Turbo gaskets?
Old Mar 6, 2003 | 01:30 AM
BigDaddy's Avatar
Turbo gaskets?
I've been looking for a gasket for the turbine outlet of my 60-1HiFi turbo, and can't find anyone that sells them. Do you think I can make one out of copper? I've got some lying around.
Old Mar 6, 2003 | 02:14 AM
89ProchargedROC's Avatar
do you mean where your downpipe attaches?
If so...no need for a gasket. Ultra Red silicone is your friend
Old Mar 6, 2003 | 09:06 AM
BigDaddy's Avatar
yes, that's exactly what I meant. Thanks for the info.
Old Mar 6, 2003 | 11:19 AM
No problem....the ultra red or copper works good. Just put on enough so that when you tighten down the bolts it oozes out a little. Then start it up, you'll have some leaks at first but usually after running for a bit it'll harden up from the carbon and you'll be good
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
