396 LT1 short block, Tick Level II T56, Headers, Clutch, etc
Old 07-26-2016, 09:38 AM
fergymoto's Avatar
Thumbs up 396 LT1 short block, Tick Level II T56, Headers, Clutch, etc
Brand new 396" LT1 short block. A lot of money went into this and this is your chance to buy a really kick *** LT1 for a great deal.
Specifications:
-Seasoned GM LT1 block:
-Hot tanked
-Howards billet splayed main caps and ARP main studs installed
-Align honed
-Bored to 4.030"
-Torque plate honed
-Stroker clearanced
-Square & zero decked
-Rotating assembly balanced
-Eagle 3.875 stroke 4340 forged crankshaft, internal balance
-Eagle 5.850 H beam rods, bushed with floating pins
-CP Pistons custom piston set with CP wrist pins and spiral locks, 9cc dish with valve reliefs
-Total seal plasma moly file fit ring set
-Durabond CHP performance camshaft bearings
-Clevite H series main bearings
-Clevite H series rod bearings
-Clevite brass freeze plug set
-Professionally assembled
With a 54cc cylinder head and .039 head gasket, the compression ratio would come out to around 12.3:1.
For compression ratio purposes:
Bore: 4.030"
Stroke: 3.875"
Piston to deck: Zero
Piston valve relief/dish: 9cc
Short block comes exactly as pictured. It is just a short block. Cost to duplicate $5,700.
$3,500
fergymoto is offline
Old 07-26-2016, 09:40 AM
fergymoto's Avatar
Re: 396 LT1 short block, Tick Level II T56, Headers, Clutch, etc
-Clutch Masters 600ft/lb clutch with billet steel flywheel 2,000 miles $400
-LT1 bellhousing - glass beaded, looks great $150
-Clutch fork $75
-Six speed pedals $75
Old 07-26-2016, 09:41 AM
fergymoto's Avatar
Pacesetter ceramic coated long tube headers for LT1 F bodies, part number 72C2235. These do have emissions fittings for 94-95 models, but will work on all 93-97 cars if you block off the emissions fittings / delete emissions. Headers are brand new. $350 shipped
MSD Ignition coil for 96-97 LT1 with single connector, brand new, part number 8231 $40 shipped
Hooker Y pipe, brand new, part number 16765HKR. Fits 93-97 LT1 F body with Hooker or Jet Hot long tube headers. Aluminized. $200 shipped
Old 08-16-2016, 08:44 AM
fergymoto's Avatar
Bump it up
Old 09-10-2016, 11:40 AM
87Aerocoupe's Avatar
I'll take the MSD coil for 96-97 LT1 if you still have it, email me at z24.turbo@gmail.com, thanks.
87Aerocoupe is offline
Old 11-02-2016, 08:31 AM
fergymoto's Avatar
To the top
Old 11-12-2016, 08:47 AM
95LT4Z28's Avatar
t56 still for sale?
95LT4Z28 is offline
Old 11-13-2016, 07:56 PM
fergymoto's Avatar
The T56 was sold. Sorry
Old 11-20-2016, 12:56 AM
Still have the MSD coil?
Old 11-21-2016, 08:12 AM
fergymoto's Avatar
Yes I do.
Old 01-17-2017, 07:56 AM
fergymoto's Avatar
To the top
Old 02-09-2017, 09:48 PM
MadMav's Avatar
Still have the LT1 bellhousing?
Thanks,
Maverick
MadMav is offline
Old 04-04-2017, 02:56 AM
RUFFIDLNZ's Avatar
Interested in the clutch fork if you still have it.
RUFFIDLNZ is offline
Catmaigne
07-14-2015 05:17 PM
KamikaZ28
05-28-2015 12:45 AM
willismoons
05-27-2015 04:03 PM
05-08-2015 11:30 AM
BIGCOWL-IMP
09-12-2002 09:18 AM
Quick Reply: 396 LT1 short block, Tick Level II T56, Headers, Clutch, etc
