- Pushing my tune up harder
- spark plug heat range gap and brand
- Baseline 8psi dyno numbers in!
- Running rich...getting annoyed lol
- need help...timing,race gas 12psi...
- Compression with Stock Bottom and 64cc Trick Flow Heads?
- Does P1SC Need to be taken off to change its oil?
- Can Jet TunerCat for ODB2 Fix MAF HIGH Freq Error?
- Which 2 step!!!!
- procharger or turbo
- How much Boost Per RPM? (6# Setup).
- What Tables in a '95 PCM Actually do Anything?
- Do Most Use Some Type Of Boost Sensing Timing Control?
- Someone Please Send Me a Clean '95 4L60E .bin
- How much water alky to run
- Just to make sure I have it all right
- Mass air meter for a turbo
- Fastest STS turbo LS1?
- Carbureted Turbo 383 build
- Need advice: go from S-trim to YSI or to turbo?
- Heads and cam to make 600 or more to wheels
- Single Plane or Stock intake on LT1?
- Between P1SC and V2-SQ, Which Produces Less Heat Per # Boost?
- Is my belt slipping? video inside.
- h-beam rods
- Finally got a WB O2 sensor...
- How much boost does a D1 with a big pulley make on a stock size engine?
- Running Crappy
- Budget Minded 500whp (LT1)
- How much SC IC boost can a stock ls1 take?
- What ait cleaner fro LT1 D1SC twin IC?
- Can a D1 Unit be Sneeked by CA Emissions?
- rings for my 355 kb pistons eagle rods 6psi
- How high to spin boosted 383?
- How much boost can my setup handle?
- Using Summit WB O2 sensor with Meth???
- help on procharger set-up
- Whats the least I need to do to make a car handle 8#?
- water/air intercooler???
- Anyone have the ATI 4.5# non-intercooled kit?
- whats the best next step?
- MSD6 BTM needed?
- IAC Relocation, worth the hassle?
- Cold air kits comparison
- Pulley Key For P600b
- How To Remove Pulley
- Single plane blow through power range?
- What pistons should I run?
- STS turbo and cats?
- Boost Bypass Question... Please Help!
- breaking a vortech x trim motor in with out the belt
- I used to have a plan.....
- front mounted innercooler?
- spark plugz
- New Project... How about some input on setup...
- wireing dual fuel pumps
- Seimens High Z 60# inj for sale..
- Hands in Pockets tuning fires up its MegaSquirted LS1
- Dyno Disapointment
- vented crankcase pics!
- turbos
- Finally got some street time!
- Quick Spool
- My 00 WS6 Buildup
- Turbo and engine temps..what do u guys do?
- what fuel pressure?
- How restrictive is my flowmaster with D1SC
- Closed or Open Loop. Pros and cons of each
- Greddy boost controler
- Help me plan my motor
- <10.0 A/F Ratio - How much on the table?
- Who has passed the tailpipe emissions test with a blower
- greatly disapointed with dyno number :(
- First time to the track with the f1a
- pistons? rods?
- Help D1CS car is running bad
- Let's play the guess my rwhp game!
- Can slipping tranny kill boost?
- P1sc 8 inch crank 3.4 blower
- What do you look for in a Cam for Forced Induction?
- What would you do?
- 383 + D1SC or (F1C) = 700 RWHP?
- crankcase venting
- What do your timing tables look like?
- Who do you trust to work on your car??
- post pics of your passenger side logs
- C16 or pump 110?
- boost gauge
- LT1 Booststreet Testing...
- well wtf, how do i fix this
- Evacuation or PCV through the exhaust
- 7000+ RPMs + stock PCM ?
- O-ringing... heads vs block.
- v8 turbo question
- turbo LT1 build
- Do you add some color to your meth?
- mustang dyno and dynojet hp comparison
- Help!! Ram Air Box Fitting Problems
- going from 12-15psi on a p1sc..
- I'm stumped-Is the motor gone??
- P600B idler pulley bearing replacement
- In case you big HP guys are interested in the McLeod SFI bellhousing...
- STS Question?
- IAT Gauge?
- Ram air on a speed density system
- Vortech head bolts stripped from the factory...
- Toughts on this Rotating assembly
- How Much Boost (LT1)?
- who bought jims old kit
- Adjusting part throttle Air fuel ratio
- Truth of Reamo04's dyno graph
- reamo04's dyno graph
- adjustable bypass valve
- I don't know what to do.
- what to do now...
- I have a D1SC with 826 miles on it.
- p1sc help
- p1sc help
- ati fan modification question
- Pics of my trigger wheel and pickup
- getting ready for the s/c
- WTF now.. DTC 43, car runs like crap after converter swap..
