Parts List
Old Feb 19, 2003 | 07:15 PM
oldschool's Avatar
Parts List
Well guys...here it is. This is the list of parts that I'd like to find used inorder to keep the cost of repair to a minimum on my WS6.
Pan Hard Rod - Aftermarket
Lower Control Arms - Aftermarket
Rocker Panel- The piece bellow the door.
Rack & Pinoin
Front Disk
Right Side front Suspension pieces
Head Light mount panel - The plastic piece that goes from the right to the left side of the car
Wheels - Incase I don't end up buying the ones I'm planning to right now
Thanks Guys
Andy
PS= Please leave this thread for those people with actual info....not random crap....you guys know who you are
Old Feb 19, 2003 | 07:24 PM
Doc_z28ss's Avatar
I know you said aftermarket pan hard but my stocker is coming out if you want to use it for the time being.....its yours
If not Stealth has great prices thats where i got my new one
Old Feb 19, 2003 | 07:37 PM
NiteRider's Avatar
"Right Side front Suspension pieces"
Can you go into more detail? I'm getting some stuff fixed on my right side to adjust the camber and I ended up getting everything instead of a few parts.
Old Feb 19, 2003 | 08:03 PM
oldschool's Avatar
Lower control arm
Hub?
front brake rotor
steering knuckle/spindle?
They really weren't too sure about exactly what was damaged but anything to do with the steering I wold assume.
Andy
Old Feb 19, 2003 | 08:08 PM
Draco's Avatar
Originally posted by oldschool
Lower control arm
Hub?
front brake rotor
Andy
I know you wanted aftermarket but I have a stock panhard rod and stock LCA's if you need em.
Old Feb 19, 2003 | 08:20 PM
oldschool's Avatar
Thanks guys...I'll give you guys a shout if I stay with stock pan and LCA's
Are there any scrap yards around here that speciallize in F-bodies or GM products? The reason I ask is that the shop that is doing the work is only connected to the yards that ICBC is hooked up to. If you guys have any numbers or names from ANYWHERE, that would be great.
Andy
Old Feb 19, 2003 | 08:27 PM
sleeperZragtop's Avatar
Lower control arm
Hub?
front brake rotor
Andy
I've got some front lower control arms..although Shawn is taking the sleeves out of it...I'm sure you can use your sleeves...
Old Feb 19, 2003 | 08:28 PM
SBainsTA's Avatar
the only one I know of is Langley Discount Parts. He deals in only GM. Ummm... you can bargain with him a little but he knows what things are worth and you'll usually get a good deal, not an awesome deal. I'm at school so I don't have his number
Old Feb 19, 2003 | 08:42 PM
BennyBoy's Avatar
These guys are in Alberta:
http://www.davidt.com/
Old Feb 19, 2003 | 11:43 PM
97TA-WS6-Con's Avatar
Andy
I have Mike's Lower control arms. As Mike says, I'm grabbing the steel sleeves but I'm sure we can get that organized with the current wrecked parts.
In fact if we act FAST I do not mind taking the DAMAGE lower control arm and giving you Mike's. All I need are the sleeves.
I basically have a whole front corner available as well. I have the steering knuckle, rotor and caliper. I also have a deCarbon stock shock if needed.
Now having said that, I THINK the steering knuckle and caliper are at Steve's as I believe I may have left them there. I'll have to look at my crap box.
I MIGHT be able to help on the TA rocker panel cover as well but we will have to talk. It depends how bad your one is.
Old Feb 19, 2003 | 11:57 PM
oldschool's Avatar
THANK YOU GUYS!!!!! You're awsome!
I will take anything you guys will hook me up with. I may have to have the shop pull the car apart more to see EXACTLY what is bent...
I'll be in touch
Andy
Old Feb 20, 2003 | 12:17 AM
NiteRider's Avatar
It'll still cost ya... $$$
Old Feb 20, 2003 | 06:27 AM
blue 79 Z/28's Avatar
Im gonna have to cut into this one! lol langley discount is a competitor to us! lol my uncles and my family run 4 auto wreckers in surrey for domestic late model you need AL'S AUTO WRECKING LTD. # 604-584-5222 12123-103A AVE. surrey heh, bring the business to me! we sell for good deals!
Old Feb 20, 2003 | 05:27 PM
93TAWicked1's Avatar
I have a double adjustable solid sperical bearing Panrod I'd let go for 90.. I may have the right control arm I just tossed the spindles I do have a wheel bearing if you need that
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
