blowing instrument lamp fuse since stereo install
Old Feb 24, 2003 | 07:18 PM
DABE92's Avatar
i keep on blowing my dash lights ever since i installed my head unit...i made a wiring harness from the gm one...i have a jvc headunit....i installed it a while ago..im now getting around to fixing it...but...when i turn the lights on i hear a pop and thats the fuse...
whats making it do this?...yes i installed the headunit correctly...its just keeps blowing out the dash lights...
PLEASE HELP!!!
Thanks!
Old Feb 25, 2003 | 10:26 AM
PaulN64's Avatar
it means that you are probably grounding out somewhere. Check all of your connections again. It's a remote chance, but try another HU and see if it does th same thing. If not, it might be your HU.
Old Feb 25, 2003 | 04:28 PM
x7x7's Avatar
sounds like a short or you connected a wire where you shouldn't have. You may have tapped into your dimmer with the wrong wire or something, double check that you've got the switched 12v on the HU connected to the switched 12v in the car and the constant to the constant. Did you try to hook up other things like a dimmer, or illumination wire?
Old Feb 25, 2003 | 11:08 PM
stik6shift98's Avatar
get a bigger fuse?????
Old Feb 26, 2003 | 03:19 AM
x7x7's Avatar
very bad idea.
Old Feb 26, 2003 | 09:22 AM
it worked for me i got one that was bigger by 5....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattstrike
Mar 11, 2015 07:33 PM
raroz28
Mar 10, 2015 11:18 AM
CaRParts102
Dec 6, 2014 08:45 AM
sc93
Jul 26, 2002 02:02 PM
