Lt1 runs, then wont start back up!
Old 01-30-2017, 09:23 PM
Midnight_Z's Avatar
Fresh top end rebuild, Solomon tune. Start car up runs and idles great, shut car off after running for 1 min. Then try to start it up again and it just turns over but doesn't start. Has good fuel pressure. Go to start it up the next day and it fires right back up! What could be causing this? Optispark wouldnt do this would it? Its a brand new skip white opti with the original Mitsubishi sensor installed from my stock opti.
Also i do not have my radiator or waterpump hooked up, could the pcm be sensing this and not letting the car start back up do to lack of all of the sensors hooked up?
Midnight_Z is offline
Old 01-30-2017, 10:50 PM
Re: Lt1 runs, then wont start back up!
Year of vehicle?
Have you scanned it for codes?
Coolant temp sensor not connected might possibly contribute to the problem...
Injuneer is offline
Old 02-15-2017, 09:22 PM
Midnight_Z's Avatar
Must have been the coolant sensor on the wp not being hooked up. Once i got that hooked up, radiator, and ewp it runs great and starts right back up. Makes sense, if the pcm isnt getting a coolant reading it should cut spark. Ohh and no codes.
Old 02-16-2017, 11:16 AM
No it doesn't cut spark, per the factory manual. If you were driving down the road, and the coolant temp sensor failed, or the connector fell off, and the engine stopped, it would be a bit dangerous. If the coolant temp sensor fails, the PCM turns on both fans, and if it's an auto trans car, TCC will apply early.
Just a coincidence. The PCM does look at the CLT sensor to see how rich to set the cold start mixture, but with a code set, it defaults to programmed settings. If the engine warmed up a bit, and the PCM was still using a very rich mixture, might delay starting.
Injuneer is offline
Old 02-21-2017, 12:03 PM
Midnight_Z's Avatar
Makes sense. So i started my car today as its just about ready to hit the road. And it started right up but now refuses to idle lol. Idles slightly rough at 1500-2500rpm but the minute i let off the gas and try to let it idle at 900-1k it just stalls.
Now a week ago it ran perfect in the garage for 15min, got up to temp fans turned on and everything was great. And it idled great, maybe a very slight hint of surge up and down a hundred rpm but not really noticeable.
Only thing that has changed since that 15min warm up is...........i put the k&n air filter on after spraying it lightly with the k&n oil the night before. And i added thermo paste behind my ICM for good heat transfer. This problem is very annoying!
Old 02-21-2017, 03:14 PM
gaedbo's Avatar
Just a thought, did you double check all the fits on everything when you put the K&N back on. If you removed the connection of the elbow from the throttle body and didn't get it back on for a good seal (I always check mine with a mirror) you may have a leak there, or have a vacuum line disconnected or loose.
Sounds like just rechecking what you touched or moved may be the answer.
gaedbo is offline
Old 02-22-2017, 08:48 AM
Midnight_Z's Avatar
Good advice! I rechecked my intake elbow and i squished it towards the bottom for a nice vacuum leak! Hopefully this fixes the issue! Thanks guys.
Old 07-18-2020, 12:44 PM
bizness88's Avatar
I am debating the skip white opti... how long did yours last for?
bizness88 is offline
