PDA
View Full Version : Drag Racing Technique
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19
  1. OKAY... so I laughed at you guys with OBD1 and loose converters, well...
  2. I Can't Stand Rice Boys Any More!
  3. I think you guys will get a kick out of this quote!>>
  4. Carlsbad Videos
  5. 275/40/17 BFG DR tire pressure at the track?
  6. est horsepower.
  7. Track Tips For A Newbie
  8. Question about 6speed at track
  9. First time at the track with the engine back together... need advice (LONG)
  10. Top fuel dragster info HOLY S@#$
  11. Tire Pressure in Nitto 555Rs
  12. ooohhhh yeahhh best 1/4 ET's from Friday night
  13. New times and a problem
  14. First time out this year....Not very good 60's
  15. Weld Pro Stars
  16. Lightning times?
  17. How much to install LCA relocation brackets?
  18. New Best At Mir
  19. New 1/4mile bests with the stock stall
  20. Car hooks good but poor 60ft. Help
  21. Need LT1 intake ..baad!!..Thanks ahead.
  22. Airbags in the rear?
  23. Relocation brackets.....which setting?
  24. 6spd launching "tips & tricks) needed
  25. Helmets - $150 the least?
  26. first 1/8 passes how did i do?
  27. Best ways to run an A4 LT1
  28. Some serious traction help needed
  29. just bought a LS1, what can it run?
  30. How should I race my A4
  31. help analize my timeslip!!!
  32. Improved times
  33. Finally happy with my times!
  34. z06 calipers - skinnies?
  35. new 1/4 times, need some advice.
  36. New Runs with FLP Level 4 & 3600 stall.
  37. new NA best, and crashed car .. some advice for the rest of u...
  38. ? for manual tranny racers...
  39. Guys who have done a th350/400 swap..please come in.
  40. First time @ track in the C4
  41. Wanna see the fastest LT1/LS1 Cars in the Nation?
  42. improved 1/4 by .3 but same MPH???
  43. 9.68 run is up........
  44. How much does head wind and humidity affect ET and MPH?
  45. Finally got some Track Times w/in
  46. new best 9.86@134.5 naturally aspirated LT1
  47. New Times (lid only)
  48. 13.2 at 18 mph
  49. How does 9.68@141.5 in a 6-speed sound
  50. What size DRs are you running on 15x10s?
  51. 'Steve in Seattle' for President!
  52. LT1 Nitrous times
  53. Stockish LT1 times inside...
  54. Any Way To Calculate 1/4 ET From Just 1/8 MPH?
  55. Too much power?
  56. Amazed at how much faster i am.
  57. My Best times 1/8 trk
  58. new 1/8th mile times
  59. How many of you guys have Welds, Centerlines, or Cragars'?
  60. RJS roll bar mount 5 point harness?
  61. how to improve 1/4 times
  62. 60ft effect on 1/4 time
  63. Any ideas on what I should be running?
  64. track times!
  65. Will I pickup with a spool?
  66. TH350 conversion, speedo signal question:
  67. WTF!!! Car got slower! Any ideas?
  68. Room for improvement?
  69. What do you think I'll run?
  70. Good stock time?
  71. what do u guys think?
  72. pics of 15 x 8 prostars or draglites please!
  73. Front Skinnie Questions!!
  74. Need to get in the 12's
  75. My 1/4th times HELP
  76. first timeslip ever
  77. 5 speed
  78. time on the quater mile
  79. This is why roll cages are important
  80. 10's 10's 10's 10's
  81. Editorial: Tony Pedregons funny car top!
  82. bone stock vert
  83. Neutral Stall
  84. new setup nets me .5 sec with 28" tire on motor :)
  85. Best Suspension piece?
  86. 2 Tire questions
  87. Guys with high HP 355's inside.
  88. finally it's coming together...
  89. NEW BEST!!! This Past Weekend Times With New Plate Set up...
  90. 10.29@127.61. .Stock bottom end LT1
  91. 1.88 60' Pulling tire????
  92. best way to launch an auto?
  93. Rearend mods to hook Nitto's
  94. Effect on ET/MPH with heavier wheels?
  95. Going to the Track Friday
  96. Had a close encounter with a Maxima
  97. Roll Bars for Convertables??
  98. Drag Racing Blues. Advise needed...
  99. My first day out
  100. dyno #'s
  101. Tubes or not
  102. New Best.....but I'm not happy
  103. Body vibration
  104. Poor Man's Spool going in 7 5/8"...
  105. Took the win in the 11.00 index class!
  106. widest et street on telstar 15X8
  107. video of my 13.0 run!!!
  108. BMRs LCA and RLB?
  109. 1/4 time??
  110. Better Tire
  111. 3500 stall & 28" slicks on LT1 good combo?
  112. heads up...10% Bogart drag rim price INCREASE
  113. transbrake experts inside.....
  114. NHRA or IHRA safety regulations for 1/8th mile track???
  115. 330 ft. time?
  116. ATI TH350 Owners !!
  117. 10 to 12 bolt
  118. What tire pressure for ET DRAGS?
  119. wheelies
  120. first win!
  121. How should I launch?
  122. How should I launch?
  123. Got To Ride In My First 10 Second Car!!!
  124. times with the new cam
  125. Weld Draglite question
  126. 3rd needs point in right suspension direction...
