View Full Version : Forced Induction
- Difference in size of housing with Diff A/R?
- Pro-M Maf
- Brad Brand intake pipe?
- Whats the max boost one should run with the vortech race bypass valve?
- Bypass valve before or after intercooler?
- Does anyone know if a racetronix single hp system with...?
- S/C Help!
- I need a turbo Kit
- Is MSD BTM still needed?
- Gas Mileage with Supercharger?
- boost on an LT1
- spark plug gap & high rpm detanation?
- 4.17 Vs 4.25 puley D1SC
- Reading compressor maps???
- Suggestions, ATI p1sc Must Have's
- Vortech Mondo Bypass Valve
- T-70 Turbo Guys (or Girls)
- sts vs. prochager
- Are stronger springs needed for running 20psi?
- PTK= Excellent Customer Service
- is 37mm BOV adequate for T-Trim @ 16 PSI
- Spark Plug Q
- how much fuel psi should i be running?
- Anybody got a 7" crank pulley layiong around?
- snapped an 8rib
- Anyone have/know where there is, a manual for a paxta-map???
- check this car out
- digital 6 and S/C
- procharger p600b
- Bigger injectors -- reprogram my computer???
- Different sts kit for 93?
- turbo's
- powerdyne vs custom rear mounted turbo
- Anyone know what this turbo is to?
- Ebay t70 turbos?? Will it work for me?
- F1r
- Thinking about selling the Bad Boy 398 LT1 ~ 1200+RWHP
- Header Flanges
- guaging interest:sts turbo set-up
- wow, I never knew blowers sucked so bad
- Supercharger
- Cometic Gaskets
- Performance parts to pimp out ride?
- A-pillar removal
- Went to the dyno and got these results
- Turbo buildup progress pics...
- oil return/feed?
- Hey guys; please defend our website against a few trolls!!!!!
- Update pix
- In reality how much power can you make with APR head bolts before lifting heads?
- Turbo cam question...
- Backfire issue- what is it?
- procharger head unit noise
- Powerdyne question
- Happy Memorial Day.
- 52cc heads what should i do for shortblock
- car idling low at times, stalls with clutch in
- Does the Delteq deliver more spark than a Crane?
- How thick are Fel-pro 1074
- Blow off valves
- LT1 Bumper cutout??
- Anyone need intercooler parts??
- what for power are you's making with a 224/236
- forced induction total packages?
- Alkycontrol in, BUT need a new washer tank
- good experience with a powerdyne?
- Who says sts cars cant be quick???
- Meth Injection w/ 2 core I/C
- Fuel pressure
- T-trim vs D1
- powerdyne
- Will I blow?
- which is better for my 86 iroc with tpi
- Radiator relocation for turbo car
- Procharger manual
- Compression Ratio Q's and a Couple others
- Jl Turbo.com Recommended
- ATI superchargers on sale!
- Boost and Fuel Pressure guage install
- Boosted stock motor check in
- 383 or 355?
- Stenod performance Twin 60 Build-up...UPDATE!!
- Procharger Rebuild
- spark plugs
- Need some HELP & IDEAS
- I need help choosing parts to finish my project. (also tunning for a 93)
- need help identifying a turbo STS KIT
- Horsepower estimate
- First passes with the new 396, need some advice
- stock blower question-3.8 blower on 3.4 engine?
- power limit of an ported lt4 intake
- Need timing maps....
- Will this work? 3.8 to 5.7?
- Future boosted LT1 here!!!
- Problem with blower pulley
- Couple questions.
- STS KIT-- How much rwhp should this combo make
- RPM limit of ATI P-600B
- Blown .LT1_edit file.
- Partial block fill?
- How to tell if my supercharger is good
- valance air inlet
- install turbo for 2000 V6 camaro
- pics of a ATI pisc twin IC kit on a LT1 please
- What does the PCV system do under boost?
- No FMU???
- gen 1 blower on lt1
- Mass air flow and superchargers.
- pics of my fuel system in progress
- P1sc or p600b or D-1
- Anyone running A/C with their blown 383?
- Greddy Profec B S2 Electronic Boost Control Settings...
- Need some Help witht he Alky kit
- New Times W/Turbo Setup
- 355 or 383 for supercharger?
- Cam motion Blower Cam
- Pic Request
- T-Bolt clamps
- spark plug gap
- What is that largest crank pulley
- LT's with sts?
- How many miles/long have you had your FI on your LS1
- Vortech Supercharger parts
- D-1 and D1SC pulley the same?
- 69 camaro turbo setup pics!
- Building a stout shortblock???
