purge kit install?????
Old Mar 13, 2003 | 09:37 AM
qwick_trip's Avatar
i boughta used NOS purge kit from a guy. i am hooking it up to a NOS dry kit. i need to know what all i need to hook it up (i not sure if i got everything) and directions on how to install it? this is my first n2o kit so i get lost easy sorry.
Old Mar 13, 2003 | 10:05 AM
sniffin94's Avatar
the only things that are really necessary are the solenoid and the wires with a switch. You don't need steel braided line. All I did was connect the purge to the nitrous solenoid, run a peice of copper tube off the purge and wire it. hope that helps
Old Mar 13, 2003 | 06:57 PM
qwick_trip's Avatar
don't you need a threaded adapter that the purge kit adapts???
Old Mar 13, 2003 | 07:53 PM
sniffin94's Avatar
Yep all that is , is a male to male adapter put some thread sealer on it. I took my nitrous solenoid off the bracket and screwed the purge on before I wired it
LeftoverChinese
Jan 14, 2024 03:03 PM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
