Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
will this cam pas smog check??
Old Mar 9, 2003 | 04:04 PM
TMDZ28's Avatar
Comp Cams Xtreme Energy 224/230 Cam .536"/.544" Lift
Comp Cams Pro Magnum 1.6 Rocker Arms, Self Aligning
CM612 Valve Springs
CM126 Chromoly Retainers
CM007 7 Degree Hardened Locks
Description: Our most popular cam, and for good reason. This cam makes great power everywhere, but really shines in the midrange and top end. Makes excellent power with stock or ported heads. Not too wild for the street, but not as mild as the 218.
RPM Range: 2800-6400
there's a good deal on this cam until the 12 th of march. i need to know wheter this cam will pass or not...thanks guys.....
Old Mar 11, 2003 | 06:58 PM
TimChiaretto's Avatar
That cam might be difficult to get past a smog check. What is the LSA? If it is up around 114 degrees you might be able to run a special program and get it to pass but I wouldn't bet on it.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
