View Full Version : LS1 Based Engine Tech
- Interior
- New tranny for 02 LS1
- Couple questions about an electric cut out..
- For Those with FTRA
- cam specs on stock 2001 z28
- hypertech power programmer
- 18 mpg
- Tested out a '99 Z28!!!!
- question on gaskets????
- Shopping Help
- New LS1 owner with some questions.
- Header install..
- Pacesetter, AIR & EGR not threaded...
- Anyone here running A4 w/4.10's??
- Dynomax bullet
- Flowtech slip fit cutout from Summit got ?'s ...
- Gas Tanks & Fuel pumps
- Exhaust Cutout
- help please
- Plug wires for relocating the coil packs???
- Help! The window motor I got from Autozone is different!
- ..what to do when gasket blown, and ls1 out of warranty...
- GMMG group purchase
- fixing a 98T/A what about a 6.0 ASAP
- All GMMG people inside!!!
- loose frontend
- !Help! Need website with camaro production numbers for 97 and up!
- Performance Options on 1998+ Z's
- Those that are using the Qwik Stick short shifter?
- Average Life for Z-Rated Tires
- thermostats
- www.ls1tuning.com
- Valve Springs with this cam....?
- Headlight housing's, are there others?
- Huge Gas Mileage Increase!!!
- 99 z induction
- LS1 SS Convert Question
- $1600.00 to spend on a new camaro
- fuel pressure test question
- eibach prokit
- New Ss, Need Some Help
- More drastic difference then I thought, CRAZY!!!
- Affordable LS1 Stroker Kits Coming
- LS1 oil change...
- Yokohama v/s Nitto
- Buying a Used LS1 car
- GEN 7 is NOT a plug in!!!!!!
- Has anyone tried this bolt on air scoop?
- GMMG Exhaust
- Muffler --> catback or just cutout?
- problems with starting and idle...
- hp gain?
- Shifting Techniques
- Need some LS1 SS help
- Engine temperature
- Piston Slap, etc
- carb on ls1
- Need programming!!
- Where to get water pump
- What's the best time of the year to buy a WS.6
- Z28 vs. SS/WS6 Sway bars
- Pacesetter headers?
- Has anybody put an LS1 in an LT1 car?
- stock 2001 TA horsepower/tq ratings
- Advantages of the LS6 block over the LS1? And likewise?
- LS1 swap into '70 Vette
- Resetting Computer
- new best time
- Gas milaege with a 4.10, need someone with 3.73 to compare with..M6
- Ordering Pro 5.0 shifter tomorrow!
- Lights flash like a strobe..what up with this?
- What gains to expect on gutted cats?
- lifter problems? maybe
- What else is needed with Eibach Pro-Kit springs?
- Vehicle information
- Some Torque Converter Questions
- Mods for my Camaro z28
- How much for:
- ls1 long tube headers 41 horses?
- Any probloms with injectors?
- 285/35 on 11'' wheels?
- Engine light on and no code was stored
- Do LS1's have this thing ....
- Ls1 Rev Limiter...
- Good Exhaust For 2002 SS?
- Winter rims and tires
- New FireHawks for sale?
- TR 224/224 .561/.561 114 LSA compared to zo6 HELP
- is a tc bad for a trans
- do 15" prostars fit LS1 brakes ?
- Ls1 Rear End
- Transformations is taking place
- Tire Pressure??
- another Hypertch PP3 question?
- Pacesetter Headers Install
- cheapest place to buy tires?
- Where exactly is the Body Control Module located?
- Squeaky Rear
- Good exhaust to add to the SLP long tube headers.
- Convince me!!
- Lowering Springs Help
- Z28 springs V.S. SS Springs?????
- Most economical way to make 400hp
- SLP 345 HP Dual Dual Exhaust
- do LS1s have the same blocks as LS6s?
- bought 99..mods?
- Warranty Voiding- Moss Magnusen pages?
- Lights not working?
- fuel pressure question
- 1/4 Mile times/ power gain question
- LS1 head flow numbers
- My FLP LT Install Notes
- LG Motorsports "Super Cool" radiator??
- Cheapest LID is it SLP??????????
- how much power from a cam?
- slp ls6 intake converison
- Need Help!! -- Car Won't Start
- 4.8L Truck Crankshaft in LS1?
