PDA
View Full Version : Drag Racing Technique
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19
  1. Looking for Jason Warren....(white LT1 Z)
  2. Any benefits to narrowing a new rear end?
  3. 1/8 th times..?
  4. ARE's LS1 RAISES THE BAR: 8.56@ 167 MPH!!!
  5. first time at track with my new 00 TA
  6. different classes
  7. Biggest BFG DR's without cutting or hammering?
  8. Front bumper support removal...
  9. Rice Boys vs Domestics
  10. FINALLY got to the track
  11. Going to Track Today NEED TIPS
  12. clutch
  13. finally got a DECENT timeslip
  14. New best last Tues. @ RT.66 in joliet, il
  15. Harnesses.... price/quality issues
  16. ladder bar questions.
  17. new personal best on motor...11.30@ 121.89mph
  18. My first time at the track, have time slips...
  19. pirelli tires
  20. Nitto's vs. ET streets, results!
  21. Paging tnthub !! NED rules ?
  22. kumho??
  23. Lost trap MPH and running same time???
  24. A Tiburon you all will fear!! No Joking!
  25. My 1st time at the track.
  26. 86 Iroc-Z
  27. Centerline Warriors
  28. Do ET Streets need tubes?
  29. First time @ the track!!!
  30. Questions about BFG DR's........
  31. Is this trade worth it?
  32. Burnouts with 2.73 gears?
  33. First time to the track. Any advice?
  34. Tires = drivetrain question??
  35. TTop owners...new NHRA rule??
  36. What kind of springs/shocks u run?
  37. Need some advice on suspension upgrades what are your ideas??
  38. vega, monza, nova, or what?
  39. LCA relocation brackets on un-lowered car?
  40. Fast guys need your advice on a tire/wheel combo
  41. ? For those with BFG DRs
  42. NHRA Rules for Sunroofs
  43. track times
  44. Finally!, Got a great pic of my launch!
  45. 60 ft With Nittos and 373 gear
  46. HOW do you get YOUR OBD1 running CONSISTANTLY?
  47. 1st time to the track. help me.
  48. Respectable time??
  49. How to launch with a stick?
  50. Best suspension mod for hookup?
  51. New Forum
  52. tire pressure
  53. Anyone been to Rockingham since they resurfaced it?
  54. Does This Sound Right My 540rwhp 2000 Trans Am Went 12.36 @118.4....
  55. first time on ET streets today - did a search
  56. how bad is it to run radial front / bias rear tires ?
  57. Check this out
  58. cam's
  59. Tire width Vs. height
  60. racing harness
  61. Fastest Cars?
  62. 4.10 gears instead of 3.73's? How much gain over 3.23's? 6 speed.
  63. How much gain from switchin 3.23's out for 3.73's? M6 !Guru's only!
  64. Stock TA pinion angle...
  65. Could I break 13s?
  66. Figuring 0-60mph time from 1/4 times?
  67. 9.08 @159.70mph
  68. Anyone try Proform's adj. shift light?
  69. For those of you with aftermarket radiators
  70. what does an 8.40 1/8th mile time approximately equal in the 1/4?
  71. Times..
  72. what would you say is wrong? help
  73. what do you think
  74. First time at the track
  75. 2.4 60 foot...grudge match coming up HELP
  76. Battery Relocation
  77. What will this run??
  78. Will Nittos even help me?
  79. Stock ls1 with nitrous.. what times should i expect
  80. Aftermarket lower Arms?
  81. Trans Am times....want 9's!
  82. BEST size for 16" Drag Radial?
  83. Can a 15' 5 bolt AR truck wheel bolt up to a 2001 F-Body?
  84. Question about tires...
  85. Need Help with Police Drag Racing Program
  86. Ran my stock 2001 Camaro SS down at the track.
  87. Wheel hop bad
  88. new best time
  89. Friends mid-low 12 second Firebird...
  90. Clutch strength, can my stock clutch hold up?
  91. Do I really need an adjustable panhard rod? What about rear springs?
  92. New 1/8 best, here's the slip, tell me what you think
  93. You guys just won't believe what happened to me!
  94. What gear should I run?
  95. First time to track went well.
  96. What are you guys running in the summer compared to the fall?? 1/8 or 1/4
  97. What RPM to go through traps in?
  98. How to figure what gears you need??
  99. Drag Racing is Fun!!
  100. launching?
  101. Octane booster
  102. bracket racing ?'
  103. Im getting a Moser 12 bolt, ratio suggestions???
  104. First time at the track
  105. What should I run?
  106. results from newly installed adjustable rear lwr ctrl arms
  107. How much of a change by going to 3.73's
  108. Seatbelt Re-certification
  109. How much will the Nittos help?
  110. what 1/8 and 1/4 should i run?
  111. SLP 2400 Stall Convertor
  112. What do you think I will run?
  113. Any Capitol Speedway, MD racers?
  114. Why doesn't Pontiac Pro/Stock...
  115. How much should nos help?
  116. why cant i hook with 12.5 ETs and hals?
  117. Got FIRST 1.4 sixty time...
  118. Michigan and closeby racers, Dragstrip rented
  119. help me pick out a tire setup
  120. 26x10.5x16 vs 26x11.5x16
  121. 2.1's for 60' launching as hard as possible, what gives?
