C/D Numbers for those interested
Old Feb 27, 2003 | 12:58 PM
Joe K. 96 Zeee!!'s Avatar
Post C/D Numbers for those interested
Was curious about how our cars compare....FYI
79 Mustang .49
94 Mustang .34
02 Mustang V6 .33
02 Mustang GT/Cobra .36
69 Camaro .40
88 Camaro IROC .34
93 Camaro .34
99 Camaro .34
92 Vette .33
97 Vette .29
Viper (pre-03) .35
NSX .32
F-bods ain't too shabby in this area.
Old Feb 27, 2003 | 01:02 PM
guess who's Avatar
Re: C/D Numbers for those interested
79 Mustang .49
94 Mustang .34
02 Mustang V6 .33
69 Camaro .40
88 Camaro IROC .34
93 Camaro .34
99 Camaro .34
92 Vette .33
97 Vette .29
Viper (pre-03) .35
NSX .32
Do you know how they get C/D......
Old Feb 27, 2003 | 01:05 PM
guionM's Avatar
What I find noteworthy is that even with that windshield, the 4th gen is no more slippery than the 3rd gen Camaro, or even the taller '94 Mustang with that relatively big grille and very unwedge-like front end !
Also, unless I'm mistaken, the 1983 Trans Am had it's drag below .27 cd, and is one of the most slippery cars ever made. Kind of makes the slick C5 seem brickish.
BTW, that .3 difference in the new V6 & GT Mustang & Cobra is from that relatively useless rear spoiler. Most all tacked on spoilers you see out there rob far more in aerodynamics than the downward force it would create at the speeds it's drivers will ever use.
Old Feb 27, 2003 | 01:12 PM
formula79's Avatar
The underside has alot to do with a car too. The C5 has an almost totally flat underside.
I have trouble beliveing the Mustangs numbers...maybe it's also in the underside.
They had to make the 4th Gen Camaro's slick...with the dog V8's they had they needed every bit of help they could cutting through the air
Old Feb 27, 2003 | 01:17 PM
PacerX's Avatar
While comparing these, please remember that you are only seeing half of the equation.
The other half is frontal area, and the F-car had it in spades over the Mustang in that department - specifically because of that steeply raked windshield and the lower seating position.
Corvettes kick *** in both departments - two thumbs up from the peanut gallery to the C5, the more I learn about the car, the more it amazes me.
Old Feb 27, 2003 | 01:18 PM
guionM's Avatar
Cool
Correct on the C5. Aerodynamics was a top priority (check out how the wheelwell cutouts are smoother at the rear of the arch than the front.
But as far as the Camaro's wedge, that's my point. The wedge-like Camaro isn't any slicker than the old one. Or the SN95 (Mid 30s seem about right for the Stang, but surprising for the Camaro!).
Old Feb 27, 2003 | 01:20 PM
Darth Xed's Avatar
The C5's exceptional C/D was no accident either.
They made a lot of changes just to improve the C/D... if you look behind the rear wheels, there is a faint 'divit' or dip in the body... they found this made a significant difference in aerodynamics.
Also, the C5 was originally to have a character line on the decklid, where it would dip down and carry over the shape of the taillamps... but they found a flat deck lip performed better in the wind tunnell, so they went with the flat edge.
Old Feb 27, 2003 | 01:26 PM
PacerX's Avatar
I know it helped the Cd, but the one appearance complaint I have on the C5 is that godawful coach joint that closes out the *** end. No matter how well it is lined up, it always looks bad.
Old Feb 27, 2003 | 01:42 PM
Found some frontal areas in sq. ft. Not sure if these are completely accurate I'm getting a lot of it from smokemup.com. I saw another site that listed 99 stang at .38.
One thing is for sure. You can't assume C/D just by how a car looks. Heck new vettes look big compared to NSX's but there's a lot more too it. Reading ACOR and I'm seeing how "small" changes can make a difference.
94 Mustang .34 22.5
02 Mustang V6 .33
02 Mustang GT/Cobra .36 22.9
69 Camaro .40
88 Camaro IROC .34
93 Camaro .34 22.0
99 Camaro .34 21.6
92 Vette .33 19.00
97 Vette .29 19.30
Viper (pre-03) .35 20.5
NSX .32 19.2
Old Feb 27, 2003 | 01:51 PM
PacerX's Avatar
K, I redid the chart with the numbers multiplied to give you a real-world comparison on the cars (Cd x FA)
94 Mustang 7.65
02 Mustang GT/Cobra 8.24
93 Camaro 7.48
99 Camaro 7.344
92 Vette 6.27
97 Vette 5.597
Viper (pre-03) 7.175
NSX 6.144
Hats off to the Vette.
Old Feb 27, 2003 | 01:56 PM
Found the following from thise site... http://www.fbody.com/members/pmdbybr...es/History.htm
"In 1982, the Trans Am was restyled. Sadly, the Pontiac V-8 was laid to rest so "more 4 cylinders could be built." At that point, Trans Ams came with the "corporate V-8," the Chevy small block V-8. At this point, the Camaro regained the market it had lost in the '70s. Many buyers saw the two cars to be the same. One highnote was the fact that the Trans Am was chosen to star in the tv series "Knight Rider." Another highnote was that in 1984, the Trans Am became the most aerodynamic GM production vehicle ever with a drag coefficient of 0.29."
That's .29 back in 84! Dang!
Darth Xed's Avatar
Ya, I kind of liked the original character lines for the tailllamps myself...
I guess you need to go one way or the other...
Sometimes, I think that minor functionality / performance issues should be sacrificed for better styling... but it all depends... every case is different.
Old Feb 27, 2003 | 01:58 PM
jg95z28's Avatar
I'm curious to see how the 2nd gens stack up. Anyone have a clue?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Roadie
Feb 16, 2015 10:34 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
