View Full Version : LS1 Based Engine Tech
- Mac header exhaust system
- How hard is it to replace oil sender?
- belt tensonor
- Flowtech Vs. Hookers
- headers
- SlpFlowPac Or 3.73 gears?
- z06 conversion ????
- Question about Cams
- Picture request :)
- oil consumption
- Bassani Headers
- So who will be swapping their LS1s to the LS2?
- Whats next? Slow with headers!
- to free, or not to free? that is the question..
- LS1 Swap to a 1st gen Rx-7, help?
- so my oil pressure went to zero when i floored the brakes ...
- Ses P0140
- cam or lifters or spring noise?
- Magnaflow/carsound catalytic conv.?
- FAST LSX questions
- WIERD start-up problem
- SLP "Performance Prepped"
- True Duals compared to other Vehicles?
- airlid install question- need help quick!
- Fuel Mileage Question - for A4 owners w/ a Stall.
- did some checking today...
- Lt1 to Ls1
- LS1 questions
- TSP Custom 220 Cam: 220/220, .564"/.564", 114 LSA
- Knock knock
- look!!! new ls1 engine girdle
- How much is a new LS1 motor?
- couple of general mod questions
- What cam for my TA?
- ls6 intake conversion?
- Ssra
- Question
- Problems starting?
- LS1 Engine Swap
- QTP Headers and Installation
- Prices
- Are these good flow number for ported ls1 heads?
- 01 SS = Couple ?'s
- Cam packages & pricing
- Question?
- AC wont blow
- Battery dies, I jump it, car drives around idling at 3k and tries to keep RPMs high
- Cam Question
- problems with starter
- cam selection
- 6Liter heads
- 00 with lsx intake mani (fake egr?)
- SLP Headers/Cats/YPipe
- How much oil does your ride consumer per 3k miles?
- Y pipe help
- Piston Slap, Change Pistons?
- abs inop after cam
- 400 rwhp possible NA with California emissions?
- Heads, cam, & bolt-ons results
- new LS1 owner
- reliable 550hp?
- ? about 6L
- Cam install
- I'm starting a true dual photo and parts database
- Iat......tb Bypass
- what and why? 5.3L heads.
- is changing really that bad
- GM Top Engine Cleaner / Piston Slap... RESULTS
- How "Streetable" Is This Car?
- Missfire..
- Curious on Emissions
- Car breaks up above 5,000 rpm???
- Vids of my Z after the h/c swap..
- Plugs and wires
- Help with future mods...
- hp gain with a lid?
- Longtubes w/catted y-pipe
- magnaflow muffler on ebay
- some wierd noise
- fipk or lid...etc...
- Pacesetter LS1 headers. Smog or Race?
- 380+ Hp
- Getting longtube headers. Should I go catless w/GMMG?
- A chatter noise what could it be ??
- Read Me! Before You Start A New Thread!! *** ***
- 4.8 truck heads on LS-1?
- Whats that on top of my Header?
- Headers
- Trap speed question..
- Do they make a cai kit for a WS6 ram air?
- Velocity Stack
- should i raise airbox or not with slp lid and ssra? raising kit on ebay?
- Something cheap or free for exhaust ??
- Options to Free Ram Air
- Milage to get the LS1 tuned up?
- Just got my new custom exhaust installed. Pics!!!
- Thunder Racing Cam
- cam install
- Anyone ever done the TB bypass and then CUT the unused tubes off the TB?
- Injector size suggestions needed
- exhaust
- 382 effect on fuel economy
- looking at getting a LS1
- Magnaflow to low?
- loud wierd fan noise
- What do I do first?
- SLP 485hp Head & Cam Package
- 1/4 mile time 2002 z28 M6 conv.
- Cam selection and install questions??
- What's the best sounding exhaust?
- 60K+ Mile LS1 Owners.. Inside
- $400 budget for suspension or other?
- Intake Manifold Removal/Installation: Tips/Tricks
- !fra
- What exhust to get?
- Are LS1s prone to trouble?
- do you know anything about cams? please help
- Getting long tubes and true duals
- Reverse split thunder cam
- What to do ?
- new 2000 z28 ?
- Oxygen sensor replacement
- How to catch a snake?
