good brand of sfc
Old Mar 2, 2003 | 02:47 PM
rage366's Avatar
good brand of sfc
well, my motor's done, now i need to worry about suspension.
monique has an stb, eibac springs (1.5), she needs to know what else she needs to stay on the road better...to change lanes at high speeds without much recourse.
since i love her so much, i was considering getting her Double Diamond sfc's, because they connect to the tranny as well, but i'm being told that they arent much better than the edelbroc sfcs.
please advise. and look at my profile to see what monique already has.
thanks a lot
--shokor--
Old Mar 2, 2003 | 02:54 PM
Dr.Mudge's Avatar
I have tubular SFCs from BMR, have nothing to really compare them too, but when I had them I only had an STB and it really made a difference, you dont know the flex you have until you have subframes.
Here is another recent thread
http://web.camaross.com/forums/showt...threadid=84671
If you already have tubular, I'd probably leave them alone and look at something else perhaps upgrade wise...
Old Mar 2, 2003 | 06:49 PM
rage366's Avatar
yeah, they're tubular. how about a panhard? is my stock one alright? as far as the link you gave me, the global west 905's was being promoted. one thing though: does the fact that the DD's connect to the tranny as well help any? i mean, since the most sfcs are two-point connectors. the DD's are 3 point-connectors.
Old Mar 2, 2003 | 07:47 PM
Dr.Mudge's Avatar
Solid rod ended panhard would be nice.
Old Mar 2, 2003 | 08:36 PM
rage366's Avatar
any good specific brand?
thnx
Old Mar 3, 2003 | 06:09 AM
quick's Avatar
I have the triangular SLP SFCs on my car. I haven't had them long, but they are "boxed" steel, weigh 21 lbs each, and hook to the front subframe (duh), the driveshaft loop, and the LCA. They look very strong. I'll let you know more as I go along, but they sure seem more substantial than many other brands.
Old Mar 5, 2003 | 01:01 PM
Z-Attitude's Avatar
I just went for the DMS Tubular
http://web.camaross.com/forums/showt...threadid=89436
Later>>>>>>
Old Mar 6, 2003 | 12:20 AM
Shempy's Avatar
Double Diamonds certainly help tie everything together better, but that doesn't make them best.
If you're drag racing, the extra weight over a 2 point tubular may not be worth it.
If you're building an SCCA eligible autocross car, you can't have the crossbracing of double diamonds.
If you want to have a road racer, then I think you can more easily justify double diamonds.
Would anyone disagree?
Old Mar 6, 2003 | 01:01 AM
Dr.Mudge's Avatar
Weight kills a road raced car even more than drag, drag racers can make up for it with horsepower, you can't do that on a road car (because tires/brakes/handling issues).
I'm happy with tubular, and they are supprisingly light (BMR). Is there a difference and how much? I dont know.
Old Mar 6, 2003 | 08:13 AM
rage366's Avatar
i just want something really good.
if the weight can be justified by the increase in handling, then they're worth it to me. besides, what's 40 lbs when i've already got a 100lb sub in the back.
--shokor--
Old Mar 6, 2003 | 12:32 PM
Ken S's Avatar
I have boxed BMR's.. they do hang slightly down by less than an inch more.. One thing I like about them is I can use it to jack up on.. Lift in the middle and the whole side of the car goes up as one. Or lift on a corner and the three other wheels act accordigly..
If someone was going to build a roadracer, probably would just skip the sfc's and just install a cage....
Old Mar 6, 2003 | 12:49 PM
Dr.Mudge's Avatar
I'd go for both cage and subs if "serious," I was close to getting boxed subframes, almost dont know why I didn't other than the claim of losing ground clearance. I scrape the exaust, dont know that subframes would be that close to the ground on the speed bumps in my area. Once in awhile on road trips though you will come across areas with strange and huge speed bumps.
Old Mar 6, 2003 | 01:29 PM
Lady in Nomex's Avatar
Most folks I know use the Kenny Brown (double diamond) or Global West. I have both, the Global West on my race car (3rd gen) and the KBs on my 4th gen. both are very sturdy. I think road race folks lean towards the GW, they can be jacked up on just about any point, not so much with the KBs.
The GWs are .125 roll bar tubing if I remember right.
Old Mar 6, 2003 | 10:03 PM
rage366's Avatar
i'm not concerned about jackin the car up at every point...as long as it can be jacked up without a big hassle.
as far as the suggestion for the cage, that's gonna happen for a whiiiiiiiile. i appreciate everyone giving me their opinions; for a while, i was suffering from car-junky's block.
--shokor--
Old Mar 7, 2003 | 06:20 PM
speed fiend's Avatar
Since you already have sub frame conn., I don't think it would be worth it to get the KBDDs. As for better handling, sway bars would help there and maybe a torque arm to help get the power down.
