View Full Version : Forced Induction
- Bumper Support
- Overspeeding Vortech blowers safe?
- Stock LT1 with ATI Procharger P600B and inline fuel pump.
- Post your Water/Alky Injection pics/installs
- longtubes vs shorty's
- 3800 S/c Bov
- New type of intercooler
- blowers vs. turbos...why are more and more people switching to/going the turbo route?
- IC after S/C?
- Piston rings for a supercharger?
- Anyone familiar with Pro Turbo Kits?
- In-depth cam discussion for FI - valve timing events
- STS Turbo to be CARB approved
- Help on choosing pulley size and reading/dealing with a compressor map...
- stock compression
- S-trim to T-trim upgrade?
- Intercooler
- Got a little smoke from under the hood...
- stock fuel pressure regulator
- How much does stroking really help in FI???
- Vortech Intall Instructions???/
- Supercharge,Turbo or niether?
- 60-1 questions
- PTK or Turbo Tech??
- Help me decide on one of these cams for my turbo car
- solid intake for lt1 vortech
- Has anyone attempted to put a whipple truck kit on a f body?
- vortech ?
- Problem starting and with idle after adding Procharger
- tial wastegate help.
- Popping when letting off gas!
- Dyno results from new exhaust.
- chalenging someone to design lt1 turbo kit.
- At what boost level are 6" rods going to be too long?
- Help on readying car for supercharged 383
- Turbo guys here... Oil out exuast? STS?
- Info on Innovative GT80-R trim??
- Considering using an LT1 block for my turbo build. Have questions.
- Pro-Turbo Kits... questions
- $2850 fair for D1SC ?
- What makes an S/C whine?
- S tirm Vortec on LS1
- ATI D1SC Twin-Intercooled setup possibly for sale
- turbo build up
- Choosing wastegate spring with variable boost controller
- vortech with no FMU
- Approximate HP numbers w/ ATI D1SC setup up
- Hellfire rings?
- Crate Engines
- Innovatives camaro vid
- Oil pressure going down under boost
- 8.6:1 OR 9.2:1 CR??? on a blown 355
- Who do you recomend for a custom solid roller turbo cam?
- does intercooling keep away detonation beter than mynthaol/water or are they equal
- Has anyone encountered this????
- damn you turbonetics...
- for those worried about piping length on an STS turbo
- Suggestions for a mild boost 383 lt1 buildup...
- RACE PREPS 330CFMs heads vs T-trim over S-trim
- spark plugs
- Starting problem with 84lb/hr injectors
- Stock LT1 Heads
- Comp Cams recomended me to this cam
- Interesting concept on oil return
- Anyone runing a Vortech elbow or trick flow
- intercooled eaton M112 setup concept.. Version 1.0
- cc306 on a 114 lobe
- Rod length & stroke on a turbocharged engine (question)
- Slp Mass Air And Maybe A Throttle Body Is It Worth It.....
- Twin or single turbo?
- Just an Idea
- Turbo on e-bay for $30!!!
- cog set up for d1sc
- Somebody finally grew a set of balls with an LT1 F-body!!!
- Suggestions on bearing and rings for a blown motor
- Only Making 8-9lbs Of Boost On A 2.75 Pulley....
- Keyed crankpulley
- vortech lt1kit
- Compression question
- Pro Turbo Kits
- Can I use any boost on a 10.4:1 CR forged bottom end?
- crane Hi-6TR Timing Retard Controller help
- times with a Vortech?
- 6psi intercooled and full timing?
- ati procharger 3rd genners step inside please :)
- Anyone with ATI/ASP cog set up w/in
- Weiand 177/142 blower questions
- Stupid Question
- Pulley size p1sc
- vortec SQ VS ati SC
- cause of broken crank keyway?
- Remote Turbo Mounting
- Fuel Pump Question
- $2,500 Fair price for PS1c twin i/c????
- Vortech Exchange Program
- Turbo 1 5/8" vs. 1 3/4" primaries
- anyone run a 3"y pipe and mufflex 4" cat back for 500rwhp+
- Max Intercooler CFM
- Could I run a 4.5 psi Powedyne with my mods?
- Stock LS1 potential with turbo + n2o
- LT1 Turbo setup! Is this for real???
- paxton opinions and advice needed
- ATI Procharger belt sizes
- Paxton Supercharger
- Supercharger tune ?
- Serious turbo FMU/SAFC questions
- Front oil seal leak, what's the secret??
- Clutch for Supercharged motor?
- 16 Gauge 1 5/8" Mild Steel U's or 90°
- What do you think of this kit??
- Parts of a Turbo
- Roots Type Question
- STS turbo kits?
- FI or NA for street car?
- Boost-a-pump question
- oil pump or smaller feed line for turbo?
- sts on tpi
- Procharger D3-M head unit for sale
- Internal Wastegate
- restrictors in the oil feed line needed??
- LS1 ignition on LT1
- Rebuild question
- Used supercharger...things to look out for when buying one.
