View Full Version : Forced Induction
- Help Engine Noise
- how much boost do you think it will take to max my 42's, need new wg spring!
- Fuel/Ignition survey thread plus question about setup
- It runs...and hooks
- maf position on pressure side
- How much should I sell my blower motor for?
- Most Important Gauge???
- Procharger oil
- How many miles will the average Procharger last?
- heads
- opinions on cheap turbo kits??
- Looking for pics of p600b/Install??
- So how bad is my cam hurting me?
- New setup #2
- Oil pan ?'s
- Help Valvetrain Problem!!!!
- What to do about filter
- How Many Cc's For New Head Purchase!!!
- whats the difference?
- Turbo LT1 Up and Running
- help me pick parts for my BOOST BUILD!
- Running stock motor with boost. Who does it?
- Turbo drain?
- any doubt?
- rod,pistion?
- Injectors
- motor is back in(pics inside)
- Where did you guys buy your oil lines? (turbo)
- S400?? Where to buy? (dallasturbo)
- FI engine cooling - post yours
- Lt4 Knock Module With Boost?
- need slimmer fans....what ones?
- Stock PCM. Aftermarket, Standalone? What you guys all running?
- ati supercharger bracket
- Does boost being to high mean restriction?
- What Bottom End/Heads Are You Guys Running?
- Piston Choice Help Low Comp!!!
- Valve covers leak; positive pressure?
- Roots or Eaton style under the hood SC available?
- Erractic tach (boosted application)
- anybody tried one of these things??
- powerdyne supercharger
- Mahle's New Piston -26cc 5.7rod AND 2618!
- S-trim to YSi?
- Pioneer keyed hub
- Aftermarket blocks
- o2 sensor placement ?
- Turbo Oil Pressure
- Guess whats in the box?
- Not An F-body But Its A Lt1.
- New injectors, tune and removing fmu
- maf relocation
- Is a custom Cam worth it for me on boost?
- Those with boost referenced afpr inside
- T Bolt clamps
- rings?
- got dyno tuned
- Where are your pcm o2s
- lets see your turbo supports
- 4 Turbos
- finally some progress on my build
- A good laugh for all you guys... especially blower guys
- Methenal Hydrate
- Oil return line
- back presure turbo exhaust ?
- SD tune w/ F/I??
- crankshaft
- Supercharger tune. Who did it and how was it?
- Bov
- Vertical Radiator
- Flutter
- Comp 987 dual valve springs and boost??
- Torque n hp with 8.5 compression?
- Aeromotive Fuel Pressure Regulator Problem
- So... Compression.. Dished Pistons
- What kind of CR with Iron LT1 heads?
- Supercharged base pulse width?
- Help with cam selection please.
- Higher HP LT1 Guys -- Ignition question
- Finishing touches
- Post your D1SC install pics.. LS1 preferably
- Tuning F/I Questions
- Gear Ratio
- Supercharger & Turbocharger Accessory Parts for Sale
- Turbo Build
- My turbo progess
- Turbo selection
- Trip to the dyno didn't go so well...
- LT1 DIY Turbo Progress pics!
- moving tcs lines for blower
- Aluminum intake with turbos on an LSX?
- How to build 1000 hp LT1
- First Drive
- Alky-Control kit
- Question about ABS block...
- Look what the santa in brown uniform brought me today
- Would this cam work w/ a S/C?
- engine break in
- Does it have to be Custom? (pistons)
- Blower and the spray...
- LSX Magnuson question
- IAT Placement
- Got some new parts and update on the car...
- Sold my blower, bought a hairdryer today
- Wastegate question
- What Else is Needed to when Installing a Supercharger?
- Today's number is - 14.9
- Debating E-Cutout
- Took the car for a quick drive today...
- Pipe plug directly above the oil filter?
- Just broke 600 whp barrier!
- Got a new toy!
- s trim and t trim pullies capatable?
- Turbo oiling question
- Dyno Run – Disappointed - Need advice
- Get rid of FMU?
- LT1 Damper question
- One question for those that went blower to turbo
- why do people go with a aftermarket ecu?
- What head upgrades are needed?
- Pic of my turbo setup launching...
- vortech install help
- Looking for suggestions
- HELP! ATI Damper, need quick response
- Oil Return question?
- Intercooler piping?
- Jet Technologies Superchargers
- LT1 T56 McLeod SFI Bellhousing!!!
- Thoughts on this fuel pressure guage?
