Manual Valvebodies and Lockup converters?
Old Mar 26, 2003 | 05:48 PM
SMOKNZ's Avatar
Once you go to a Manual Valvebody on a 4L60E or a 4l80E is the lock up feature gone? Is it possible to still utilize it with a switch for say highway use? I understand it would not be an automatic feature anymore. Thanks
Bill
Old Mar 26, 2003 | 08:03 PM
sb427f-car's Avatar
Bah...get a lenco, lol
Old Mar 26, 2003 | 08:18 PM
SMOKNZ's Avatar
If i wanted an answer like that i would have posted in LT1 Tech.
I helped a friend replace the lockup solenoid in his 4L60E, because if you don't remove it when you take the front pump out you break it. I don't remember if the solenoid was part of the valvebody or not. Would it still function via a switch with a manual valvebody. I know there is a auto tranny guru around
Bill
Old Mar 26, 2003 | 08:48 PM
OneFlyn95z28's Avatar
I am not sure. only kit I know of is the TransGo -3 kit. This is the same kit Art Carr is selling for it.
It all depends on how it is setup. if it is set up right you should be able to keep lock up
Then again it is a POS Trans Go kit
Old May 26, 2003 | 12:44 PM
David94TA's Avatar
I just installed a 4L80E in my car and it has a manual valvebody and lock up torque converter. I even put a switch in so that I could activate the lock up feature manually.
james007moore
Jan 1, 2016 01:14 PM
timmy39120
May 8, 2015 11:41 AM
sberry3827
Apr 9, 2015 04:27 PM
