"Back" button on browswer inop at times
Sometimes when I go to a specific post, get through reading it and want to go back to the board I came from, it won't do it. It happens alot, I am on AOL, this is the only site that happens on. Do I need to change something on my end??, Browser setting or something? Happens most when I am on a specific post and there is a link on it to somewhere else and I go to look at it. I can get back to where the link was on the post bot not back to say LT1 Tech. I have to get of the site and then back on. Whats up??
David
David
Sounds like a browser issue having a problem with the site for some reason. I have no idea what setting it would be (if any).
Sorry, no clue.
Jason Debler - Webmaster/Editor
CamaroZ28.Com * TurboBuick.Com * ChasingStanley.Com
1996 Camaro SS #259 - Project 396 in the works
Sorry, no clue.
When your in a post, in the upper right part of the screen it says "The CamaroZ28.Com Bulletin Board" below that the forum your in for example "LT1 Tech" and below that the post your in...
Why not just click on where it says "LT1 Tech" or whatever forum, and go back that way...
Should work
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
Should work
- Almost Alive: ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
- Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Jesel Shaft Mount Rockers,
- Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
10-31-2016 11:09 AM
