1997 z28 30th anniversary will not move while in gear
Old 01-23-2017, 08:57 AM
shaynebaca's Avatar
Exclamation 1997 z28 30th anniversary will not move while in gear
Easy to explain, crank up ...put in 1st or any other gear...step on gas...revs up and no movement. I am thinking something came loose etc
Thanks
shaynebaca is offline
Old 01-24-2017, 08:37 AM
Re: 1997 z28 30th anniversary will not move while in gear
Usually not a lot of tech help here in the "Lounge"..... I'll move this to the "Drivetrain" forum for you.
Assuming it's a 4L60E, have you scanned the PCM for transmission codes? Most of them don't turn on the SES light.
Does the shift lever have any resistance? Did you check the cable?
Injuneer is offline
