what is wrong with my car?? need advice..
Old Mar 14, 2003 | 12:00 AM
rollin in a camaro's Avatar
ok well my catilac converter is messed up i think. my car sounds a little funny, and it is virbating in the catilac conv. area in my car when it idles. i feel a lose in horse power, and a rattle comes from my car every so often. if it is my catilac conv. how much will it run me to replace it and install it?
Old Mar 14, 2003 | 12:14 AM
94GrayV6's Avatar
You can get a hi-flow Catco from summit for around 60 bucks i think, or you could gut the stock one. Either way it's easy, you shouldnt need to pay someone to do it.
Old Mar 14, 2003 | 01:21 PM
kahouna23's Avatar
even if you do end up having someone put it on for you, it shouldn't be more than $100......if that. Definately is the cat though. If it ever stops rattling, don't think the problem fixed itself. The honeycomb inside the cat probably just got lodged somehow with the exhaust flow. The problem is still there and you need to get it replaced ASAP before that honeycomb makes it's way to your muffler. Then you'll need a new muffler as well. Depending on emissions regulations where you live...I would recommend a high-flo cat like 94GrayV6 said. Otherwise you're looking at close to $600 for a Y pipe. GM doesn't sell just the catalytic converter seperately. You have to purchase pretty much the entire Y pipe assy. Call around and see if I'm kidding......I've already done it and decided to say "screw emissions" I'm getting a High-flo.. Depending whether you still have a warranty, it'll be covered if you do. Take advantage if you can.
Good luck
Old Mar 14, 2003 | 02:46 PM
All_InTheRED's Avatar
Get a hi-flo and be done with it
Why would u want to put a stock one back on and pay that much I dunno.
Plus there is that little performance increase you'll get.
Old Mar 14, 2003 | 03:49 PM
ImportKILLER's Avatar
Since you're in Cali, hope you never have to visit a Test-Only smog center if you add on a hi-flo.
Old Mar 14, 2003 | 07:12 PM
A test-only is no different than any other smog shop here in Calif.
And the "Catalyst Visual Inspection" is just that......"is the cat there or is it gone"
So him having a Hi-Flo wont hurt a thing.
Old Mar 15, 2003 | 11:52 AM
would a MAGNAFLOW HI-flow S.S. cat. converter 3inlet/outlet fit on my 95 camaro 3.4?
ModdedNerd
Dec 18, 2014 10:52 PM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
JoeD316
Aug 16, 2002 09:12 AM
