View Full Version : LS1 Based Engine Tech
- What is an LS1 "crate" motor?
- new dyno numbers today
- top end
- LS-1 article in CHEVY Hi Perf.
- My LS1
- which cam for A4
- 91 0ct causing SES light? California
- Service engine soon?
- Ltd. Funds...Headers or cam first?
- heads
- gas mileage differences 01+
- Header install.. need help
- headers - good deal
- Lids on 2000+ vehicles
- Spark Plugs and Wires
- Dyno Tune Today...
- Air lid or K&N FIPK...
- MY SS is making broken sounds!!!!
- New oener, simple questions! =)
- New NA record?
- Yet another cam question!
- New BBK SSI-Series LS1 Intake Manifold
- where to buy wires for ls1 that u make yourself.
- Questions about Z28
- header install problem
- New to LS1.. Dumb Question :)
- post Flowtech LT install
- a pic of my dynograph
- B&M trans cooler and ftra question.
- SS Pkg-SLP or Chevy
- 01 Temp gauge = Dumby light
- Another cam swap Q&A
- need a cheap hi-flo cat y-pipe
- rocker arms
- Going to take a look at a LS1 for sale...
- Pulling the Engine...
- track results of my 02
- Just realized how lucky LS1 guys are
- o2 sensor problem
- headers=next mod
- Should i do it
- Did all ls1s have an oil pump problem
- Can anyone help??
- LS1 swap
- Speedo Help!
- Best 1st mod?
- Someone must have a link to this article....please
- gas mileage woes
- LS1 swap
- is this water damaged Ta worth looking at(some motor noise)
- Best EGR blockoff!!
- GMHTP 10 free mods
- open headers runs my life.
- does a 00 ls1 have egr?
- rockers and lifters
- how to remove injectors?
- cam specs, springs needed...etc
- Oil monitor?
- This really sucks....
- are the o2 extensions supposed to be the flat 4 pin style or the square kindfor ls1
- Check out APE's New LS1 5.3 Race Heads!
- Any1 have any info on putting a LS1 in a Chevelle?
- 2001 Camaro Repair Manual
- what size cats
- Ssra????
- I have the slowest cammed LS1 in this country
- Pics from underneath car (radiator area)
- New Racetronix F99 Fuel Pump System
- Cant decide
- Top End Performance
- Billy Grahams camaro
- What kind of car is this?
- Just bought headers...have questions
- stock ls1 info
- Electric water pump owners>>>in here please!
- Are long tubes easier to install on a LS1??
- performance Q
- annoying engine noise - what is it?
- Pace MAF
- flp
- VIN for LS1 equiped chevy
- Camaro wont start!
- Home made polly mounts?
- 98 ls1 computer ?
- rear end question
- Casting flash on LS1 heads?
- good deal?
- ls1 coils ?
- LTs and smog
- Messed up valve springs ...
- Is the timing right?
- Cam/heads question
- diff between '98-'99 and '00+ lid?
- where to buy coil packs??
- Shorty's No Performance ???
- ok guys i really need your help
- what gains would i get from stage II 5.3 ported heads from patriot performance?
- Z06 85mm MAF add power?
- P1416 98 Ls1 Z28
- Good Cam?
- next mod
- mac header install
- Long Tubes
- Vacuum gauge question
- What size are the boltholes on the ront passenger head?
- spark plug gap with cam
- Looking for a Sleeper Cam..
- LT1 LS1 swap
- LS1 Guru Test...ie my problem
- where to buy SSRA?
- Ls1 piston slap, oil consumtion
- Will these mods make this kind of HP???
- ls1 crankshaft
- lid again
- Where Did You Install Your
- question what kind of pisitons come with the LS1 engine?
- Sparking valve cover
- ticking from passenger coil pack
- Best Lid
- piston slap got the best of me
- Need Help Asap
- 6 Bolt Mains
- burning oil
- patriot performance
- hello cam help which one?
- starting problem
- Squeaky noise
- Ls1 in a 240sx???
