rear end spindel #
Old Feb 11, 2003 | 04:36 AM
oil pan 4's Avatar
rear end spindel #
I am going going to order 2 ring and pinion sets(10-bolt) from summit for my 85' V6 and 85' Iroc and an Eaton posi unit for the Iroc.
I don't have a summit book, so I don't know what set I need. Do I need the 28 spindel or the 30 spindel set?
Old Feb 11, 2003 | 09:38 AM
MRZ28HO's Avatar
Exclamation
Spindles are what your front rotor/hub assemblies are mounted on, the differential doesn't have spindles. Are you asking about Splines? The only splines used were early (1982-~1989) 26-splines, and late (~1989-1992) 28-splines. The only thing in a 3rd gen to have 30-spline was the late (late 1984-1992) auto trans.
It wouldn't matter what spline you have to order a gear set, only if you were ordering a carrier/LSD unit. Best way to find out is to pull the axles, someone could have already swapped them out. It is a common thing.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
