N20 plug gaps and timing on stock
Old Mar 16, 2003 | 07:05 PM
Shark Chaser's Avatar
Exclamation HELP N20 plug gaps and timing on stock
Hi guys Ive got a 95 basically stock except for a programed computer and flowmaster muffler, Ive just installed a Nitous Works system and set it @ 125, please give me some instruction on what to do next( Plug gap, Timing etc... ) Thanks,Rich
Old Mar 16, 2003 | 10:44 PM
stik6shift98's Avatar
gap em at .040
and i think u will need to retard the timing a bit
Old Mar 17, 2003 | 11:34 AM
sniffin94's Avatar
yep gap at 40, If it is a wet kit I wiuld not retard the timing
Old Mar 17, 2003 | 01:22 PM
It is a wet kit! ,And thanks guys !
Old Mar 17, 2003 | 02:45 PM
95greendragon's Avatar
Timing should be fine I run 125 stock timing pump and ngk tr55's. Just don't hit the rev limiter and get a fuel pressure safety switch.
Let her rip and prepare for 12's!
Old Mar 17, 2003 | 03:40 PM
sniffin94's Avatar
do not get ngk tr55 spark plugs, green dragon gave you the wrong number. Go with NGKTR64177's
Old Mar 17, 2003 | 03:46 PM
There's nothing wrong with running the tr55's I check them weekly and run nitrous (125 shot) quite often and have never seen a plug look less than new. I think either set would work just fine for anything less than 150 shot. It's all about keeping detonation down, if you run into det. It doesn't matter what plugs you are using the cylinders that are detonating are not going to have ground straps.
Old Mar 17, 2003 | 08:21 PM
for nitrous your best bet is ngk tr6......
Old Mar 17, 2003 | 08:39 PM
12's ?? Damn do U think ? I cant wait , so there's nothin else I need to know ? Thanks guys I'll let U know how I do !
Old Mar 17, 2003 | 08:42 PM
sweeyt
jst remember ngk tr6 gapped at .040
Old Mar 18, 2003 | 07:12 AM
I run 12.80's everything stock but LCA's on street tires.
Old Mar 18, 2003 | 09:20 AM
ngk tr6 gapped at .040 got it, I,m strappin in the bottle tonight and I'll be squeezin' it on fri night thanks for all your help,,C-ya!
HectorM52
Jul 30, 2017 11:46 AM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
