93-97 LT1 F-Body Vortech v1 COMPLETE kit
Old 03-29-2017, 03:47 PM
OutKast's Avatar
SOLD:93-97 LT1 F-Body Vortech v1 COMPLETE kit
Price for EVERYTHING listed is $3000
Price for the supercharger kit alone is $2500
I have a complete Vortech v1 s-trim polished finish supercharger kit for 93-97 LT1 F-Bodies. You won't find a more complete kit. This kit has been boxed and kept inside since about 2003.
Kit includes the supercharger, all mounting brackets, bolts, belts, 2 pulleys for high or low boost (7# & 15#, I believe), FMU, bypass valve, oil line, oil pan with drain fitting installed, all inlet and outlet tubes, full instruction/installation manual, modified coolant line assembly with fittings, and pcv hose. I even have the t-rex fuel pump that came in the kit but I don't think I would trust it. Will throw it in though.
Vortech also included a Crane Fireball HI-6r ignition box in this kit that I am including.
I also have a blower cam (trying to get specs for it) that was spec'd by Ed Wright, as well as the 1994 computer that is tuned (by Ed Wright) for the entire 355ci combo, the 24# svo injectors that it's tuned for, and a pillar pod with boost and fuel pressure gauges.
I personally installed the kit on a car that I am rebuilding but the direction of that car has changed and is going back to stock to be sold. I was able to install and run the complete kit.
It's a v1, so it's loud as expected due to the straight cut gears. There are no pieces or parts missing from the kit and no play in the impeller shaft.
Price for EVERYTHING listed is $3000 OBO
Price for the supercharger kit alone is $2500 OBO
Shipping is not included in the prices.
Trades may be considered for aftermarket heads.
OutKast is offline
Old 05-20-2017, 12:44 AM
skyman44's Avatar
Re: 93-97 LT1 F-Body Vortech v1 COMPLETE kit
I'm looking for the mounting bracket that the tensioner pulley is mounted to. I'm sure you're not interested in selling just that piece. Is there any way you could send me the dimensions of that bracket?
skyman44 is offline
Old 05-21-2017, 12:20 PM
OutKast's Avatar
This kit was sold. Sorry man but I won't be able to get the measurements for you.
OutKast is offline
Old 06-09-2017, 11:39 AM
sleeperZ96BT's Avatar
What did it sell for, if you don't mind me asking?
sleeperZ96BT is offline
Old 06-14-2017, 02:47 PM
OutKast's Avatar
It went for $2700 for everything I had.
OutKast is offline
Old 06-15-2017, 01:01 PM
Thanks so much!
Old 06-22-2017, 07:36 PM
blown94's Avatar
Not bad for what you were selling. I just stole a T-trim kit with hardly any miles on it for $1500. No ignition box or fuel pump or injectors or cam, but I already got all that. Nice complete setup you had though. Killer deal for sure. These kits are getting harder to find. I now have 2. S-TRIM makes a nice daily driver, but too small for a 3800lb car when you compare it to today's super cars
blown94 is offline
