- RCA inputs on 2k monsoon setup?
- Pioneer AVIC-Z1
- system info
- What adaptor do I use to put an aftermarket sub on a Bose system?
- cd changer help
- Recommendations for rear speakers
- Two Questions about PAC converters
- 99 TA monsoon radio
- Higher amp alternator
- power door locks going crazy
- Making steering wheel bottons work?
- interior LED light mod question...
- I SUCK at audio stuff. Need help picking a good amp.
- XM Radio Help
- Turn Signals Not Blinking...
- Need help wiring headlight switch
- Factory CD Radio with 12 disc changer
- Help me build...
- speakers missing in stock system!
- Volume Specifications. W/ or W/O woofer?
- possible to convert accel 300+ OBDII harness to OBDI Lt1 car?
- Stock radio knobs
- Added a System, What do you think?
- Pioneer Remote
- help please
- Digital Audio Mid-Bass Driver
- Pass. side Stealth Box
- NEED HELP:confused:
- Pics of install
- Are theses subs any good???
- Bose amp location?
- Hook up Headphones to a car stereo???
- car killing batteries??
- Polyfill
- mounting my amplifier
- Suggestions for new speakers
- monsoon radio question
- what am i doing wrong??
- what you think about my box?
- Wiring Auto Meter Tach to 96 Camaro Z28
- Bose sub with aftermarket headunit
- CD player problem
- so how do i get to the door speakers in a 98 Trans Am convertible?
- Pioneer AVHP6400 indash monitor wiring issues
- Making LS1 gauges work in an LT1.
- Does anyone have....
- brake lights
- Who has the custom faceplates that read Camaro or Trans Am?
- What can fit a 96 convertable? In the back
- Alpine Type-R's vs. Polk Momo's
- Viper 791xv..add a 508d proximity sensor?
- Speaker suggestions
- Replacement Speakers
- Radar Detector
- 01 Z28 'woofer' replacements.........?
- any one used the.....
- Need 12inch sub for stealthbox.
- New system with Eclipse CD5000 H/U installed....
- Which subs???
- Will my new headunit work with my existing Monsoon system?
- Monsoon Replcment, what do you think?
- Will this model KD-AVX2 reciever fit in my 94??
- stealth sub box for 95 camaro
- Door Speaker Baffles anyone?
- Head Unit and ACS switch not working!
- Good, cheap, online reseller for car audio
- Questions about a stealth sub box for a 97 TA
- CD player 94 z
- 10" kenwood subs in stealth box
- where to mount amp?
- Opinion on these subs
- Siezed Motor/Bad electrics in seats?
- Speaker Sizes 94 formula?
- Monsoon Amp Location
- Help me pick out a 4/5 channel amp and speakers
- aftermarket foglights for 97 z28??
- Third brake light wire route info please
- Cellphone interference with new HU
- Monsoon head unit + aftermarket amp/replacement speakers
- 4th Gen. help pls.
- Factory CD deck problems (95 w/ bose)
- How do I mount a Sirius antenna on a camaro?
- no bass with the top down :(
- 3ohm impedance with midbass driver?
- Monsoon HU
- Choosing the correct ohm load with DVC subs?
- Inputting subs
- speaker wire question
- Subthump stealth box questions...
- Aftermarket 4 ohm speakers reading 1 ohm on Bose stereo!
- Amp ?
- How does everyone fish the wires through to the door speakers?
- will infinity 5 1/4s work in the front?
- Power Mirror Not Working??
- Q about remote starters:
- Battery Being Drained after 1-2 days of sitting..
- Door Speakers in '97, need 2 or 4 OHMs?
- Im new and I have some speaker questions!!
- ABS Inop light coming on from stereo?!?
- dead stereo
- Does anyone make a 12" stealth box?
- What gauge wire should I use?
- is it okay to run these at this ohm level?
- car alarms
- speaker/ audio system question!!!
- Momentary switch wiring
- Are Legacy head units worth getting?
- putting a kenwood headunit in the 94 firebird...
- high beam switch
- DEI Remote Start System
- cant find it anymore
- stock sound system - so confused
- pics of my new box
- 1994 T/A Factory 10 speaker stereo need help!!
- Quick Question
- Which stock cd players fit??
- Monsoon radio locked?
- ported box pics
- rear/hatch speakers
- '96 SS Bose Radio Question
- What kind of ....