- Is a 1.05 ex A/R ok for my setup??
- How much boost 396 Powerdyne BD-11
- Rear mount turbo dyno results are in
- 355/~500hp=how much?
- Planning a turbo stroker need help
- Opti install
- Bypass valve
- LE2 with an ati procharger??
- ati procharger stickers.?
- Compressor overspeed???
- LM-1: Digital Air/Fuel Ratio Meter ???
- Removing T-rex inline pump??
- New to Forced Induction, got a few questions?
- My preliminary head flow numbers (feedback requested)
- New best
- Breathers or catch cans
- 1 cat or 2
- Tracks Results w/ STS Turbo Kit.
- turbo oil line
- What plugs should I run?
- Rebuilding my engine. ? on CR without turbo...
- p600b on the way out, anyone use f-1c or know where to get it?
- UPDATE Pic's
- STS Turbo on LT4 Conversion w/ Hotcam ??
- Can the MSD Boost Timing master be used as ...
- STS GTO at it again...
- LT1 questions
- STS + ATI + Twin ICs = ???
- which way is better to lower compression?
- Some Pic's of versafueler install & Alky install
- Whats legal in CA?
- Procharger install help
- Water injection tuning
- Roots blower help - All FI guys inside!
- Traditional s/c cam's
- Limits of the Stock TB
- LT1 ATI Cog Kit For Sale With Pics
- For anyone with a supercharger setup
- Pictures of my twin turbo buildup
- STS kit for sale
- Detonation on 1 and 2 cylinders
- Turbo, Supercharger, Or Nitrous
- Keep supercharger or go turbo?
- Finished aftercooler box
- What is a electric supercharger
- After over 20k supercharged miles I did a compression test...
- Turbo kit for v6 camaro
- Possible sts kit for sale
- i want a 800 rwhp turbo setup
- the suggestion from combination motorsports...
- i need help with intake gasket part #s for AFR 210s
- msd 6 btm hook up
- What does it take to run 10's
- Alright what does the STS turbo sound like like on a car?
- One year left...
- Water Injection and Nitromethane
- A/F tuning
- Questions on running a dual walbro system
- Ideal Piston reccomendations?
- Aerospace V-style flanges and clamps?
- Sts Turbo
- ati or vortech
- STS dyno sheets please
- Opinion on Hot parts turbo flange
- procharger F/S LT1 p600b
- 90° Fitting obstruct nitrous flow?
- Turbo W/AFR heads Plugs ?
- Alky/Meth install pics
- Oil return on PTK and Phamspeed kits
- how much boost with 9.2 to 1 compression?
- Track today
- what would my compression be?
- LT1 World record Broken again
- Turbo C4 Vette progress 4-24-04
- Selling Vortech V2 kit w/Aftercooler for 1993-97 LT-1
- a1000 mounting...where is yours?
- ATI price increase coming soon!
- Made a few dyno pulls...
- WTF??? Disappointing track times.
- Heads for 1000+ hp turbo
- Why do blowers tend to make so much less power than turbos
- 89 supra turbo on 94 z28?????
- i still have pressure in the crankcase... cant figure it out
- Scrap + wirewelder = aftercooler tank
- diffuser in TB elbow, any difference?
- What head bolts with 12-15#
- What header gaskets for FI?
- Anyone heard of, or used these?
- intercooler for sale!!
- blower question
- Elbows on Ebay
- What you guys think about this kit?
- my price estimate/plan on bottem end
- people that had/have blowers on stock bottom ends
- Purchasing procharger pulleys
- Stock 10 bolt survives another pounding! New best as well!
- Quick question about fuel upgrade on sts kit
- sc/turbo/hc at the same hp level how do they feel??
- power steering and alternator relocation without using stock acc. bracket???
- more single turbo C4 vette progress..
- STS VS. Supercharger.........???
- All members who drivin or has a sts turbo kit on there late model
- External oiler for P600 B ?
- Which cam?
- detonation issues with procharger
- forced industion on carbed?
- Engine Managment System?
- in need of a stock 10 bolt rear end
- Should I procharge or Head/Cam
- sts kit on stock lt1 engine with hot cam -- HELP
- Anyone running a XE 224/236 cam in CA?
- p600b p1sc questions
- a1000 pump questions?? doesnt add up
- 3.8 turbo kit
- STS System Incomplete???
- procharger install tips
- ?'s on heads for FI setup
- Mufflex GP!
- Its a Vette, but figured I'd share... T74GTS
- Lt1 PTK Gen 2 progress....
- Will the SDCE tensioner setup>>
- Oil cooler on vortech? worth it?