  127. What to expect w/ my new mods
  128. New best ET with lousy traction from 10 bolt and Nittos
  129. Bracket season finally arrived..
  130. Stock ET Time?
  131. Need help launching ET streets
  132. New Best!
  133. pic of my 1.8 60' time launch!
  134. Times for 97 Z28 A4, seems kinda slow???
  135. Launch RPM's?
  136. TH350 conversion, how did you get the speedo to work?
  137. Anyone use the Hurst th350 conversion kit?
  138. For Tanner and others QA1 setup
  139. What 60' with Nitto's and stock suspension?
  140. How are my times?
  141. Tips For A Good Launch
  142. Track Open's Friday Tip's Please!!!
  143. does this sound right?
  144. question on racing
  145. Getting Off The Line Quick Help Please!
  146. Driveshaft length with a 9" rear?
  147. Launching, high horsepower, a few questions...?
  148. traction/suspention help
  149. Is the street twin SFI approved ?
  150. Where can i get a cheap SFI dampner / balancer?
  151. what backspacing?
  152. Atco Raceways 2003 Quick 8 Season Opener !! Pics and Results !!
  153. Where to get my brakes checked out
  154. New track times....
  155. Roll Cage question...
  156. Anyone running Hoosier Quick Times...?'s inside
  157. What are the largest Nittos i can fit on my stock rims???
  158. What do u T56 guys use for scatter sheild ?
  159. New Best!!!
  160. 1st track run
  161. BMR Trak Pak ??'s
  162. Supra VS SS
  163. best tires without going to drag radial?
  164. 13.8 @ 105 Wtf!!!
  165. ET Reduction?
  166. what are the requirements for roll bar padding ?
  167. I need help figuring out what my car should of ran
  168. VHT Track bite works great
  169. Wolfe Racecraft parachute mount is in :)
  170. rear air bag install
  171. Need help in launching!!!
  172. anyone has any EXPIRED 5 pt harnesses lying around ?
  173. 60' times, I need some tips..
  174. Congrats Matt Swindle
  175. launch procedure
  176. fastest time in any car??
  177. expected times
  178. Degreeing a Torque Arm
  179. ws6 35th aniversary T/A
  180. what times are the 3rd gen 5.7's running
  181. 1st time to track, tips please!!
  182. Koni SA adjustment for mostly drag setup
  183. Some Wild Wheels Up Action !! Enjoy !!
  184. need to lose some weight!!!!
  185. How do I pour 6 qts. of Royal Purple...
  186. How much time will i drop off?
  187. Lowering springs cause a loss of mph?
  188. What traction aids are you guys using?
  189. Tell Me The ET ...
  190. How much should a back half cost?
  191. White smoke from exhaust from Toluene and Marvel Mystery Oil?
  192. HELP! Car cannot launch for crap!
  193. Rear End question
  194. Innertube for Slick?
  195. Burnout & Launch pic of 98 Vobra
  196. What will 5 MPH on your trap speed do? Take a look at 2 times slips...
  197. Strange drive shaft question
  198. Do 90/10 shocks help a lot?
  199. Going for 12.6xx's with bolt-ond only for LT1... Wish me luck!
  200. m6 guys in here for gear question????
  201. 4 banger stang vs v8 camaro
  202. 2003 Goals?
  203. What should i run with 390rwhp @ 3400#
  204. An 03 Cobra timeslips
  205. I didn't know the LS1 and LT1 cars have different trans crossmembers
  206. I am looking for a good A4 shifter for my 4 Gen
  207. new track times!!!!
  208. 9 Second NA LT1 gone Bracket racing!
  209. Out With The LT1...Its SBC Time
  210. 2000 z28 stock?
  211. Nitto 555R DR's 96% tread $200!
  212. will 4.30 gears be too much for my car??
  213. New Roll Cage Requirements?
  214. help, i'm slower with 4.10's
  215. th400 swap tack results within
  216. Z-9s got a question for ya!
  217. just ran a 9.00 in 1/8..
  218. Suspension problems - HELP
  219. Which auto do you guy's recomend?
  220. m6 lingo question
  221. Safety harness help. What kind?
  222. Anyone make Frt Sway Bar quick disconnects??
  223. how do i get a good takeoff?
  224. best launching
  225. Anyone running different than hals up front?
  226. Picture Of My Car Leaving On My New Best 60FT- 1.7!!!
  227. Atco was INSANE last night!
  228. quick question????
  229. Is this a good time?
  230. Biggest Drag Radial you can fit on salad shooter wheels?
  231. Brake Upgrade/Drag Racing
  232. thoughts on adding a spacer to run 4 series gears on a 3 series carrier ?
  233. approx. ET?
  234. Compare These Timeslips- What SHOULD The ET Be?
  235. Almost time..few questions..
  236. Much awaited Direct fit 15 " Bogart RT P1 series now available!
  237. New Best: 5.98 @ 116+ Mph
  238. Raytech Solid Pinion Spacer?
  239. can u use MPH as basis for guessing ET??
  240. Need to know if this Toulene is pure ASAP please
  241. New best ET :)
  242. Mach 1 runs 13.54
  243. Should be a 12 sec car now...right?
  244. Anyone Racing Out @ E-town Sat March 8?
  245. BFG drag radials
  246. Video Chic
  247. Do all NHRA tracks now have the new brighter lights on the tree?
  248. nhra trans am 2900lbs?
  249. Few Engine and exhaust questions.
  250. What gears should I get?
