFG DR
  44. wont start,after wash.This happen to you?
  45. pulling to the left
  46. hyper ground kit?
  47. Code P1415, Need a little Help
  48. LT1 man with a LS1 question (Teflon Piston #1 Cylnder)???
  49. Hypertech Programmer For Tire Size
  50. gas pedal gets stuck during hard driving.
  51. Which cold air induction?
  52. Will a ported TB lean out my a/f mixture?
  53. Clutch swap
  54. what kind of times would this get?
  55. launching with an M6
  56. po300 misfire multiple cylanders :(
  57. Patriot Heads/TSP Cam Dyno Results!
  58. Help with Qtec cutout
  59. Need to change rotors and...
  60. Does Anybody Have A 10% Discount Code For Summit...
  61. who has kumho tires? are they good tires?
  62. Does your left front tire wear it's outside edge faster than the right ?
  63. 97-99 Tranny Swap
  64. Help me please! I can't get the hood to shut!
  65. going to dyno test an FIPK tomorrow
  66. Engine Torque Specs
  67. Help! Installing a new hood!
  68. engine
  69. squealing brakes
  70. How do I reset SES after changing MAF
  71. when racing whats the best way to launch an automatic LS1
  72. water, but where
  73. Bent push rod.
  74. Uh oh... another "Noise"...
  75. These never work on LT1s...LS1s??
  76. bassani off road pipe
  77. Torque Converter and SFC's installed FINALLY!
  78. Newbie Exhaust questions
  79. mass air sensor
  80. Help! Dealer trying to railroad me?
  81. Siemens Deka Injector ?
  82. Iridium sparkplugs
  83. boxed or tubular lca
  84. ? Y Pipe ?
  85. Headers on Ebay ???s
  86. People who've put motors in their LS1 cars... I have a ?
  87. 87 octane in hot weather
  88. Tune up/ Spark Plugs
  89. The absolute cheapest... long tube headers... what are they??
  90. Transmission rebuild
  91. Injector sizes?
  92. How fast is a full bolt on ls1
  93. Cost to get some programming done?
  94. Got my BMR springs installed...
  95. All Texas Speed & Performance lid owners inside
  96. anyone whats the best quiet tire to use for the camaro ss rim
  97. How common is it for an O2 sim to go bad?
  98. Power steering pump failure???
  99. lq4 iron block
  100. intake manifold
  101. Someone help
  102. traction control system? 98 TA
  103. I got her!
  104. Ignition???
  105. Should I wait
  106. Ever heard of a fake ZR1 wheel ?
  107. oil question
  108. mods for a 5.3 LS1
  109. A4 shift knob
  110. Question about 18" tire size??
  111. Why is my gas mileage so sh!tty?
  112. transmision
  113. How big of a cam can I go with stock heads?
  114. ignition troubles
  115. Power steering leak
  116. 20w50 oil in my ls1?
  117. 431.7rwhp/391 Tq
  118. Corsa Exhaust
  119. Headers?
  120. P0410
  121. QUICK!!! 01 LSI: Good Price?
  122. How long does it take to change plugs and wires on a 99?
  123. got grind??
  124. LT1 to LS1 conversion
  125. Can u modify stock airlid?
  126. gear change?
  127. engine weight question
  128. door sensor for dome light and radio??
  129. pirelli tires and 99 ss rims
  130. Good ol' P0420 DTC
  131. Pace setter LT
  132. Just rolled my fender lips.
  133. Stock Y diameter
  134. crunching from rear going over bumps
  135. 60K miles on my 98Z28 and metal shavings!!!!
  136. Well, I was wrong
  137. Times with Stock & Pace vv MAF
  138. Looking for some help.
  139. datastreams
  140. engine acting up
  141. Anyone Have Don Goetz's SFC's?
  142. FRA and Ram Air Systems
  143. True Duals, what is involved?
  144. cutout or not?
  145. scanning software for ls1??
  146. Installing ASP Pulley Q??
  147. ? About LT's
  148. wiring cutout
  149. Headers and Y Pipes
  150. Oil Pan Plug
  151. What are these wires and what do they do?
  152. wtf is wrong my my LCA's
  153. who has a built engine?
  154. Gas gage
  155. Weird Noise from Car need help
  156. kumhos?
  157. b and m shifter problems, i think
  158. Wings West Body Kit Problems?
  159. I am going to need a detailed list of needed parts for clutch changeout.
  160. Shorty headers with LM?
  161. How much drive train loss?
  162. lt header's and 02 sims?
  163. Rearend not center
  164. Running Lean...HP gains from LS1 edit??
  165. LOL It was only a matter of time
  166. Ls1 holly/ls6 intake manifold?
  167. 99 Ta Wont Start...help!!!!
  168. Had this happen before?
  169. Stage 2 heads
  170. console question
  171. SS exhaust
  172. Eagle F1's on SS
  173. header y-pipe questions
  174. New Forum
  175. New guy
  176. How much did everyone pay for Converter install?
  177. How is this for starters?
  178. www.eriespeed.com
  179. hypertech shifting question inside
  180. Newb here with a Hugger SS..need opinions
  181. Oil Consumption Article
  182. QA1 + Eibach Prokit
  183. tornado fuel saver
  184. Need help troubleshooting charging system
  185. Installed my Moser 12 bolt
  186. ignition mods
  187. PCM Tuning
  188. LS1 as a Daily Driver?
  189. EGR mod is it worth doing? yes or no
  190. gear carrier
  191. <---LS1 noob
  192. What is the most cost effective way to gain upper end HP ?
  193. Please help me chose between these two cam setups
  194. where to get aftermarket belt tensioner
  195. My Next Set Up
  196. K&n Fipk
  197. Pan hard bar or torque arm, best for reducing tire hop?
  198. FLP's are in.
  199. Rear Main Seal PROBLEMS!!!
  200. What Size Pulley For 10lbs Of Boost,do I Need It Retuned.....
  201. sub frame
  202. Start car with no trans?
  203. SLP lid & line lock kit
  204. Headers?
  205. c5!!!
  206. best shifter for m6?
  207. SLP 85mm MAF
  208. how well does this flow
  209. slp lt headers
  210. Torque converter?
  211. trans help please
  212. LS1 -> LS6 build up
  213. bolt ons
  214. Give me your .02
  215. Driveshaft with 1350 yolk and u-joint to stock 10-bolt?
  216. Noise
  217. 98 Trans Am, Should I buy?
  218. C5?
  219. Installing autometer gauges in TA LS1- A/C vents..
  220. I need some tech help asap, moser rear end install.
  221. is the 99 TA steering wheel leather wrapped?
  222. Higher temps with Loudmouth?
  223. Another LCA question
  224. dfi gen 7 for ls1
  225. Should I go up in stall?
  226. running rich
  227. Trans Valve Body, What Does It Do?
  228. Tuning after header install
  229. Do All 4th Gens come with...
  230. ASP underdrive pulley question
  231. Air/Fuel Ratio Results
  232. Denali or GTO
  233. part # for belt tensioner
  234. rebuild an ls1
  235. sevan series 1999 trans am
  236. Aftermarket rotors on 2000 Formula
  237. Repairing a cracked oil pan
  238. 3 or 4 Channel ABS??? Ummm.....
  239. I have a video of my car with open headers, where can I get it hosted?
  240. Time for a clutch.. what to get?
  241. Trans. Problems HELP!!!!
  242. Finally go some traction!!!
  243. traction control
  244. where to buy gears
  245. anyone got a weight on a stripper f-body?
  246. ttt
  247. where to get window motor
  248. o2 simm problem
  249. Knock , Stall , questions..?
  250. Newbie with Camaro