- Monsoon Help
- Digital Media
- Bulbs out in the faceplate of the radio
- Factory Monsoon stopped working
- Pioneer AVIC-N2 Install Help
- good or bad idea?
- Driver side window dies after 2 seconds of use!
- ACDelco 12 disk changer problem
- Courtesy Lights Acting Up?!
- installed new Hu and sound is screeching
- System Overhaul
- Relocating Head Unit / Cd Player
- Mid-Range vs Mid-Bass
- Please help me, minor light problem.
- Installing sub in TA...
- iPod Nano Mount
- Fog Lamp Problem
- alarm led
- Key Fob Question?
- alarm memory?
- a few questions
- Add alarm/keyless to '99Z w/no PL PW
- quick!
- escort x50
- Heater fan motor
- Which way is better
- 4th Gen. F-Body CD Install Kit?
- Bose midbass speaker part number
- Antenna Cable fitting into alpine 9853
- Replaced front speaker, sail speaker doesnt work
- what 6.5's for the sail panel speakers??
- Distortion in subs with deck turn on and off
- stealth enclosure for sale
- Location of rear Bose speaker amp(s) ?
- 200 amp alternator
- wood grain install kits?
- help with choosing a new deck
- 3rd gen - Power Lock Actuators - In other Gm Cars / years?
- BOSE in 96 Maxima......HELP ME OUT PLZ
- Lit button questions on Factory AM/FM/CD Delco ][ Player
- 95 bose wiring diagram
- Radar Detector - power wire through the vent?
- Stock CD player
- box...whos got one like this.....
- capacitor
- iPod FM Transmitters for Cars
- Bose Sound System on a 96 Camaro
- Elemental Designs! Which Sub?
- Good company to order from?
- Anyone running 5.25's
- Touchscreen, in-dash DVD players... (alpine)
- New Subs
- anyone have a 12 alpine sub
- Anyone using a Kenwood H/U with the little joystick?
- removal of monsoon system...
- speakers
- Speaker wire diagram?
- Electric cutout problem
- will this sound good?
- Speakers
- need some help picking out my new system
- Where is the amp?
- stock sound system...few questions
- some help pls
- Subs / Bass in convertible?
- No power to new head unit...?
- Bose Radio for 93-96
- Radar detector mounting
- Mounting an amp under seat????
- A/C not working right
- aux input factor hu monsoon
- Alarm systems
- 12 in stealth sub enclosure
- gauge lights dimmer not a fuse
- fron turn signals don't work
- is this a good set up?
- Anyone mount a new amp in the Monsoon amp location?
- New Front Speakers with Monsoon Stereo...
- Does any sell a ??
- Custom Box...
- 1994 Camaro. No Speakers in sail panel area.
- Error codes???
- Which speakers ....
- Amp Compatability
- 1999 camaro flasher location
- AUX input for MP3 player stock radio
- fog light problems
- this item does not fit my vehicle ????
- need advice on upgrading....
- ground on RCA?????
- speaker grills rattling
- Resetting security lock on delphi monsoon 2001 radio
- double din head units??
- How do you disconnect/bypass factory amp?
- need help deciding where to put my amp settings?
- Kappa Perfect vs Polk MMC6500
- Need suggestions on a $500.00 setup!
- i unhooked/rehooked my sub box up to the amp. subs seem to barely be working?
- new sub and used amp...
- how difficult is it to install an aftermarket CD deck?
- any opinions on Pheonix Gold OCTANE-R series
- Anybody still make Din and 1/2 for direct replacement for GM Radios?
- Question about my radio???
- Lock/Unlock wire colors?
- anyone have a single din monitor and a single din dvd in a TA?
- How To: Trans Am Door Panel Removal
- Converting driving lights to DDL's, 3rd gen.
- Trouble with new deck and sub
- question about bose adapter.
- How to get you people to reply? suggestions?
- Suggestions for Audio!!
- Need help on changing front door speakers please help!!
- ~7yr old Crossfire DB Subs???
- alpine speakers
- Gunna buy a system soon, a few questions...
- my amp is on when the tuner is on. but it turns off when i turn the cd player on?!
- Having to ground RCA's???
- Speaker fittment question
- What kind of Bass Blockers would be good to use on my factory monsoon mids?
- radars...
- firebird door panel on Camaro
- i gotta a cd player and it skips.. anyway to stop it?
- Speaker Question
- volume screwed up
- Rear Defroster Detached...solder???
- 3m ruberized undercoating
- Will a hard top camaro head unit work in a vert?
- jl10w3
