View Full Version : Drag Racing Technique
Pages :
10
11
12
13
14
15
16
17
18
19]
- Traction issues solved and set new best (barely)
- New best time
- will 16x9.5 et streets fit under fenders?
- auto launches
- Anyone going to the US Nationals
- Pics of new rear Draglites.
- New times for the 91 RS!
- LCA Relocation Brackets??
- Th 350 torque converter suggestions
- Strut Tower Brace for Drag Racing?
- V6 rear springs...worth it???
- 3600+lbs + T56 + N2O=10.14 @ 135.11mph, 1.40 60'... almost there :)
- Anyone like open loop, for drag racing?
- Practice Tree Software
- Dropping front sway bar??
- anyone running a 4-link???? Or thought about it?
- Help! What will i run with this mods?? anyone??
- Just got back from RT. 66
- George Baxter's email?
- Shooting For The 9's, Details Inside
- Anybody in CA....
- Proportioning valve bypass, to stalling converter at the track.
- Hoping for new best in this heat...
- How much does a Spohn Driveshaft weigh?
- Hooking...........!!!!!!!!!!
- First time at the track
- looking for a little mph understanding????
- pinion angle figures- leaking moser pinion seal
- To AC or not to AC...that is the question........
- 123mph trap speeds. What rwhp does this equate to?
- trap speed
- First trip to track - horrendous times - Please help
- How much does a TH400 weigh?
- My 1st time at the track.........
- Good street/strip tire?
- Anyway to make a 2nd gen rear work with a torque arm?r
- Gaging interest in 8.5" ten bolts for F-Bodies...
- Who is happy with their DS loop?
- Heat the tires?
- What Backspacing for 15x8 welds?
- How do you measure backspacing on a wheel?
- Anybody here fried MSD boxes before??
- Madmans got power
- What kind of 1/4 time would this be
- Finally broke into the tens...... now it's time for a rebuild...
- Will LCA's help me?
- Car back together and raced a 502 Nova!
- guys runnin lockers..inside please.
- Nittos Stick on street but can't get hooked on the strip..burnouts?
- 6.6 @ 105.11- 1/8mile, what does that translate into the full 1/4
- clutch
- Steel Street Twin + 4.10s + DRs = spin
- M6 Bracket racers?
- Helemt open or closed face?
- My $5 timing advance kit actually helped!
- 4th gear t56 with 94 console
- what steering wheel to use?
- Loading on a trailer
- powershifting an LT1
- Import vs Domestic Shootout!
- 1st time at track with manual.. im happy.
- Longer wheel studs
- ever drag at Raceway Park, NJ in englishtown!?
- LAUNCHING!!!!??????
- New Times ??
- What should I Dyno at?
- Drum brakes with Draglites
- Michigan dragracers and closeby - INSIDE!
- First time @ track ever (Milan, MI)
- Best tires
- How do you Front Swaybar?
- bogart drag rims mounted on a Z
- flash or stall?
- When to replace clutch, not sure if needed.
- First time going to track with manual.. need a few pointers
- Needing criticism and advice for the worst ever modded Lt1 times :(
- yet another question
- S&W torque arm?
- times on the bottle
- when to shift
- Burnouts
- New Times!!! are these good?
- Dyno Next week
- locker for 10 bolt ???
- Going to the track on friday-first time with the T/A
- front tire ???
- High MPH on ET and lousy times - need help!
- 92 Firehawk vs 97 SSLT4 vs 02 Firehawk
- Can a poly torque arm bushing and tranny mount lower E.T.?
- Going to the track with my new engine
- gearvenders overdrive and a few A3???s
- Cecil County Bracket Finals
- First #'s with my 94 A4 stock Z...is something wrong?
- Got some new times (happy but also kinda bummed)
- 16 yr. old's first time at the track!
- 1st time Drag Racing, went to Bristol DRway, TIMES SUCKED, NEED ADVICE!
- 1st 3 runs ever i need criticism and advice
- Lighter OEM Chrome Wheels
- Want to have some fun...
- How much will and exhaust cutout help my 1/4?
- Well, went to the 1/8 tonight and didn't get where I wanted to be. Need advice!
- Best suspension pieces for a 10 second car?
- New lightweight G2 rear suspenion pieces for the weight-conscious!
- Roll cage!!! I want one! please help me choose
- Going to the 1/8 for first time in 2 years!
- I Finally Did it!!! Hit the 12's tonight!!!
- Would v6 springs and bfg's help me?
- RACING TIPS
- Weight Reduction
- ws6 vs a Lightning???
- how many tenths would i drop if i used bfg drag radials?? how about nittos??at track
- Driveshaft safety loop question
- Finally...First pass on 383
- .500 Pro Tree pondering's...
- First time at the track! (in nearly 3 years)
- Rear Race Sway Bar, which one?
- Indiana racers-Muncie Dragway this comming Wed.
- 1/8 times
- I weighed the Stock Torque Arm and Spohn Torque Arm.
- What 60' times should I be running?
- Horspower Estimate from 1/4 MPH?
- Small Slicks adn Et's??????
- Anyone using a line lock?
- Finally got decent numbers!!!
- Any one know a Web-link to a Practice Tree?
- New track times, how do I improve 60ft???
- Why was my rear end shifting on the line...( / )
- Double Clutching????
- Tonights times what ya think?
- V6 springs?????
- First Time at the Track
- Anyone know the formula for altitude correcting et & mph?
- Solid Roller again..
- anyone going to Grand Bend for NMCA/NSCA shootout?
- Follow up post....went to drag strip for first time...
- Need help clearancing for 28" tires
- Installed Trans Go .. Have questions .(long).
- what clutch you guys use?
- Gains w/ skinnies compared to Chrome GM ZR1's..
- what's a transbrake?
- Are Wolfe crotchstrap bars supposed to come powdercoated?
- Paging all Michigan drag racers and close by!
- Just got back from the track. New times with Hot Cam
- Whats the problem w/ my times????
- Who runs a 17" Drag Radial?
- cheap wheels to use with 26 x 10.5 x 15 ET Streets on 4th gen?
- Not an LT1 question, but need some opinions on what size slicks to run??
- Mr Gasket drag 2000
- Springs...Shocks...
- Need to get into 13.9 13.8 help !!!!!
- My First Run on a Track
- 2 questions here
- East coast fBody Nationals/Looking for pics
- Going to the Track on tuesday. Any predictions??
- Where to buy light weight carpet?
- HELP!! I split all 4 cylinders on one side of my 383 LT1
- LT1 in the 9s....NA!!!!!!!!!!
- Is there a way to figure out track elevation?...
- big cams, big tubes, and knock sensors????
- A3 users, what TC are you running?
- Ok so who is going to win??
- HAL QA1 install
- 94.57 mph in the 1/8
- Went to the track again last night, got no traction and some bad caliper rattle! help
- 1/2 inch play in Dshaft after moser 12 bolt install, to little?
- Using bald street tires as slicks...
- If I ran a 8.00 before, what do you think I can run now?
- Problem With HAL Shocks Unloading
- First Pass on new combo & BOOM
- 15 x 8 Draglites - what backspacing and bolt pattern?
- Hoosier Tires!!!
- So what are all the Big Dogs up to?
- Flowmaster Vs. Borla
- What's your best R/T?
- B16 sc civic
- can we say traction?
