steering wheel replacement......
Old Mar 2, 2003 | 12:15 AM
stik6shift98's Avatar
i have a 98 and it doesnt have radio controls......i can get a 00 which does have em
how do i take it off and stuff.....do i take the whole wheel with ignition and shaft thing????
all help will be appreciated
thanks
Old Mar 2, 2003 | 01:05 AM
Blue89Bird's Avatar
I'm pretty sure you'd have to replace the whole column. The wires run down the column, so I'd check to make sure you have the wires inside first. If you do, then its not to bad, just make sure your radio has the plug for the controls behind it, it may already be plugged in. The airbag will remove with a few screws behind the steering wheel, just make sure you unplug the battery first.
Old Mar 2, 2003 | 03:04 AM
im getting the wheel with the airbag too.....
do i need a sterring wheel puller....
and then will they guy whos selling me the wheel be able to move his wheels some how to move the car around for a bit.....
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
