View Full Version : LS1 Based Engine Tech
- Ebay Auction LS6 Intake ??
- what year did they make hugger orange ls1
- Slow LS1?
- cheap throw away bearings
- Speed in gears
- 03 cobra injector's?
- Autometer fuel level gauge
- Anyone running TSP Magic Stick 3 cam?
- quick ?, MSD ls1 plug wires, resuse stock heat shields?
- Tsp Rumbler!!
- Power loss??
- 2000 Z28 A4 1/4 mile question
- SLP Dual/Dual to other catback - Gains?
- Engine codes?
- Do i need a computer tune now or can it wait?
- Ticking = Bent Pushrod
- NEW engine?
- 5.3 heads?
- Which Header? Kooks or QTP?
- 2000 z28 remote start?
- how many miles on your ls1?
- engine swap
- Cooling diagram and Electical?
- Head swap HELP
- LS-1 PCV Location on 1998 Z-28
- HELP PLEASE Is New F14 Cam Suppose To Be Hollow?
- thoughts on camshafts?
- SLP Headers & Exhaust system
- asr question
- Any Thoughts On What Will Happen To My RWHP & RWTQ #S With These Changes?
- what would it take to swap my LT1 out with an LS1?
- upgrading a 2000 z28 LS1
- 440hp Carbureted ''LS-2'' Engine ???
- torn between mids and lt's
- Fast LSX Intake Manifold
- 99 headers fit an 02?
- How are tpis headers?
- security light=no start?
- SLP 400hp kit for Ls1
- Anyone done the Ls1 to Ls6 conversion?
- Mac Mids
- ls1 true duals
- What's the part number for the gen III truck coilpacks?
- header install? difficult?
- ls1 ss/ta vs c5 ???s
- whats a loaded 99 6spd z with a rebuilt/ theft recovery worth ?
- yet another Question about exhaust
- new to LS1's - anyone have a run-down list for me?
- 1999 Ss Hp?
- How can i tell if a motor is LS2 or LS1
- Problem installing new idler pulley
- Header install
- help, rust in coolant system
- What about these headers?
- Do you need to bleed ls1 coolant?
- How much of a gain???
- Just installed new opti-spark on my LS1.....
- No starting response
- #'s to expect
- Head price?
- What will it Run?
- lt vs ls motor reliability question
- Cam Question
- P0157 - SES only when Cutout is open.
- LS1 Torque Specifications
- Stroker
- Will I loose TQ or HP??????
- engine swap
- Should I do it? Trade 95 LT1 T/A + Cash for 99 LS1 Z28?
- What do you think about this?
- best pirce for LM?
- Good deal?
- loudmouth bolt up
- Conversion?
- SLP Loudmouth and timming retard.
- slp underdrive pulley power gain??
- What should i expect after the tune?
- Edelbrock LT?
- More Power Needed, Please Help, Currently Have 400RWHP/379RWTQ
- Bad gas mileage?
- ORY got messed up, what to do?
- ls1 questions...
- belt almost off?
- putting a 383 in a 98 firebird?
- crate engine problems
- Edelbrock headers?!?!?
- A Coolant Leak with a mind of its own....
- Stroker or cam/heads
- 2000 SS dyno numbers
- Which mod?
- Do i need a different air filter?
- What it takes ls1 to break into 12s.
- SES code
- Dyno results for my Z
- What next?
- Procedure For LS1 Rocker Arm Install?
- TPS y pipe fitment?
- just odered Pacesetter LT
- Another guess my HP Thread
- Funny story of shattered Valve Spring Seat...
- Funny vid of my Vette:
- First Post! Got a Questions for you guys.
- Header and exhaust question
- SLP cam&head pkg
- y pipe and headers
- Electric Cutout installed with powerstick
- Those of you with Pacesetter LT's
- estimated cost...
- dual exhaust options
- lamborghini gallardo!!!
- True dual muffler choices
- A few ?'s for you guys
- LT Headers, Noise, Slow
- cam instaliation
- Anyone have the P/N for a *STOCK* LS6 oil pump?