- front mount turbo kit 4 sale
- Fuel Pressure gauge on FMU
- Who Wants to Guess HP
- wastegate question
- WasteGate and Bov Signals
- Procharger help part 2
- Supercharged Vette <Vid>
- how much boost if i add Methanol Injection
- Fuel Pressure questions
- Anybody relocate/remove traction control for blower?
- Funny street race video of my car
- Video Of my car
- Can anybody give me some input?
- STS Question
- Part Throttle Knock...is it dangerous?
- Single Turbo Guys....What exhaust.
- Dripping oil from seals after boost
- p600b problem
- This is what I want, how do I get there?
- New LT1 Procharger inlet...
- 3.4 pulley..anyone have one for sale? How many PSI going from 3.7
- What size belt for P600B LT1 kit
- URG :rant:
- do i need to get rid of my pvc valve?
- Taking apart my D1 Procharger
- any disadvantage with a exhaust vacuum crank case vent?
- Turbo's and boost.
- For those that weld your FI setups together...
- Anyone in the market for a good Boost/Vacuum gauge?
- Injectors for f1a?
- Some pics of an LT1 Boost Cast manifold kit
- what wideband?
- Turbo lt1 opinions needed!
- will jet dst tune for boost
- About to start a T-76 LTx buildup...need some advice...(cubic inch questions)
- Supercharger in hot and cold weather performance
- Please, help with turbo selection...
- IAT Sensor
- turbo tubing?
- Video teaser of 1,000 RWHP TT Z06..
- Forced Induction and the LT-1
- sbc 305 twin turbo?
- STS turbo setup
- Be aware of WHONXT!! Scam alert!!
- PCV system set up for turbo....???
- Wastegate,blow Off & Afpr Plumbing!!
- help with front mount intercooler for 69 nova
- Turbo Build
- D1SC Leak
- procharged 434 sbc help
- Wow!
- How do you make/keep a blown LT1 dependable?
- Help me pick a cam
- 50 miles on boost - Thought I would share some info
- Turbo 355 rod question
- will headers for an 86 camaro fit my lt1?
- LT-1 Turbo site
- what efi setup
- Overloading After Repair
- Leaking front seal: ATI big block damper
- new dyno numbers
- hahn racecraft?
- Anyone have an AutoCAD dwg for header flange?
- getting rid of fmu and need bigger injectors with tune
- Anyone using an S400 75mm on 1.10?
- D1 external oil source
- Coming to the Forced Induction realm. Need Advice!
- Joined the boosted camp finally.
- Keep LE3 heads on Boost?
- t3/t4e ??
- o2 sensor signal wire
- WANTED-Customer for the Ultimate Power Buildup
- www.lt1boost.net
- Wastegate and BOV Size
- Turbo guys - Underhood temps?
- HELP... Cannot Remove ATI Damper
- Almost left the lt1 world today
- how much is this ATI D1SC kit worth?
- ATI Damper Removal
- Vortech Supercharger Rebate
- A video tribute to CALL911...
- How To Get Spacer Off ATI Damper
- new here from bar area "ca"
- Procharger LT1 Questions
- Procharger Questions
- Twin turbo/centrifugal questions.
- Finding a vacuum/boost leak on a turbocharged car?
- Do I need a bigger TB?
- D1SC and Bypass Valve
- Hypertech Supercharger Pack - 96 Camaro - Corvette LT1
- Any of you ordered a Bret Bauer Turbo cam before?
- LS2 TBody on LS1 (6L truck) with Radix
- Crank trigger with cog set up?
- LT1 Boost PT88 turbo kit
- my 88mm turbo 94z
- What are you guys using for your 90* elbow to TB connection
- Lowering compression for turbo
- In a big dilemma about heads/piston choice for turbo setup...
- P600b leak
- The turbo lt1 on the street..,
- Guess who has become a supporting Vendor...
- Need forged dished type pistons for lt1?
- k27 turbo
- Selling my Camaro
- STS install issues or tricks
- Need lt1 turbo headers
- I-Charger (Twin Screw)
- Upgrading head unit?
- P1SC cam ideas
- Old vid of my Procharged C5 vs. Pullied 2003 Cobra
- My supercharged Z, vs a supercharged Mustang nothcback...
- 10's on stock heads/cam
- Nitrous intercooler spray
- Whats the best headgasket for a boosted car?
- Looking for pictures of FMIC on 93-97 camaros
- OIL weight
- Electric Water pump or BE Cool radiator?
- TTi manifold bolt holes don't line up any more.
- High boost on stock lt1 with intercooler and meth?
- Will these turbos work for me
- MPT70 on a LT1?