- Turbo's are fun
- im back for a couple more questions before i finish my part list
- Am I too lean?
- Pics and vid of my new YSi setup
- Spark Plugs
- How much would my kit be worth?
- Couple quick questions on turbo build
- Procharger tuning questions?
- I have a dumb question about my turbo....
- A couple of question`s!
- ATI D-1SC 12 Rib Idler Pulley Bearings - Bad Design?
- Running without boost for a few weeks now
- getting front off for meth kit???
- "Splash D-Icer" for meth injection?
- Blower pulley change? vortech
- What do we think about Flatout head gaskets?
- 1st Gen Camaro w/lt1 Supercharged.
- What pistons for 62cc heads
- Which header gaskets
- Yay! Milkshake!
- Brace or support for turbo??
- T-64 Turbo RWHP on LT1?
- PT88 74 camaro hotparts pics
- back pressure vs cam anyone tested?
- took out the LT1 Boost Turbo T/A for Maiden voyage
- Vortech Boost Problem *HELP*
- Blowby? / possible blown intake gasket
- Injection Fluid - Pre Compressor?
- Next step??
- Anyone with subframe connectors and the STS kit?
- Turbo or Supercharger
- upgrade: S400 t6
- Merging!
- verticle radiator ?! line from the back of the head?
- A2W vs A2A
- Large single vs twins
- Need help on set-up 15psi of boost
- Boost question
- How much boost with my setup??
- fuel for boost?
- thick walled hotside piping
- Looking to route my BOV exhaust to the ground. Suggestions?
- Vortec boost issues..
- I just ordered Dart Pro1 Heads
- blowby question
- Rear mount turbo questions
- Recommendation on plug for SC'd 496BB?
- Stutter issue
- Need a second opinion
- Anyone have a ZZ502 calibration?
- UP YOUR DRAIN HOLE!! BB vs Standard Bearings
- Switching to ms2 extra
- Anyone know the MAF limits on the LS controller?
- lt1 intercooler piping ???
- supercharged lt1
- Getting hot after sts turbo
- JMD turbo kit?
- Air to liquid IC ?s
- Paxton sn 93
- Blower cam specs.
- Turbo Cam Advance
- Check out the new guage placement
- Anyone use the new 79lb high Z injectors?
- getting ready to order pistons
- ? On DP routing
- Boost Kills... Hemi carnage pics to enjoy....
- Where to buy JGS wastegate springs?
- Is my FMIC causing overheating?
- LE2 and Vortech
- cam swap while apart?
- How would you build my LT1?
- searching for big power boosted build thread
- Anyone running the AEM Tru-Boost Controller?
- 10.1:1 Compression with 12lbs
- LT1 Supercharger cam suggestion
- What plugs for my trick flow heads
- Pratt & Whitney
- Need help with IC
- Turbo maxed out. few math questions about injectors
- Need help tuning, i think
- cam for a turbo?
- Thermal coating - tell me about it
- Compression Ratio???
- Am I lifting my heads? More drama with the T/A!
- How do I go into "suck side" of blower
- Thinking about FI for the LT1
- Head studs or bolts?
- Everything is starting to fall in place
- My flex coupling imploded
- Modification to FLX 220 fans for fitment?
- Heads/cam + STS
- What TC for procharged 383.
- Boost controller?
- And the build continues (small update)
- Help picking Cam????
- bigger turbo than PT88?
- whos running solid mounts?
- Absolute best heads money can buy????
- good info on water injection
- vigilante torque converter 3800k+ w/ SC
- how much diff will twin logs flow over tubular headers?
- critique my cam!
- Procharger for V6 3.8 Camaro?
- 95z28_m6's Turbo build
- Dyno #'s:Bolt-on; cam; s-trim LT1
- Some last minute decisions to make
- Where the hell is everyone getting there pistons from?
- LTX turbo cam for big power, non street car!
- Got the TV75 in place
- Is an intercooler really necessary?
- Turbo Tuning
- Any interest in 3rg gen fbody kits?
- ok high power opti cars come in please. what ignition box?
- 8 rib horsepower capabilities.
- Jeezus - What kind of turbos are these?!
- Where did you get your t76 gts?
- LS1 Powerdyne Supercharger
- Can I make 1000 horsepower with an F1A
- Need opinion on cam
- Hey guys, need some info on a couple turbos
- FI with KB118030-8, -22.00cc pistons?
- PT88 dyno (900+hp)
- inexpensive BOV
- Just a smidge over 9.0 CR... Should I worry?
- lt4 vs lt1 block for fi
- Advice for 383 supercharged build.
- Need some advice for a buddy. stroker supercharged LT1
- Paging "mzgp5x"
