PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Is there a particular power level at which...
  2. Twins for 383 Impala
  3. Boost Roll Call... if you've got it, come on in!
  4. Best street suspension
  5. fuel system for blown 355
  6. Want to switch from my SC to turbo.. Torque concerns..
  7. Are 3 set screws enough to hold balancer hub on crank?
  8. STS Performance...
  9. Chug
  10. Base STS or supercharger to ls1?
  11. Another half baked FI idea
  12. Max. Rated HP of a Turbo
  13. Blower Cam
  14. Worth it to put an STS on 80,000 mile lt1?
  15. What happens when you put a STS kit on H/C
  16. STS Turbo Kit
  17. Dropping in some FI
  18. Need some fab ideas??
  19. question about injectors
  20. 15psi D-1 pulley
  21. 383 Parts list?
  22. car wont start, stays on w/ help, loud, white smoke, a/f gauge pinned on rich
  23. What intake gaskets are you lt1 guys using.. what you torque to?
  24. Bypass Valve Orientation
  25. Best Place to Mount a Versafueler
  26. Forged rotating assembly for FI
  27. 52mm or 58mm TB with boost/NOS question...
  28. Who do you think will win?
  29. compression vs. squish area in FI
  30. Tuners in 4 courners region NM/AZ/UT/CO
  31. Updates on the Turbo Install
  32. Crankcase pressure problems
  33. which pistons for blown LT1 + 58cc heads
  34. intake hose colapses under wot on ati w/ twin i/cooler
  35. X trim ?
  36. LT1 reliability with F.I
  37. heres the cobra head intake PN...
  38. Big block snout crank
  39. Dyno results inside.
  40. 255LPH fuel pump cheap from summit.....
  41. Trickflow Heads (Advertised versus my flow numbers)
  42. Do I need a fuel cell?
  43. How fast, or who is the fast on BFG DR
  44. Cant decide which to choose.
  45. supercharging a 91 Z-28 (5.7)
  46. 2 bar map tunes on LT1.
  47. PTK LT1 car at the track with PTE-88
  48. paxton supercharger
  49. 383/396 short block?
  50. Trust a local shop to fab up a turbo sytem?
  51. is this intercooler ok or crap??
  52. Rebuild after SC/Turbo
  53. Why spend money on heads???
  54. CC 224/236 as a turbo cam?
  55. ptk install with canton oil pan
  56. cheaper tubing for turbo...
  57. JE Pistons 138103 lighweight pistons and boost?
  58. Max boost on forged 10.6:1 w/ pump gas? Even worth it?
  59. Vortech V9 G-Trim Question
  60. 9# bottom end?
  61. Power curve question
  62. fi wear and tear
  63. cheap forced induction for stock LT1...
  64. mufflex where???
  65. Will a 94-96 vette supercharger work with 95 Firebird?
  66. Tough Turbo'ed 383 Buildup
  67. Boost Control Problem
  68. Max boost on stock LT1
  69. Nitrile hose and boost?
  70. building a blower motor
  71. Another Turbo Question
  72. Need to find this size hose?
  73. Aftercooler pump timer
  74. Bought me a Procharger...a few questions for you guys
  75. pointers on id'ing an installed cam?
  76. ATI BIG HUB & Vortech crank pulley (HELP)
  77. Any guesses for you FI guys???
  78. People that have made hard intake piping for ATI blowers can you post pics?
  79. 14psi Reliable
  80. Vortech T-trim
  81. Opinions please on turbo setup
  82. Where's the boost??
  83. P1SC to D1SC price for upgrade/refit new parts?
  84. SuperCharger installed... Fueling question
  85. Turbo vs Supercharger ?
  86. World Street Race Videos
  87. Replacement Diverter Valve
  88. MAF post blower pics please...
  89. New Era Performance is now carrying STS Turbo Systems !!!!
  90. Where to get 2 or 3 bar MAP Sensor
  91. lucas injectors good??
  92. A way to reduce boost without pulley change?
  93. Afr 227
  94. best thickness copper gasket with o-rings?
  95. Ditching the FMU
  96. Turbocharger or Supercharger?
  97. How often does the vortech BOV?
  98. STS truck nets 669rwhp/744rwtq @ 9.5psi!!!
  99. 98-02 Z-28 Turbo Kits, Where?
  100. Root Bolwer for hypered LT1
  101. lower gears OR lower stall
  102. Will 4th gen LT1 kit work on 3rd gen?
  103. DFI What do you think??
  104. Congrats Brady McNew & Crew
  105. Turbo Basics and misc info
  106. Where to find silicone 90* elbow, 2.75" to 3"?
  107. Paging: Rich Krause
  108. Is a D1SC capable of making 700 rwhp.
  109. help my supercharged lt1 PLEASE!!!
  110. supercharger to turbo conversion how hard is it?
  111. Fuel Injector Question
  112. MAF questions
  113. Ever since supercharger, car revs to 1700 every startup.
  114. Weird Idea
  115. Aftercooler and HP?
  116. what do you guys tink i'll Dyno this weekend?
  117. fuel rail and lines ?'s
  118. Quick MAF/supercharger question please...
  119. new delteq, still misfiring, any pointers?
