View Full Version : Drag Racing Technique
Pages :
10
11]
12
13
14
15
16
17
18
19
- took the 383 to the track
- What rpm is everyone launching at?
- Harness/Rollbar
- what do the gtps have on us?
- automatic vs manual
- Opinons on these flow numbers.
- KYB AGX's any good up front?
- Anyone using 2.8 V6 springs in their 3rd gen?
- lower 60' times
- some tq arm questions
- Torque arm or sway bar?
- New Times but...
- Whos Running A Spool
- line lock ?
- Where to go to get tubed ET Streets mounted?
- How fast???
- instant center vs anti-squat
- Time Estimate
- 26x11.5x16 E.T. vs. 26x10.5x16's
- New crappy best;)
- Why won't my lowered 91 hook?
- Just thinking...
- Post your th400 dyno numbers and track times
- 1/8 times for stock LT1
- Finally did it 11's N/A!
- STOCK V6 Time
- convo pros on 4th gen F bodies
- cut-out @ track, uncapped or capped?
- Wanna race a 100% stock M3 6MT???
- Eibach Drag Launch Springs
- Best way to start
- seat brace question
- Roll cage from Jegs for F-body
- Trailering Question
- 13.5 good for my mods?
- How to get rubber off quarter panels?
- How much does deep staging effect your 1/4 mile ets and MPH?
- power to manual steering box on a 79
- Spec me a solid Roller.....
- How Do You Launch You Car
- Best psi for Nitto's at the track?
- How much of a difference from 275 to 315s?
- 26"or 28" ET streets or gear change?
- Complicated gear choice
- I have 2 choices for tires... which ones?
- want traction
- Just got back from track, times inside
- Do SFC's really help???
- Burnouts
- First timer going to the track tomarrow, any advice?
- Nitto DR's...Got a Question
- Wisconsins Greatlakes Dragway: F-bodies VS Mustangs Day.
- Anyone use these rims?
- First run at the track
- Watch out, 14 second four bangers with $0 dollars in mods
- going into 4th right before traping
- New stock head LT1 best inside :) 12.0...
- ET Streets rolling diameter?
- New best... killed the tranny...
- 1st time out on new set up
- Who had the Fastest N/A LT1?
- How much air for my right rear airbag? :)
- 96 ss
- first time at the track
- Centerline Telestar Question
- *Removing Stock Steering Wheel*
- hybrid video
- battery disconnect switch.
- Stock springs in the back?
- Will This Mustang Beat....?
- camaro racing mustang vid link
- E.T. street questions
- Battery Relocation:
- Hal, Qa1's How much did they improve your 60' and ET
- how well do 245 bfg dr's hook?
- Rumor or Truth ?
- Can you pass Tech with the G2 harness bar?
- ok to run 17" DR's in the rear????
- Gear Vendor OD with a 4l60e
- high mileage & internally stock LT1's inside
- How much will Stall converter help me?
- BFG's? or is time to replace the Nitto's with ET Streets?
- Suspension questions????
- Racing Videos
- Battery Cut-Off Switch
- where can I buy?
- g-tec
- Quick and stupid question about pinion angle.
- help me pick out new tires please
- Burnout with Street tires?
- quickest stock internal LS1 on drag radials???
- Best size Rims to get...
- Check my signature.
- How much could I gain with these LT1 mods?
- 5 point harness': Dragster vs Individual?
- A quick question about my 1/4
- broke 12's tonight at HRP!
- Installed the new TC
- Best rear springs for HAL setup?
- Anyone running an A4 LS1 w/4.10's?
- 1.69 60' on Nitto's! New best too :)
- Tweaking Frame Possible??????
- Should I worry about breaking something.
- My car has no endurance!!
- v-6 springs, front? rear? both?
- Custom sub-frame ???
- Who's still running?
- Guys with 236/242HR cams inside.
- 3.73's helped my MPH out.. and some ET :)
- some help on launch...
- Yokohama v/s Nitto
- Street/Strip (mostly strip) suspension suggestions?
- Tire pressure for cammed, stalled lt1???
- Results from weekend race
- new best
- just found something weird on my slip...
- Removing Torque arm for better traction?
- bfg 325/50/15 drag radials
- Tire Pressure
- It has finally been done!!!
- Battery relocation - 2 gauge enough?
- Going to Track tommorrow
- Minimum Tread Depth at the Track
- track numbers
- what kind of 60 foot do yall pull
- Guys with solid rollers in there 355's?
- Quick question to ask?
- how do you A4, 3.73, stock stall, nitto guys launch?
- BFG G-force Drag tire pressure
- Runnig Radial Fronts when using ET Streets
- New best times.....
