Butchered Exhaust
Old Mar 25, 2003 | 04:05 PM
camarocruzin's Avatar
Butchered Exhaust
I was trying to save my stock cat until i could save up enough $ fior a high flow one. I already got the headers and y-pipe and was about to order my hooker cat back when i noticed it looked like it bolted to the cat. I noticed that my cat was welded to the I-pipe on my car though...when i bought the car it had a newer exhaust from the cat-back. I'm guessing some lazy mechanic just chopped the old exhaust off and welded this cheap POS one on.I have a pick of what i see under the car, but no clue how to post it on this board.(if someone could show me how id be glad to) can i save this cat, or do i have to replace it in order to bolt up my new exhaust?
Thanks
Josh
Old Mar 25, 2003 | 09:43 PM
Tobe2wild's Avatar
Gaskets are nearly impossible to find to seal the cats. So its either you cut the flange off and weld it for a leak free exhaust or you attempt to use the rusty old flange and wad it with silicone for a leaky a$$ exhaust. Your choice.
Old Mar 27, 2003 | 05:50 PM
Marc 85Z28's Avatar
That's the way exhaust goes man
You have a couple of options:
1. Get a direct-fit cat for your car.
2. Have an exhaust shop install the catback. They will need to cut the flange off the I-pipe and weld it to the converter. Common stuff...
As far as posting pics:
Assuming you already have them on your computer, you need to find someone to host them (a place to store them on the internet). Your Internet Service Provider should already allow you to do this. Once you find a place to put them, click on the UB Code link in the Forum Rules box located near your reply box.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
