Speedo swap questions
Old Mar 5, 2003 | 10:29 PM
lil305gta's Avatar
If I swap in the 140mph speedo, what will I need to do. Will the mph/rpm be slightly off. I have the electronic speedo. Any help is appreciated. Thanks!
Old Mar 5, 2003 | 10:39 PM
CODY BEHNKE's Avatar
Are you switching the complete gauge assembly or just the speedo?
If you are switching the whole thing I belive it should read correctly, since the VSS is sending the same signal to both.
Old Mar 5, 2003 | 10:51 PM
lil305gta's Avatar
Thanks for the fast response. I am switching the entire thing. Now with the higher rpm reading will my car be safe to rev in that range?
Old Mar 6, 2003 | 12:00 PM
Jim85IROC's Avatar
Do you really think your tach has anything to do with the capabilities of your motor???????
Old Mar 6, 2003 | 12:19 PM
Marc 85Z28's Avatar
I believe he is talking about the higher indicated redline found on the tach in the new cluster. It's only another 500RPM. And just because you can, doesn't mean you should. Why rev that high if you don't make power there?
Old Mar 6, 2003 | 01:47 PM
Jim85IROC's Avatar
I know exactly what he was asking. He was asking if it's ok to rev it to 5,500 now that the tach is a different color there.
Old Mar 7, 2003 | 02:42 AM
lil305gta's Avatar
I pretty much the limits of my engines rpm range. I am planning on doing spring and 1.6rr swap. Just wanted to make sure everything would be ok if I go into the rpm ranges.
Old Mar 7, 2003 | 07:44 AM
Jim85IROC's Avatar
But do you understand that it has absolutely NOTHING to do with what tach you're using?
As for whether or not it's "safe", yeah, it should be plenty safe. I doubt that you'll float the valves until 6k rpm or so, but you're going to be completely out of power long before then, so revving it that high before you shift is going to slow you down.
Old Mar 7, 2003 | 08:01 AM
lil305gta's Avatar
Cool, thanks for the advice.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
blac94Z
Feb 10, 2015 11:02 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