  120. Basic questions about homemade turbo kit (non fbody)
  121. boost
  122. tunning for boost
  123. Turbo on my V6
  124. Wet Vs. Dry Nitrous kit
  125. Tuning. What would you do?
  126. Iac
  127. wanting to charge a 96 rs
  128. srp or je (what's the difference)
  129. HP limit for 42# injectors
  130. Turbo Question
  131. 3800 Series II + Turbo
  132. bad cam for boost?
  133. Procharging My Gta
  134. oil weights?
  135. junk yard twins?
  136. Setting up th ebottom end properly for boost
  137. TT setup on LS1
  138. What do people think of the cobra head
  139. Anybody want to check out a couple logs I did???
  140. Power falling off at 5500rpms
  141. subaru t-30 (off wrx) on a lt1?
  142. Opinions on running blower+nitrous
  143. Scan tool needs
  144. Base tune
  145. Race gas & timing
  146. just a quick hello
  147. Boost VS. timing
  148. Rear mount HX35 heat issue?
  149. Brents 11.23 sts GTO video****
  150. Bracket Fabrication complete
  151. Vortech Supercharger System
  152. Opinions on different the brands of manual boost controllers....
  153. Felpro head gaskets?
  154. Rod Bolts.. 2000 or L-19
  155. Fuel pump booster location
  156. Silicone TB Connector
  157. turbo cool down time vs. supercharger cool down??
  158. which used turbo to get?
  159. Good or Bad
  160. Check this out please. DONT LAUGH
  161. Lifting the heads
  162. whats best for my car? SC
  163. paxtone supercharger question
  164. Turbo, what do you think?
  165. 3.8 Camaro Rk Sport Supercharger
  166. Studded Mains
  167. Supra's never cease to amaze me. . .
  168. 355 or 383 for TC
  169. Weldon 2025/83lb injectors
  170. Hey, where are those sts track times?
  171. Looking for a Vortech supercharger? Important info inside!
  172. pistons
  173. gauges
  174. hooking up gauges? Boost & A/F
  175. whos running Gen & with FI...
  176. Turbo TA may have to go....
  177. Custom pressure side & suck side piping
  178. how long do they last?
  179. who all makes turbo kits for lt1s?
  180. Vortec Supercharger
  181. selling my twin turbo kit for $1000
  182. build my bottom end for 800rwhp
  183. twin turbo intercooler options?
  184. Custom Vortech t-trim setup w/front mount
  185. Aftercooler guys.... I need a good water pump
  186. for a 355lt1/ptkII....gt42-76..or pt76
  187. How will this cam do?
  188. Has anyone run a T74GTS? any input?
  189. what stall is everybody running
  190. New MP T70 with .96 turbine housing
  191. YSi owners
  192. Which s/c to get..
  193. where can i get an intercooler fora 93TA to support 900+hp?
  194. inline fuel pump, myth or truth??
  195. Walbro 255lph intank + Walbro 255lph inline
  196. Ati Twin Intercooler Kit For Sale
  197. Anyone heard of Mperacingfab??
  198. LT4 crank with good rods pistons.. safe FI HP level?
  199. Mounting the Versafueler
  200. bottom end build prices?
  201. ATI inline pump specs?
  202. Powerdyne cold air intake?
  203. What is a GT67 turbo?
  204. Blown 383 owners with FMIC Inside Please!!!!
  205. sts instructions i need a copy
  206. LT1 FMIC, what kind to get, running piping to it, etc.
  207. Can i run a SC with this set up?
  208. larger throotle body = less boost???
  209. Cog belt question?
  210. 1.5 or leave the 1.6 rocker arms
  211. Some info.....
  212. STS with long tubes?
  213. Sts kit without upgrading the turbo can I reach.....
  214. Big cube smallblock
  215. tossing belts like no tomorrow:(
  216. Crankcase vacuum pump
  217. The High lift 224/236 Ex cam
  218. My half baked FI idea (not electric supercharger)
  219. Paxton Supercharger FOR SALE
  220. 4'' mandrel bends...with less then 6'' radius...where?
  221. ? for 650-750rwhp owners
  222. Backwards Boost?
  223. Weiand 6-71 sbc Blower in a 4th gen.. Has it been done before????
  224. Guys with vortechs... Question please....
  225. STS in Georgia
  226. Who is sping there eng to 6500+rpm
  227. Velocity Ring?
  228. Sts Kit On A Stock Lt1 Engine
  229. THIS twin turbo!?
  230. 3.8L Cartuning Turbo around the corner
  231. ET calculator
  232. What to do with vac. acessories?
  233. STS turbos - how much interest?
  234. ZZ9 w/4.5PSI?
  235. lost my saved liniks: need 3/8 or 1/2 MS flanges and 1-3/4 pipe links
  236. lt4 hotcam with induction?
  237. Ok...tell me what you think 'bout this
  238. 4/7 cam swap
  239. Charging an LT1 (what do I need?)
  240. Cam's
  241. pulleys
  242. Greddy T88 34D.. thoughts on this unit?
  243. Phamspeed Turbo Kit
  244. Part #
  245. Cog setup???
  246. Let the games begin! Turbo vs. supercharger test.
  247. AFR Heads
  248. Part# for ATI Big Hub ???
  249. PTK Hot Parts
  250. How much Boost can I hold?
