PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Tires and Rims 18/17
  2. TA cover
  3. New WS6 redlining?mods?
  4. Corvette Shift Knob
  5. Lid doesn't fit with SLP bellow
  6. Change GEAR BOX!!!!
  7. May purchase a 98 ls1, whats some problems to look for?
  8. Is the "Castrol Semi-Synthetic" Oil better than regular oil?
  9. Headers
  10. Headers
  11. what size injectors?
  12. Dang IAT sensor and grommet in stock lid...how to get it out?
  13. Grease fittings
  14. Turn signal lights
  15. Synthetic or not?
  16. 12's
  17. Question about shifting on track
  18. Got a New F-Body Today
  19. reccomendation for headers and y pipe
  20. Wisper lid???
  21. $200.00 to spend what to buy???
  22. X Pipe
  23. misfire on 5 and 6 and the same time?
  24. Clueless!!!
  25. Problem With 98 TransAm
  26. any 2002 ZL1 owners on here?????
  27. quick question
  28. Cruise Control Problem 1999 Z28
  29. Squeaking!
  30. 35th Anniversary
  31. Does the GU5 code on the door panel mean it has a 3.25 gear?
  32. Increasing Effeciency on the LS1
  33. What is ASR? What does it really do?
  34. How loud would it be if....
  35. Cats bad again...
  36. New to the LS1, what does it take to perform?
  37. anyone ever pull a 4l60E out of a ls1 f body
  38. Rear main seal leaking
  39. For those with TSP lids...w/n
  40. Pontiac Raised Air Box
  41. Do you guys recommend a Struts brace?
  42. Airbox raiser?
  43. $519 Pacesetter LTs?
  44. What is "Track"?
  45. FLP Header Problem
  46. Jethot LT's
  47. Problem w/ free ram air mod...rad. support...?
  48. Break job help Caliper question
  49. What do you think about buyin this?
  50. will I pass emissions?
  51. What length pushrods do I need? (LS1)
  52. TR 230/224 111lsa??? Anyone???
  53. Performance Axle code
  54. what driveshaft do LS1 cars come with
  55. Vss???????
  56. need something cleared up
  57. What to Expect?
  58. Is this normal!
  59. SLP Y-Pipe
  60. Cooling fan Schematic
  61. P1416 code mean?
  62. oil light comes on, why?
  63. Kind of an embarrisng question, but I now need to know.
  64. I finally bought a long sought after LS1 camaro!
  65. Non airtight seal for airbox
  66. K&N Filter Question
  67. How loud is a Loudmouth...
  68. Exhaust
  69. Loudmouth exhaust
  70. Denso Iridium SP
  71. What should I look out for?
  72. Super Sucker scoops for FTRA or SLP CAI kits
  73. No predator for 98. What next?
  74. Engine ping...should I buy the car
  75. Those 5 free mods in GMHTP
  76. is this a good estimate of RWHP?
  77. ls6 intake
  78. Oil pressure slowly dropping....worried!!!
  79. KR Questions
  80. I put 87 Octane in my LS1
  81. Dynomouth
  82. transmission seal
  83. Traded my 96 v6 for a 02 z28...1st mod a cutout?
  84. tach install help
  85. Air restrictor plate and EGR blockoff????
  86. hooker long tubes question?
  87. power steering issues
  88. No Oil Pressure...HELP!
  89. Have a few Questions
  90. Okay folks, what do I need to know about 98-2002 LS1 engines?
  91. oil in LS1
  92. intake from slp
  93. Tramission cooler
  94. Coolant/AC problem?
  95. catback sealer
  96. Calling ALL that have DMS springs installed....
  97. Just bought a 1999 Z28 M6,$13,000
  98. Who makes the best Air Lid and filter combo?
  99. Headlight Questions
  100. whats up with this shizzle!!!
  101. Red Top owners, HELP!
  102. Dynomax exhaust
  103. Lingenfelter!!! (Turn ONE) Power Steering Pump
  104. Needing a dyno shop
  105. So the auto headlights pissed me off to no end tonight!
  106. Keep The Ss!?!?!?
  107. cutting the intake on an ss?
  108. magnaflow
  109. Oil on #1 plug
  110. Reliability of Hubs/bearings
  111. coolant questions
  112. SLP Intake package
  113. Anybody use that Redline Water Wetter ?
  114. New Motor??????
  115. bassani orp and magnaflow...WOW...what a sound
  116. Wiper probs...
  117. Next mod? poll
  118. anyone put 245/45/17" on their SS or WS6?
  119. GM differential fluid, yes or no?
  120. clear sidemarkers
  121. Muffler
  122. g5x1 cam specs?
