What Kind of Brake Fluid Do YOU Use?
Old Feb 15, 2003 | 11:34 AM
95 Z/28 LT1's Avatar
Super Moderator
What kinds of brake fluid do you recommend?
I have heard the Ford HD stuff is good for street use.
Is there anything that is better that you don't have to change all the time?
Old Feb 15, 2003 | 01:01 PM
Dr.Mudge's Avatar
You dont have to change anything "all the time", unless you get that 800º stuff or something. I use Wilwood, no special reason, its not the best, it was readily available to me and it was decent and I needed it short notice.
Most people are going to change thier fluid around once a year, thats just how it is.
Old Feb 15, 2003 | 02:41 PM
KeithO's Avatar
I use any brand-name DOT4. I autocross and track my car. Should I ever have a problem, I will go to DOT 5.1 or Motul.
Old Feb 15, 2003 | 03:29 PM
chuck's Avatar
I use Motul 5.1. It has yet to fail me. The current batch has been in there for four months, and has three days on the track plus some autox and several thousand street miles. Even though the pedal feels good, I will run a bottle through it before the next track event.
Has anyone tried the GS610 from Pro-speed?
Old Feb 15, 2003 | 08:25 PM
apex's Avatar
I use the ford DOT3 for w2w with great results. Its easy to find and inexpensive.
Old Feb 15, 2003 | 09:58 PM
mitchntx's Avatar
Castrol SRF ...
Sounds outrageous, but I saw it used w/o issue, w/o bleeding, w/o replenishing for over a year in a street car that saw some serious track duty.
I was also having some brake issues and HAD to rule out fluid as an issue ...
Old Feb 15, 2003 | 10:32 PM
Lady in Nomex's Avatar
Motul 600- most racers in the Camaro-Mustang Challenge use this. Reasonably priced and well proven.
Old Feb 15, 2003 | 11:42 PM
WOT's Avatar
WOT
ATE Super Blue. Good dry and wet boiling points for the price which is ~9.95 a liter. If I wanted better I'd probably skip Motul and go straight to SRF. SRF is worth the $70 IMO b/c it can go a lot longer than any other fluid out there. Castrol advertises it as being able to go one year under race conditions-imagine how long it could go in a daily driver.
Old Feb 16, 2003 | 02:14 AM
Lowend's Avatar
EXP
I have tried a few and the Wilwood EXP600 is the best I have found
Old Feb 16, 2003 | 06:08 PM
chrisbarr's Avatar
Without a doubt, Castrol SRF is the best brake fluid-period. I was walking through the pits at the Rolex 24 at Daytona a couple of weeks ago and that is all I saw in the garages.
If you only track a few times a year, then ATE, Ford HD, Motul, Wilwood-they are all good choices. One is not going to greatly outlast the other in terms of durability on the track. Where you run into problems is if you don't change the fluid frequently. It picks up moisture over time and the boiling point drops with it. That is when you will start to boil it. Keep the stuff fresh(say every 2-3 track events or every 6 months) and you will be in good shape.
Old Feb 17, 2003 | 09:37 AM
All_Z_Way's Avatar
I use the Ford HD and I think it works great for street & track use.
Old Feb 17, 2003 | 08:56 PM
Compstall's Avatar
I use Valvoline Synthetic with no issues.
- Brent
Old Feb 18, 2003 | 02:59 PM
Super Moderator
I went to Ford to pick up some brake fluid and they told me that they stopped selling Ford HD fluid in a blue metal can about a year ago. They now offer Ford "High Performance" DOT 3 fluid in a White plastic bottle.
Old Feb 18, 2003 | 03:10 PM
BigRich's Avatar
they put in some good greenish blue racing fluid in mine.
the can had German writing on it.
i think it was for or made by BMW.
Old Feb 18, 2003 | 03:51 PM
WOT's Avatar
WOT
Sounds like ATE from what I've been told they make that fluid for BMW.
