Bottle heater important???
Old Mar 13, 2003 | 10:09 PM
Alvin@pcmforless.com's Avatar
I just got the 100 jets in and the car is still popping and spitting black smoke at wide open.
Someone mentioned to me that a heater is critical to get the right psi.. He says with temps like they are now i'm lucky to see 600psi which would be a good cause of this extreme rich condition!
any advise?
Old Mar 13, 2003 | 10:49 PM
drop top steve's Avatar
You need a pressure gauge to moniter pressure and it should be in the 900-1000 psi range. If lower you well be rich. A bottle warmer like the NX unit well keep the pressure in the desired range.
GPZ406's Avatar
Bottle pressure is critical for proper/consistent operation,usually 900-1000 psi. Too low and the nitrous/fuel mix will not be right,system will run rich. Heating the bottle will raise pressure. I would get a heater and a nitrous gauge also if you don`t have one.Ditch the platinum plugs,every manufacturer does not recommend them.
Looks like drop top posted while I was typing What he said!
Old Mar 13, 2003 | 11:07 PM
oh i did, changed my jets to 100hp shot and put in some autolite 103's at a 40 gap.
It seems to do a little better, i'm going to try to locate a good nos gauge... any ideas for a good remote gauge?
Old Mar 14, 2003 | 01:04 AM
stik6shift98's Avatar
low psi wont cause popping low psi can cause almost nothing.....i had it before...and yes u need a bottle heater until it gets to summer when u will prob need a purge
for a gauge i would recommend autometer and mount it in a pod
Old Mar 14, 2003 | 10:31 AM
95greendragon's Avatar
Low psi WILL NOT cause popping. Popping is usually caused by a lean condition or bad plugs have you checked them?
Old Mar 14, 2003 | 11:08 AM
plugs are brand new, car is just really really rich...
Quickss96
Jan 29, 2016 05:56 PM
Bxlt1
Sep 17, 2015 08:31 AM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
RX Speed Works
Jul 24, 2015 02:25 PM