- new worste time
- *caution* lunati cranks are bad
- drag rims and balancing them?
- Track Collision Insurance/Liability Feedback
- Widest Nitto 555Rs i can fit on stock rim?
- Eibach Drag launch vs V6 springs
- New best today with the vigi.
- If my car could 60 ft good....opinions.
- New Lt1 Stockhead best
- Anyone have pics of where to grind on calipers for weld pro stars?
- New best for the LT1 91 RS
- Got a new best
- Suspension for 02 Z28 M6
- TA and drag race swaybar questions
- New Best ET....Any Guesses What She'll Run On Spray??
- CC305 STILL works! New best street tire ET/MPH
- New DRAG RADIAL from M/T!!!
- tire pressure for stock
- n2o + 4.30 rear gears + 27 inch slicks= ?
- Helmets
- Guys with BMR driveshaft loop, inside please.
- nittos
- New times on new combo
- Anyone Have a Decent Battery Tie Down???
- 11.5" ET Street on salad shooter?
- Drove my dad's 94 396 yesterday
- Time for 12 bolt
- new track times
- Ran My Ls1 Today
- Are 11's in my future
- Best Settings for HAL QA1's
- First 4th Gen V6 to go 11's!!
- Panhard rod in a drag car suspension
- Guys with Aftermarket Torque Arms inside please.
- Best way to Launch A4
- Fishtailing out of the hole... ****!
- new best.....11sec barrier to fall soon!
- V6 springs....
- Anyone else's DR's wear out unevenly?
- *Anti-Bag Elimantor*
- Best drag radial tire size?
- PCM Program for bracket racing?
- What does this ET translate to with a 2.0 60'
- altitude effecting times
- BMR Chromoly Torque Arm
- There is no way i can afford HAL's but......
- U must see this
- Which drag wheels?
- Two-Step w/ six speed
- New best on Nitto DR's
- Chromemoly vs mild steel. Safety in strength vs malleability.
- Lt1 runs 9.73@138.09 n/a
- Storing slicks for the winter
- Got my LS1 M6 to run a 12!
- Found an old timeslip of car...
- First time at the track !!! What yall think ??
- HP&TQ limits of a Yank ST 3500
- heater box removal clarification needed
- Tell me about my 1/4 times- Convertible
- convertor and slicks difference in 1/4
- Who Would Win??... Honestly.
- What Would My Car Run???
- Going to track for first time, need pointers!!!!
- Beat an 03'Cobra last week!
- Good times with 2.73's
- which racing seats?
- Pulling the belt, how much gain?
- How was everyone's season?
- Removing airbags.
- Looking for 12.4's tonight, wish me luck :)
- Thunder Shootout videos
- Texas Speed Heads/Cam Project Z28 Wins Quick Stock and Runs 10.78 @ 124 MPH!
- Just bought some BFG Drag Rads/ think i can run 12's now
- 1997 camaro Z28 vs Talon awd tsi
- fastest stock headed lt1's
- Is the $145 extra worth it.....?????
- Knockin on the door of 12 seconds
- Pics From The Southern Shootout
- I raced using the trans brake for the first time yesterday.
- 93 Formula + Moroso + Loudmouth + Free mods = 13.1 @ 105.7!
- Lifting the tires in 2nd gear
- 10 or 12 point cage, through the dash questions
- How do these slips look????
- stud spacers for weld draglites?
- Autofab coilover rear shocks
- New Best @ Thunder Shootout
- New Web Site
- Ladder bar conversion, keeping interior
- Please diprove my roommates about drag raceing and trannys
- Quickest all stock suspension 4th gen.?
- looking for advice on setting suspension
- Any way to get a 15" wheel over an LS1 caliper?
- m6 driving tips, contribute!
- BMR Relocation Brackets
- How long do drag radials last for everday driving?
- **New relocation kit available**
- Anyone Test 28,32,35mm Sway bars/endlinks for effect on 1/4
- Win a set of TEA Stage 2 Heads @ the Thunder Shootout
- I did it! 10.89 @ 127mph
- Best converter: Coan, Yank etc?
- my best time from rockingham...
- FS or trade TH400
- Fastest Lt1?
- 60 foot times
- new best w/ my new mods
- Suggestions
- new n20 times!
- converter suggestions..
- Fastest stock heads(unported) LT1??
- fs: 12 bolt spool and 4.10 gears
- Great air beats good air new best=10.525
- 13.76 @102
- Does anyone agree that my next mod should be drag rad's
- What would be the 1/4 Mile time for a 3.4l V6 94 camaro
- First Time Track?
- anyone going to the halloween classic at norwalk sat
- Front Disc Brakes
- Do you heat up your drag radials?
- Thunder Shootout, who is coming to race?