  122. Lightweight seats...
  123. Screws and tubes with ETs?
  124. First time at the track! How did I do?
  125. VMP LS1/LT1 Drag Video
  126. '97Z goes 9's...with a stock bottom end
  127. Is there a site that figures out correction factors?
  128. Adjustable shock settings for drag racin.
  129. Race bracket classes?
  130. Just came back from dragstrip for the 1st time
  131. 1/8 mile times and suggestions
  132. Some Drag Videos of my buddies
  133. come on in, take a guess
  134. Need new Tires
  135. Consistancy question
  136. Guess at track times
  137. Moser and TA issue has me concerned..
  138. Traction by BMR.
  139. F Bodys Dominate Outlaw Pro Street, Huge Gallery and Results !! Enjoy !!
  140. At what PSI do you run your tire pressure?
  141. Relocating Alt/Retaining PS
  142. 394 rwhp and only 12.6 ???
  143. Got ET Streets - few Q's
  144. What times with 400rwhp/380rwtq 3700lbs.??
  145. Scatter shield
  146. Running 28" ET Fronts with 26" ET Drags rear: Problems?
  147. Traction Problems
  148. Pix of Convo Pros or Pro Stars on Firebirds/TA's
  149. good drag shocks?
  150. Converting belts from bar mount to floor mount
  151. Travel Limiters...
  152. Slick Rotation!?
  153. Passing tech....
  154. car falling off
  155. Going to new england dragway for 1st time Friday
  156. 12's at Last
  157. Light weight dry cell battery question?
  158. Last Weeks times in my 98 Z.........
  159. Converting 4 point roll bar to 6 point.
  160. Where should I shift?
  161. 60' affecting MPH
  162. New KYB/AGX need help
  163. ? about street legal at nat. trail
  164. Gear Banger makes it to finals at Cecil
  165. Launching and shifting ?'s
  166. ssm products
  167. help, cant burnout
  168. ET streets or Drag radial?
  169. Anybody delete the panhard rod brace?
  170. 1/8 mile times
  171. Losing Weight? Transam
  172. First time running the 1/4 mile, advice wanted
  173. Anyone in the market for an engine?
  174. Anyone been to Andy's Auto Serv. in Monrovia from November 2001 to July 2002?
  175. Getting ET streets for the first time - advice wanted
  176. ET Streets Tire Pressure?
  177. 3500 stalled converter
  178. Have a simple track question
  179. Just bought my 94 z28
  180. Which is it OD or D?
  181. weight reduction
  182. Whole Day Funked Up!
  183. I suck at launching
  184. What ET should I run?
  185. 11.DOH! still looking for 10's.
  186. By how much does heat and humidity kill time
  187. Setting Pinion angle on BMR TA
  188. Suspension setup...Good or bad???
  189. Just ran 1/8th, time q's
  190. Rim screws/tubes for et streets question
  191. cheapie Bart wheels from summit - the verdict
  192. Need wheels...what are you guys running?
  193. getting better, new best input appreciated
  194. Driving the finish line...
  195. Matt SLONOMO... 4 wheel line lock...INFO
  196. Breather Issue on Moser 9"
  197. Do Skinnies make any kinda of a difference?
  198. I am a POE drag racer now...
  199. What's the current fastest 1/4 mile record for LT1/LT4?(HELP!)
  200. comps 306 cam how much HP
  201. First time out bracket racing .. need advice :)
  202. Question about gauges and passing tech
  203. Help out a racing Newbie!!
  204. Yet another weird way to lose.
  205. TH400, TH350, 4L60E or 200R4 questions
  206. What do you guys think of my chances with these...
  207. will drag radials break my 10-bolt
  208. A4 guys how do you drag?
  209. New BEST tonight.
  210. Mini Tub Project
  211. 15 or 16" for drag tires?
  212. 4l60E to TH 400 swap, info guys?
  213. Eibach drag launch springs/ air bag ??
  214. Those with adjustable LCA's. Can I center the tire in the wheelwell?
  215. track slip please advise
  216. Drag Struts?
  217. like new nitto drag radials, 15"
  218. Water pit with nittos?
  219. What about this set-up
  220. Good Weekend...
  221. Where to mount camera for DR?
  222. How to drop thos 60ft times?
  223. fitting 28 inch slick with no alterations???
  224. Those looking for possibly the lightest drag rims for the front!
  225. 8.8" for F-bods
  226. anyone tried these cheapie Bart wheels from summit?
  227. 10.30 133.85 at great lakes dragway
  228. 1st times....
  229. launching technique using 2step, and line lock...
  230. time for slicks
  231. why not shift into 5
  232. Can someone explain DA to me?
  233. analyze my slips please
  234. what size drill bit to drill weld's for tubes ?
  235. Pro Tree TIPS?
  236. Motorcycle at the Drags??
  237. who would win..............
  238. anyone know how to get a hold Steve Quinn?
  239. Dyno Centers
  240. can i use doughnuts(spare tire) for skinnys?
  241. How wide of a tire will fit a 15x8?
  242. Drag Racing
  243. Air pressure in the Nittos?
  244. What springs to get?
  245. Which unleaded VP racing fuel?
  246. Thunder Racing Southern Shootout Rules are Posted
  247. Stalling a high stall converter
  248. Going to the track on Friday,How should I prepare
  249. BEWARE of NMCA Racing!!!!!
  250. Will C16 race fuel help any?