- Ls1?
- will LS6 drop into 98 t/a?
- Just Bought a 2001 Z28
- Comparing the LS1 and LS6 intakes
- Buy LS1 w/ burnt valve?
- valves
- TREX on the way !!!!
- Code P0420
- LS6 intake Q
- Will these mods put me over 350rwhp?
- more cam questions?
- 2k-3k bog
- NGK PTR5C-13 plugs found in my TA, questions!
- SuperMaxx header dyno results
- PLEASE Hurry. What year is this casting number from
- Quart of oil low after 3000 mile
- running rich any ideas?
- A new cam for a mostly stock LS1 question
- Need dimensions of stock spring seat PN 12565118
- Header installation on my 02 SS
- spark plugs
- Code PO303
- Trouble code
- Gots me a new cam whats your opinions
- lifter change question?
- Is This True About The LS1??
- Codes????
- Dyno Results
- Heads/Cam swap question
- Head porting
- Not another "what will run" thread!
- Got valves out....how do you tell what wrong???
- LT1 vs LS1
- whisper induction lid vs slp induction lid
- Need new pistons...what to do
- changing the valve springs
- ls1 price???
- Diablo Programmer.
- po 1416
- lid shopping
- Want to Learn more about the LS1..
- stock heads, biggest cam?
- Friends New 02 Trans am What mods with this amount of money?
- After lid then what?
- SSRA questions
- Best Valve Springs for .581" Lift
- fitting
- Best smog legal heads in cali? Patriots 2?
- air lid, MAF, filter
- Super Sucker Ram Air
- Switching out Stock Headers for Aftermarket
- How do you check......?
- 98 LS1, need facts here
- What to look for when shopping for an LS1
- Super Gas Project underway !!!
- AFR Heads w/ CC 224 cam 500+ hp?
- New LS1 power output
- Airbox front clips
- Flowtech headers & ory-pipe installed
- Hooking up after market tach???
- cam or bolt ons, help me
- Interest in true dual exhaust over the axle
- hi flow lid
- What mods to chose
- Service Engine Soon - P0442
- YAY!!! My car burns oil...
- Raining last night, runs bad, no power now
- easy question for LS1 masters
- P0300 codes: Blinking SES and rough idle
- EGR gasket? Blocking of my EGR...
- trouble after cam install
- valve springs
- I need your help
- 382 Stroker ?
- Patriot LS1 5.7 Stage 2 Heads any info
- OMG!! What have they done?
- some people say i need a special smaller socket to change plugs
- Camshaft Position Sensor
- SES code P0430 came up today...
- will 5.3 heads on my stock Ls1 increase horsepower
- My 01 WS6 wont start...What gives?
- thermostats
- I heard 98's dyno lower...
- How do I know if i have an ls6 block?
- ASP pulley
- Installing Pushrods..anything I should know?
- Flowtech Headers
- volant w/ bgra
- Who Makes a Good Waterpump?
- Stock Pushrods Part #??
- stock ac delco plugs or ngktr55?
- part #?
- ls1 engine harness
- Many problems: Running REAl rich, clicking noise from valvetrain, and SES light on
- Alternator
- MOVED: Shift Points!!! Need Help!!!
- Heads up for those burning oil after a h/c swap.
- ls1 problem
- c5-r cover
- Headers 1 3/4 or 1 7/8
- heads,cam,header
- Bellows and Lid
- texas speed 231/231 cam
- which car to get?
- C5R block
- help! SES and smoke out the pipes
- waterpump leaking
- Just got me a 99' B4C camaro...
- power steering fluid help!
- 2002 Z28 Ss
- High Mileage LS1's??? What to look for?
- first mods
- tb and maf
- Quick ?: New Z what CAI do u have/Rec.
- vr velocity stack
- insane misfires are BACK!!
- Headers Or Induction Next?
- TB bypass
- Blowing blue smoke after h/c swap and synthetic switch..
- power steering pump
- headers ?
