New Aluminum Radiator for 1993 - 1998 V8 F-Body
Hello,
I was going to use this for my Lt1/T56 swap into the RX7 but it is about a half inch too wide to fit between the frame rails. It is new/never used, but I did cut the clips off the front (a/c condenser side) because I didn't need them. I used a cut-off wheel, but saved them and they could be tig welded back on if needed. It is a 2-row with 1 inch core tubes. It has provisions for auto trans cooling and sensor bung. It has some slight scuffs and scratches from handling. Does not come with a radiator cap.
It is supposed to be direct fit for 1993-1998 v8 f-bodies, and should work with little to no modification in 1999-2002 (think it's a little "thicker" than the stockers for those years).
I'd like to get $50 plus actual shipping cost to your door. I'll get some box measurements and will provide estimates based on your zip code via the UPS cost estimator calculator.
This radiator appears heavy duty and was rated to provide 50% better cooling over a stock radiator. I'll get some pics up once the thread is approved.
If interested, shoot me an email too as sometimes notifications from this website get snagged in my spam folder. jeremyferguson4444(at)yahoo.com
Thanks,
jeremy
Thanks,
jeremy
Re: New Aluminum Radiator for 1993 - 1998 V8 F-Body
Is that a bung for a sensor, or the drain petcock? Thanks for the heads up! I was trying to remember where the drain was on my '97 and I thought it was on the driver side, but noticed this one has it on the passenger side.
I also completed two shipping quotes. 1 from Detroit to PA ($37) and 1 to MO ($54)...... It's a pretty good size box, so it's not cheap to ship. 35 x 25 x 9 (20lbs) is what I used for the estimator.