- Hogh Pitched Noise Coming From LS1 Engine
- Self tuning using LS1 Edit, and some questions about O2 sensors
- Best cam for a full bolton
- Clean Carbon Off Top Of These Pistons???
- Anybody Know Of A Good LS1 Mech In KY
- Check out this 228?
- What your best guess?
- When is it time....
- How is this cam?
- sudden NO start....
- dynatech supermaxx system
- seting timing
- Air pump check valve
- Cam and rocker arm?
- 5.3 head question
- 2000 LS1 trouble code p1416
- Really worth it?
- LS2 power?
- Over-Drive?
- hp sound right??
- Another Engine Noise Post
- No Power??
- Tsp Exhaust???
- Headers and exhaust?
- Identify the injector
- Installing Gauges -- Need HELP
- sparks coming from under car?
- Fuel Pressure Question...
- Service engine soon?
- fuel rail question
- water pump ?
- 6.0 to 5.7
- What anti freeze do you use?
- Idle Problems Plz. help
- Crackling Noise at Full Throttle
- Power Steering Leak. . .
- MAF clean, throttle problem fix!
- Torque to Angle Indicator for head inst.?
- El Diablo
- Leaking ?
- Is it safe to...
- stock cubes?
- heads?
- SLP loud mouth
- Strange Engine Noise(Vid inside)
- Any warning signs for?
- pcv location
- Single Pattern Cam on LS1
- Can someone explain the differences in the Borla Exhaust Setups.
- Painting mishap!
- anyone have these tips?
- 02 SS headers
- TR 230/236 or F14 W/DARTS?
- any help
- cam size question
- need matching heads..
- cold air intake
- How big with 2.055 valves?
- Need help with exhaust decision....
- What should I look for when buying a 4th gen Camaro
- Ram Air
- Accessory belt?
- SLP 160 stat
- Plugs/Wires
- dirty internals?
- need service advise
- GM MLS Head Gasket Part#?
- Pacesetter O2 System
- Dyno Depression what gives (low dyno numbers)
- How long did your LS1 fuel pump last?
- What will my C5 dyno at?
- Something isn't right in my 98 z28
- Cam only 10's?
- LS2 Timing Chain Part Number?
- WS6: Lid/SSRA or Volant/FIPK
- Fuel injectors?
- LS1 Fuel rail bore spacing & angle
- Finally HERE!!!
- Help with sparkplugs!!
- 11.2-1 OK with 93 pump gas? P/V clear?
- Has anyone tried the
- This Season
- LS1 Blocks
- Patriot heads?
- need help, please
- Should I reduce before or after the x pipe
- PCV question
- Is this a good deal?
- for all the ls1 guys..im wondering about your fans..
- Alternater Help
- Need Help, Header Question?
- MSD blaster
- horrible bucking from a stop
- sound good? i think so :)
- Pulled Car From Storage Today & It Won't Hold A Charge, Any Thoughts?
- Thinking about Throttle Bodie's.
- forged bottom end
- Removal of AIR and EGR
- value of a used ls1
- Backfire at low throttle and WOT
- New Vette Pics and Vids
- How long will it last?
- Heads And Cam?
- Oil Pressure at idle
- What tools are needed for???
- Max horsepower??
- PaceSetter header question
- What brand of U/D pulleys perform best?
- Question about lsx series motors....
- What times can I expect?
- Fuel system
- 98 SS having starting trouble
- Air fuel ratio gauge
- Any maintainance I should do on my car at 40k?
- LS6 head/LS1 header which gasket?
- Quick question for you ls1 guys?
- high idle speed
- retarded question.
- 6.0 crank offset for flexplate
- What kind of shifter do i need?
- Need some help with price quotes that i got on head and cam package.
- what would it take to produce big numbers?
- ls1 header swap and tune-up
- Worth it? header swap
- over the axel true duals
- I need help w my coolant level sensor!!
- Those of you with Pacesetter Headers
- Cylinder Misfiring Woes...
- What way to go ?
- Best heads for LS1
- cat ? HP gains and gas mileage loss?
- O2 Sensors for Bank 1 causing MAP codes??
- misfire
- Want to ride in a car with a stall.
