View Full Version : Forced Induction
- going used
- Got my heads flowed got some ?'s
- Going turbo
- LT1 Edit - Tuning a 383 Stroker with 7.5lbs of boost
- Anybody have a demon and procharger or
- Concerns..Need help. 120k 3.8L 96 Maro....Can it handle boost?
- Turbo cam.
- Dissapointed in centrifugally s/c cars
- lightweight flywheel and clutch needed..recommendations?
- Does a SC need backpressure to create boost?
- 396 T-trim boost
- Fuel Pump advice please
- finally pics of engine. updated web site
- Powerdyne vs vortech sq
- how much for twin intercoolers from ATI??
- thinking of installing a supercharger on my second gen with LT1 .. questions within
- Got the turbo car on the dyno today!
- Are the D1-SC or F1 blowers quieter than p600b's?
- Need p/n and some info:
- 93 octane gas.. how much power and boost?
- Got my car back today, S-Trim idle question
- ATI P600B w/ 2 core FMIC for sale
- How hard to open combustion chamber?
- Turbo + spray? Anyone with experience?
- What do you think of this setup, will it work?
- Please help me out, need a part quick
- If anyone is considering fabbing their own turbo >> inside
- Powerflex, semi-solid 4 inch intake
- ATI question
- Intercooler needed
- Car is smoking white through the exhaust
- Anyone need some 42lb. injectors
- Twin turbo ls1 pics :) been busy in the garage :)
- ATI Carb Supercharger Question
- LT1, upgrade MAP when supercharging?
- Procharger fit under 2nd. gen. hood?
- SBC Carb. Vortech
- Fuel Rails?
- Stock Heads - Best Compression Ratio for Supercharging
- Where to find..
- What can I expect and can I spray too?
- How long have you been running 8psi or more on stock internals??
- everyone's opinion
- Interesting location for IC on WS6/Zstyle hood
- My WS6 is a dog! I need a supercharger BAD!
- Twin Leafblowers.
- Hows the 224/236 XE on 114 for driveability???
- does anyone ever have any luck with superchargers
- How much HP with turbo???
- What should I expect?
- Whats your trap speed????........
- "Injuneer" > Will BTM timing retard show on Scanmaster?
- Polishing the elbow
- T-trim boost quicker?
- Griffin radiators for high RWHP LT1's...
- John Deere tractor tuning
- Turbo chevy sites??????
- Blow and go, or righteous with nitrous?
- Equation for calculating boost after a pulley swap.
- How much power with an ATI P1SC 4-5lb kit?
- Need Help! Custom solid intake tube for vortech?
- What is needed to get 8-9 psi out of a S-trim
- Blown, smoggable 383 build
- Polish the inside of the intake???
- Need Help Installing Supercharger
- Supercharger specials
- 7" Vortech crank pulley for sale?
- Is a compression Ratio of 7.8 to low.
- Need help
- Oil pan: Canton, Stefs, or ???
- Seriously considering supercharger
- Pro Turbo Kit Progress
- 500rw w/ stock heads?
- Anyone using Evans NPG+ Coolant?
- Problems installing Crane HI 6R
- What oil are people using for SC
- What A/R are you turbo guys running
- Cam motion phone number
- How am I gonna expell the heat from under hood?
- How hard to rebuild Powerdyne headunit?
- stock ls1 block with a blower???
- few questions on requirements for bottom end on superchared motor
- Strange Cooling problem (Please Read)
- Tubing came apart, need to relocate MAF
- Is my car running too cold
- Plugs for a blown 383 with Nitrous
- plug gaps "blowing" closed?
- Purchase ATI oil seal?
- Ignition upgrades
- My thoughts on Nitrous vs Supercharger
- need turbo pics, please
- Hot cam any good for car with these mods...?
- Double Key
- Wastegate line broke off
- Procharger guys > Restictor in air line going to FMU?
- Test n' tune on twins (video)
- Will vortech sell the impeller alone for a S-trim?
- 350 / 355 / 383 / 396 / others ... who has which ?
- 350 / 355 / 383 / 396 who has which ?
- Electronic Supercharger, What exactly is it?
- Which blower to buy?
- Where to buy a cheap t-trim
- My CMotorsports heads flowed....
- Intercooler?
- Front-mount i/c nerf bar
- Destroyed supercharger impeller blades
- Ring gaps with blowers
- compression ratio with ATI?
- FS: Forged Rotating Assembly
- Should I put a one way valve on the PCV?
- Max Boost & RPM on a T Trim
- Are super chargers street legal?
- Water/Alky injection questions
- anyone running 6'' rods on their blown application?
- FYI: Procharger F1 v. F1R fitment on a 4th gen
- Any Vortech T or YS Trimmed Stroker Cars For Sale?
- Took my turbo 383 out for it's first run, have some questions
- Electric Turbo???
- Turbo Vette vid
- Pictures of front mount on camaro
- Clutch advice pease
- supercharger intake
- 11/1 383 with 5psi supercharger?
- What's so bad about this turbo setup?