- Time for longtube headers
- ram air ta guys inside
- what ls1 to buy
- LS1 sleeper cam
- Looking to buy a 98-99 Z28 questions inside...
- How much quicker are LS1 SSs from each progressive year?
- help! Big Problem!
- Whats wrong with my car???
- New times
- Are these cars tough
- thingie next to throttle body??
- Tune for Headers?
- 5.3 heads
- who does ls1 edit in pa, oh, md, or nj?
- do you know anything about 3.73 gears and shift points?
- 00SS not smog with LSX OR LS6 INATKE
- Anyone here go from an LT1 to an LS1?
- SES light....
- Cool to run defroster and such w/o A/C Compressor
- will a hooker Y pipe work with pacesetter LT headers
- Peak Power!
- looking for stroker kit and blower and all of the info and help that I can get
- cam size
- do i need emissions breather wit this lid
- Will the stock ECU give me problems?
- can't stop pinging..........HelP!
- insane misfire on cyl 5-8
- camaro no start-security light
- Ls1 Problems?
- Hood/Lid clearance problem
- Someone got a clue?
- Service Engine Soon-P0171
- Coolant Leak
- Y pipe help
- Where can I get a clear Air lid?
- oil catch can
- Gutted my cats... no SES??
- Volant intake question. Ram Air?
- pvc ?
- Need info on wrecked white 01 ws6
- AHH! might have messed something up...
- help
- Best Cam?
- Fuel Pump Size?
- Do MAF ends work?
- 60-120 faster than 0-60?
- Which cam to use?
- Check this out
- Ssra
- 98 Vs 99-00 Vs 01-02
- TSP Rumbler..?
- EGR modification not removal.
- LS1 HP In reality?
- please help with spark plug issue if you can?
- Top Engine Cleaner / Piston Slap
- LS6 cam questions
- Roller rockers which is the best?
- What do i need to beat a vette?
- Best Cat Back?
- Back at SLP and IDA automotive today
- Vibration????
- Help me select a Cam to match these heads.
- Thank you all for the support...
- do i need any tuning if i get ported throttle body for my 00 trans am?
- when dyno tuning what else do you use besides maf translator?
- Yet Another SES question-catalyst inefficiency
- Cheapest emissions legal LT header setup
- How hard is this to do (full exhaust)
- ? on ls1 head castings
- New to me 99 SS!
- Heads, need an experienced, detailed response
- Who knew a slp ram air would be a pita?
- 99 SS Build Up??
- serious engine trouble?
- Some kind of rattle
- Ls6
- How much hp can I look to make on a 02 WS6 with full bolt on's?
- installed ssra is there supposed to be a gap?
- Volant intake whats your thoughts of it ?
- idling issues
- found trick for rear-passenger plug wire
- Cats!!!!
- SLP head and cam package
- My new (to me) 2001 Z28 6 speed!
- proper manifold bolt torque spec
- Computer throwing a p-0410 code......
- Air filter replacement for 2002 SS 345 D-D
- LS1 heads!!!
- Wanting 500 hp
- SLP Y-pipe installed.....but got Q's
- whats a good heads and cam package
- cam
- Ticking noise
- Hesitation??
- Fouled #5 Plug.. What do I need to check?
- what yr was LS6 intake standard on F's
- Are LS1 main bolts TTY?
- Got my oil changed.. now the Change Oil light comes on
- cam
- I need help!!!
- Cylinder missfire????
- Replacing rod bolts, need rods reconditioned?
- People with MAC headers...
- Pushrods!!!
- Headers question?
- Thermostat Install
- Lid fitment issues?
- slp cam
- ls1 horsepower
- HEADERS ARE IN!! Now I have some questions
- Wiered Problem! Take a look
- New LS1 owner :)
- Gas Mileage
- Best Cam to Get
- To get heads ported and polished?
- what happens when o2 go bad
- How loud would it be if...
- pacesetter lt header gasket...
- Changing oil brands on an LS1?
- alternator
- Billet Aluminum Tensioner Pulley?????
- Ok so if piston slap doesnt stop after warm up how can i get warranty to cover it?
- gas ?
- ses light...1153
- Anyone here using the AMW oil catch can?
- Is this knock?
- stock rear end gears/posi?