  123. What's Next?
  124. lower control arms install
  125. rear end ate up 4.10's in under 2k mi
  126. power pullies
  127. will C5 brakes work on LS1 Fbod spindles?
  128. help please
  129. slp long tube headers and scraping...
  130. What is life after the big 100k...
  131. What Tools Do I need
  132. Money to spend?
  133. '00 Z28 - some advise please!
  134. Does anyone have a loudmouth setup with the dynomouth muffler?
  135. Intakes?
  136. F*#k........ Power steering is gone
  137. RPO codes???
  138. Quick K&N help
  139. need help picking LT headers!!!
  140. cam/rockers/lifters/springs change
  141. Hooker LT install
  142. Disabling airbag light? Here's how!
  143. Traded in my 85 Vette for 01 SS.........
  144. ls1 displacement
  145. LS1 Fuel Rail Covers
  146. dyno results, what about your ls1
  147. Cooling Question
  148. o2 oxygen sensor part # please
  149. Which SFC's?
  150. My oil pump is toast
  151. Size of Pacesetter Lt's
  152. Exhaust Poll !!!
  153. Help Voltage gauge going down
  154. Most HP heads Cam LS1?
  155. 32v Ls1
  156. Dynomouth help!
  157. Anyone know their actual (normal) operating temp?
  158. Gasket on lid w/ K&N needed??????
  159. How to understand cams...
  160. B&M ripper shifter
  161. forged internals...
  162. Selt belt question
  163. (HELP) Idle Control System High
  164. Option DE4...where can I get?
  165. Corsa tips on a Loudmouth?
  166. bassani exhaust?
  167. Muffler
  168. power loss question
  169. Descreening..is it worth it?
  170. is the bbk 80mm throttle body worth it?
  171. GMMG exhaust GP! We need 5 more!
  172. Rearend/Rear suspension noises
  173. stock Z28 tires
  174. ls1 underrated?
  175. Think this is a scam?
  176. Getting GMMG exhaust, question about tips
  177. Need part #
  178. M6 Shifting problem
  179. Cooling Fans, V6 vs. V8
  180. New 2000 Z28...cheap upgrades?
  181. Traction Control
  182. I'm cheap...how's the exhaust?
  183. X or H pipe...
  184. More power....ugh ugh ugh!
  185. How do you drain coolant from a LS1 block?
  186. Anyone know about the new F.A.S.T. intake manifold?
  187. CAI Packages
  188. Octane Question
  189. EGR information??
  190. LS1 Smooth Bellows
  191. Gears???
  192. New Engine
  193. off the line
  194. LT1 cam swap Vs. LS1 cam swap??
  195. Ebay
  196. rear tires
  197. Running HOT?
  198. 02 simms for gutted cats
  199. True Duals with Flows VS Dynomax
  200. Power steering went out
  201. Problem with window
  202. new racing k-member
  203. LS6 Intake on LS1: are the ports matched to the head ports?
  204. Plug Wires with LT's....
  205. MAC question
  206. '98 LS1 rebuild, stroked or stock?
  207. Rearend Problem
  208. New numbers!
  209. Did my Rotors Warp?
  210. 17 X 8 vs 17 X 9 tire size
  211. Does anyone remember.......
  212. Once and for all MAF Screen removal
  213. RPO codes
  214. Is the SLP MAF worth it? Or MAF ends worth it?
  215. is this true
  216. Just a little note
  217. Which cam for my 01?
  218. Need yalls expertise
  219. Daily Driver and the power steering pump
  220. Light Problem
  221. Stock gear ratios
  222. First Time at the track...
  223. Cheapest SSRA?
  224. Paint Job.
  225. A catback...
  226. Don't be shy, Scanmaster GP!
  227. cat back exhaust
  228. Rebuild: '98 Z28 LS1- stroke or original?
  229. DEQ engine light prob
  230. O2 extensions?
  231. How does a stroker motor work?
  232. Tranny swap...
  233. Air Lid Dimensions...
  234. Dumb but serious Air Lid question
  235. Do M6 LS1's really burn oil like I've been hearing?
  236. A simple question for all LS1 owners
  237. Battery Dying?
  238. hooker vs borla
  239. going to check out a 2000 SS
  240. Anyone ordered from Speed Specialty?
  241. clutch problems
  242. Wheel size, offsets?
  243. New Car
  244. Got the car back together!
  245. throttle body bypass?
  246. hypertech programmer?
  247. bolt-in SFC difficulty factor?
  248. how much do u guys pay for storage to store your LS1?
  249. 99 or 00? Two beasts....
  250. 99 or 00? Two beasts....