- Need wiring help!
- Milage on some Drag tires
- i need new tires and the guys in appearence section arent helping me
- Built numbers?
- ?'s about GMMG --->>
- What is ASR?
- what king of radiator??
- Do the stock tires suck that bad??
- smoke coming from oil fill breather...
- Tell me about car ramps
- What do LS1's run with bolt on's?
- What's the point of this mod - X-over
- Air Bank Fault?!?!
- OPINIONS NEEDED - Suspension Q's
- Fire extinguisher overheat?
- Correction: 6$Smooth Bellow
- Easy Header Question
- Ever see tires damage like this!?!?!?
- Hooker Headers
- LM question
- Which tire to buy?
- Smoggable cam
- Straight Pipe sideeffects
- need suggestions
- Who Has Ran a Stock 12?!?
- IAC question...
- how to improve ride quality?
- Security Light - Car wont start
- Problem w/ rear defogger/power seat
- Throttle body bypass question.
- Which brake pads?
- Catback lower value of my car?
- ls6 intake install
- ATI's new complete kit for the LS1
- 3.90 gears now available for the Strange 12 bolt
- Everything to know about an LS1
- T-top conversion
- LS1 question
- Is GM CheaP????!!!????
- 12's Baby!!!!
- Wheel size
- Tire size
- Can someone please tell what this code is?
- Question about turn signal
- Are JBA's the only 50 state legal header...
- Anyone Here Ver Use Hypertech ?
- where to get used parts
- quick question
- Big difference ?
- Question on true duals and suspension
- Street Legal LTs?
- Should I buy A High Mileage LS1?
- Suspension for 1K
- won't run WTF
- Oil Life Monitor....
- Upgrading Ignition. Advise?
- Engine Oil
- Engine idle
- computer not ready
- cam question
- Wiped out & hit a curb going 35
- Workin on an ls1
- cam for an A4
- hydro roller vs solid roller
- Is this too many?
- Cts-v
- flowpac vs fipk
- strange shift light/tach reading
- Does the McCord Company Exist?!?!
- Just bought $6.00 smooth bellow
- How long do you warm up your car for?
- Battery Warning!!!
- SLP Suspension v/s piece built.
- LS6 intakes stock on 01-02 Z28's ??
- Price
- Brake Problem?
- supercharge or lotsa bolt ons and 410 gears?
- LT's or shocks and springs????
- Dropped the car off at GM....
- RPO Code list
- Last time, Flowmaster or Magnaflow?
- Thermostat question???
- What Temp should the LS1 Run?
- Ticking AFTER Warm up.
- Stage 2 Heads & Cam
- LS1 Gas mileage
- MTI Clear Lid
- engine cuts off without warning. no codes.
- Thanks Guys
- ls1 Motorsports
- What size tailpipes come standard on the 2002 Camaro SS cars with round oval tips?
- Installed subframe connectors, bumpier ride?
- Tires
- how to replace bulb for turn signal?
- clicking noise on front passenger tire?
- A hp question
- what do i reprogram?
- 400hp goal : Safest and economical way
- SLP lids
- opinions on best underdrive pulley kit??
- Need Help!! What to do with truck?!!
- SS Part Number
- ls6 intake conversion
- I need opinions from Magnaflow exhaust people
- Any differences in '98-'02 K-Members (Complete from rotor to rotor)?
- ATR pitt-bull mufflers
- Best window motor?
- Hawk VS EBC Greenstuff
- Cold Weather =/
- Turbo, SuperCharger, or Heads & Cam ???
- Height and length of a Wolf race craft 6-point cage?
- PCM pin numbers please...
- The Best Sway Bars?
- o2 sims and extensions
- New Cam Question
- LS1 Rocker Arms
- looking for advice
- sun visor just fell off!!!!!!?????
- ls1 book
- Finally picked up my....
- best intake set up for 99 WS6
- Autometer Air/Fuel Gauge Install?
- macs hooker and loudmouth
- Rear view mirror lights
- coolant issue
- Ls6?
- opinions: 98+ transams
- Motor mounts
- new best on Sat.!!!!!
- Engine noise and oil consumption... what's normal for an LS1?
- What Exhaust do I have??
- how to tell if its my water pump