- Boost Pulley Sizes
- Beat a ticket with a Turbo?
- Where to get bypass valve?
- Dangerous installing an LT4 Knock Sensor on Procharged LT1?
- Pics of supercharged LS1?
- 5.85 rod and blower pistons
- piston coating
- Whats the best twin turbo kit to use on a stock 2002 Z28?
- Engine mods for a Procharger on my 383
- supercharged 383 with nitrous
- Powerdyne belt adjustment
- Low boost from ATI > Now low fuel pressure > Please Help!
- Fun night at the dyno lastnight! Great results!
- Updated Single Turbo LT1 dyno numbers.
- Dual walbro question
- Boost pump,Acceleronics, and stock PCM ?
- Turbo or Supercharger for the 99 3.8?
- Upgrade engine for a supercharger?
- altitude make a difference?
- 414 LS1/Vortech/NX
- Spraying nitrous onto air/air intercooler
- in reguards to o2 sensors
- Turbos rock!!! (had to tell someone!)
- STS Turbo Kit Pics..... Uploaded!
- new cam specs.....what do you think?
- suggestions needed for vacumn lines or hoses silicone? braided?
- Need Feedback: blower/cam setup!
- Grand Prix GTP w/ pulley, 100 shot and slicks
- Question about SPEC vs McCloud engag
- Ati Cog Belt Question?
- STS Turbo Kit Pictures
- ati procharger twin intercooler pricing
- how much FI power can a tpis tpi manifold support?
- Rebuild questions
- Does anyone?
- new guy on the block
- FOR SALE: Turbo cam
- Getting close to release of the LT1 kit
- in reguards to a 383 stroker with p600b blower
- Blower Piston swap for Hypers...
- MSD boxes
- Whats the best supercharger (price)
- Need blower pistons ASAP
- Roots style blower?
- Previous post about SPEC and McLeod
- anyone have the part # for the idler pulley for 8# p600b on a 96 TA
- STS LT1 Turbo Kit
- Kid running 7lbs in unmodded TA!
- flange warpage
- De-Screened MAF with Boost?
- 8 rib-vs-12 rib question
- 145! :)
- Cool product for those of us with multiple and/or large a$$ fuel pumps...
- 396 T or 396 TT? Which would net more power?
- Twin Turbo LT1
- 396 guys inside
- Y/S-trim head unit
- Whats your EGT?
- How much HP per # of boost
- SLP Intake Runners & Poor Performance
- Q: What do you do after many thousands of dollars end up in a toasted motor?
- Cog Pics
- which valve covers for shaft rockers
- anyone ever get the PTK kit installed?
- Street twin + 8lbs = What flywheel?
- T guys w/ WS6 hood and blower
- Damper and ATI
- Digital boost gauge coming soon!
- Supercharger sale - 1 week only!!!
- How well does the LS1 respond to s/c?
- Is this safe compression for boost?
- other impedence converters
- NOOO oil pump faliure
- Need Advice
- 42# or 55#?
- Custom Turbo kit, check it out!!!
- ? Flow #'s On LT1 heads
- Maximum Boost ROCKS!!!
- Maybe you can help me on this.
- RSKrause: please advise on compression ratio: 8.3 or 9.5
- BOV and MAF placement
- Turbo placement at the rear????
- Head Gaskets for 9 lbs. of Boost
- FPR to replace FMU?
- Cheap source for..
- Whats the advantage of a charger over nitrous?
- vortech'd 383 LT4 freshly built, bad sputtering
- URGENT...do you have to have an air/fuel gauge
- More Power
- A/F ratio ?
- forged 10.4-1 383 + 9lb blower...can it be done...safely?
- Bearing Going Out?
- Which rear gear ratio?
- Walbro Install
- Gotta question for superfueler users
- I have a YS-Trim Vortech, Problems with Plumbing
- Who runs a FMIC?
- Vortech YS-trim LS-1 dyno'd
- Intercooler Kit
- Boost Motor
- K&N filter for sale
- Fuel injector adv. for D1 TPI
- how do u make the sound of blow off valve on turbo louder?
- how much boost can a stock lt1 handle?
- Kinda of a stupid ? (Vortech aftercooler capacity)
- What size pulleys for 6psi??? Vortech S-trim
- PCMforless Rocks!!...And Maf relocation pics inside!
- Need vacuum in crankcase!
- 60-1 Turbo - What size exhaust A/R?
- What kind of oil should I use... blown, summer car...
- Hood louvers?
- Tuning a blower motor
- Valve lash adjustment and Timing questions
- Holley Pro-Jection + Procharger?
- what do you guys think? 406smblk forced?
- vortech belt length
- Need BTM Installation Instructions
- What kind of ignition systems are you guys runing with 9psi+
- Aeromotive fuel pump? Or Weldon? Or?
- 5% off superchargers until 5/27!
- *drools*......this is just plain sick
- weird problem
- post your 0-60, and 1/4 times
- Anyone need turbo headers for your LT1?
- Pulleing up the S-trim.. what would be the gain.. or losses???
