Lights dont work
Old Feb 28, 2003 | 09:48 PM
neil350's Avatar
Lights dont work
Every thing on the passenger side works fine, it’s the driver side that’s screwed up. I replaced all the sockets and bulbs like you guys told me to do, other than they seem dimmer, they illuminate fine, the turns work, just dimmer, how ever the minute I so much as turn the parking lights on, they blink super super super slow. What gives, also my brake lights on the passenger side don’t work at all. If you just turn the lights on they seem fine, if you turn the turn signals on they work fine, but the minute you brake they don’t work at all. The back up and corner light work perfectly fine and are of normal brightness. The minute the lights come on, so much as the parking lights, the lights blink super slow. Whats causing this, its real annoying. I have replaced all the sockets and bulbs like I was told to and still this crap.
Old Feb 28, 2003 | 11:50 PM
shoebox's Avatar
You might want to check the long connector that is attached on the RH side of the steering column under the dash. That connector has some flex to it and sometimes is not pushed in well all the way across. Just a thought, since you have had your hands on most of the other things. While you have that area opened up, visibly scan/check for any other potential problems.
Old Apr 3, 2006 | 09:09 PM
klpps's Avatar
Re: Lights dont work
i'm having this same problem. what connector do you speek of shoebox? I am having the same problem after taking that piece under the dash off to do some wiring.
liamcg97
Nov 25, 2019 05:55 PM
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
