What is IAC and how to adjust TPS
Old Feb 11, 2003 | 07:18 PM
white91z28's Avatar
Question What is IAC and how to adjust TPS
Can anybody tell me What the IAC is and where it is located? Also how can i adjust the TPS?
Old Feb 11, 2003 | 07:26 PM
BlowBye's Avatar
IAC is an Idle Air Control valve. Its located below the throttle body and is basically a solenoid. If engine needs a bit more air, solenoid opens up, if it dosent need air it closes.
A TPS is adjusted by using a Digital Multi Meter. You first must loosen NOT REMOVE 2 bolts holding the TPS. Connect your negative and positive terminal from MULTI Meter to connecter A and B(its engraved on the TPS) read the volts, It should put out .52. If its below or high move it up or down till you read .52. Once its set tighten it back up and you're done. If im wrong in any part someone please let me know.
Old Feb 11, 2003 | 07:31 PM
white91z28's Avatar
Thanks Blowbye
Old Feb 11, 2003 | 08:45 PM
aklim's Avatar
See my post here: http://web.camaross.com/forums/showt...threadid=80099
I believe that the earlier TPS cars were set to 0.54V while the later ones were set to 0.6V. I think it is the pre 87 ones that are set to 0.54 while the post 87 ones are 0.6
Old Feb 11, 2003 | 08:52 PM
white91z28's Avatar
Thanks Aklim
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