- compression and boost
- How much power are you guys making?
- SD Concepts Tensioner Pics
- need a blower cam for LT1
- anyone using 30 SVO?
- Ginea Pig for Muffex hard intake
- Motor break in with procharger?
- Fuel Question
- What's up with our engines?
- Anyone using a GN intercooler
- Whats going on
- cheap way to make good induction?
- Stealth Ram or Modified LT1 intake for Turbo set-up?
- Vacum set up with a Weiand 144 CID???
- exhaust system advice???
- has anyone supercharged a 3.8L?
- Oil Leak on Vortech - Blower guys help!!!
- monoblade porting
- New to supercharging
- Aggiez28's dyno video
- Best place to purchase an ATI Procharger?
- Paxton; are the horror stories true?
- Is a Switched Supercharger Possible?
- need a better maf for turbo? other costs
- Intimd8 Rich Krause: Maxing out the S-trim on pump gas
- FI or NA?? anyone ever been in this situation??
- Install New Throttle Body
- vortech aftercooler on ati d1sc
- Cold Weather...FI Guys gotta Luv it!
- what happens if the oil oulet is level or slightly lower than oil pan??
- Vortech Aftercooler...???
- LS1 Vortech
- Bro Needs to sell his Vortech LT1 Kit-$2300
- Finished up photos of latest thirdgen single turbo car
- boost gauge
- turbo headers for 3rd gen sbc
- paxton head change
- Turbo Questions
- LT1 Edit or Tunercat?
- opinions on scat's rotating assembly, look inside
- Buying a used SC?
- Turbo headers for gen I sbc? Specifically a 3rd gen?
- New ATI part numbers for the LT1
- ATI's new complete kit for the LS1
- Hey vortech guys - pulley sizes!!
- Cubic inches for a turbo setup
- to the dyno, james
- Who’s rear mount turbo setup is this? *video*
- LT1/4 intake restriction(hogan)
- Broke my new 383!!!
- Safe to run 5PSI of boost?
- sts turbo lt1
- Any thoughts on sheetmetal intake for FI cars?
- Heads have to come off for repair, port or not port while at it?
- 94-97 vortech s/c with a/c on ebay $850!
- 383 exhaust resonating ?
- MAF Relocation help
- INTAKE recommedation
- roots style blower on ls-1 T/A ???
- roots type blower on f-body???
- Supercharged Riviera with minimal mods makes almost 400 lbs flywheel torque
- getting past 6psi
- Can someone explain to me why porting heads is good for turbo setup??
- Rear mount Turbo
- Turbo size
- Forced Induction And Intake Port Volume Q..
- The crank pulley comes off.
- First WOT blasts with new cam...
- need help with twin turbo pressure ratio on dyno program!
- how to connect exhaust outlet to this turbo, pic inside
- Traction Control / D1SC
- boost gauge
- Autolite 104 gapped at 42.
- 50# injectors w/ ATI D1SC OBDII 2 OBDI
- STS Turbo LS1 Dyno
- STS LS1 Dyno #'s
- Turbo, SuperCharger, or Heads & Cam ???
- good site w/ blower engines?
- 12.72 quarter mile at 112 mph.
- 8 inch 10 rib setup for a Vortech???
- Help! Ati seals bad, again
- Suggested injector size w/ P1SC
- $$ required for turbo project
- HP #s with ATI D1SC
- Boost on a BBC
- making an intercooler
- Air Filter
- NGK TR6 spark plug gap with ATI procharger
- What size belt for a T-trim 7"x 2.65"??
- sts ls1 dynoed today
- New Turbo LT1 track results.
- forced induction help please
- twin turbo?
- mass air meter
- makeing no boost
- some pictures of my setup so far
- Dilemna
- where to buy brad brand tubes ???
- Thoughts on Iridium Plugs
- Whats the Most HP NE 1 has made w Stock heads
- Couple Questions About Using Nitrous for Cooling Effect
- ATL 3 core specs???
- Where can I get a keyed hub?!
- Best SC (Procharger) setup for 383 LT1
- Would 3.73's mess my traction up totally?
- A little help
- Realistically, how reliable are turbos on LS1s?
- stock heads
- 224/236 cam and brakes?
- intercoolers twin or single 3core
- need a F.A.S.T. tune for my twin turbo setup
- building 12 sec street
- Are MSD 50#'s really that bad?
- lt1 vortech guys, I need pics
- 454 Power handling capabilities
- about how many miles will a supercharger last?
- STS Rear mount turbo oil pump.
- I think I found a LT1 to rebuild for FI, but I have some questions.
- Got my new 383/AFR/T-trim/aftercooler running
- ATI Procharger K&N Filter location
- o-ringing the heads
- supercharged
- turbo, 1.6 intake/1.5 exhaust Rockers
- 355 questions
- Boost Calculatiosn Figuring out how much hp 14psi
- Fabbing headers... what gauge tubing?
- 2 Bar Map + stock pcm - seems to work fine
