Doing a C5 brake Conversion, Have a few Questions.
Old Feb 9, 2003 | 08:03 PM
95 Z/28 LT1's Avatar
Super Moderator
I am planning on upgrading to C5 brakes pretty soon and I am going to make an order from GM for some parts. I want to save as much money as I can while doing this, so I have a couple of questions about parts and whether I should spend the extra money on the GM stuff or just go down to Autozone.
First off is the rotors. The price is pretty similar between Autozone and GM at about $50 each, but I have to pay shipping if I buy w/GM. Are the GM rotors any better than the Autozone ones, or are they basically the same thing?
Next on the list is the pads. GM offers a few different pads and Autozone does as well. On GM's list are the Durastops@$50, Durastop Ceramic@$71, Hawk HP+Pads@$95, or the Z06 Pads@$89. Autozone on the other hand has two decent pads, Performance Friction Pad @$50, or Performance Friction Z-Rated Pad@$107, and lastly, "Albany Pads@$35.
I have the Napa Ceramix pads on the front of my Camaro now, and I haven't been very impressed with them so far. As for the Z rated pads, (that I currently have on the back), I only get them hot enough to work on the street about half the time, so those are probably out too. What pad would you recommend out of the remaining ones for the best all around pad? What pad would you get personally?
Any other advice on parts from you guys would be really helpfull. Thanks in advance.
Old Feb 9, 2003 | 11:21 PM
LPEdave's Avatar
If it were me, I'd get the Autozone rotors and the PF Street (non-Z) pads. The pads should have a lifetime warranty on them (wear out? get new ones free!).
Dave
Old Feb 10, 2003 | 02:42 PM
Super Moderator
Another question of mine is, do all C5 brake parts interchange?
BTW, thanks, I will be going with the Autozone rotors and PF Street Pads.
Old Feb 10, 2003 | 03:23 PM
All_Z_Way's Avatar
I would go with the AZ rotors as well, but would probably go with the HP+ pads. They are a little better pad for track use.
Old Feb 10, 2003 | 10:46 PM
WOOS1's Avatar
I purchased my C5 conversion parts from Team Chevrolet and the shipping was free.
Old Feb 10, 2003 | 11:01 PM
drop top steve's Avatar
Keep an eye on e-bay, I got a complete set, front and rear, Z06 calipers, rotors, pads and lines for 325, had a 1000 miles on them, like new.
Old Feb 10, 2003 | 11:23 PM
chuck's Avatar
I have had great luck with AutoZone rotors and plan to use them for track rotors for some time.
The calipers are <$90 new from Dal, and your stock lines are fine. I also prefer the OEM GM pads for street use. They are quiet, stop good and don't dust bad.
All C5 calipers are mechanically the same, but the Z06 calipers are red and the base C5 calipers are silver.
Old Feb 11, 2003 | 09:35 AM
Super Moderator
So, stock LT1 lines will hook up to the C5 calipers with no problems? I don't need C5 lines?
Old Feb 11, 2003 | 09:49 AM
Chris 96 WS6's Avatar
1. All C5 brake parts are the same, no difference in years.
2. You MUST get the C5 front brake lines. the LT1 lines are too short and the fitting on the end won't thread into the calipers.
Team Chevrolet is where I got the parts for the complete kit I sold, my cost was $506 shipped for everything. If you already have the adapter brackets from Bob I'd call them. I have their phone # at home but you can email Chris Slack at Chriss@teamchev.com and he can point you in the right direction (he was in parts but has since moved up, but he's who I worked with and he's the guy that got them stocked with C5 parts). I'll try to remember to post their phone # this evening.
Old Feb 11, 2003 | 02:48 PM
RdRacerZ28's Avatar
Where are these $50 C5 rotors you speak of???? I'm not finding them that cheap anywhere. Autozone has some but they are $112. They have soem that are $55 but look horrible and the vanes arent directional. Are these whats you've found?
Old Feb 12, 2003 | 08:09 PM
chuck's Avatar
I got mine at my local AutoZone for $55 each. They are made by AIMCO, and have 3 days on a road course on them so far with Panthers and not a single tiny stress crack. I am going to have to try harder
Part number 55044 right side
Part number 55043 left side
http://www.autozone.com
In the past I have been very hard on rotors. KVR blanks only survived two sessions
On my '01 I did not have to change the lines, though I would like them to be a little longer so I could replace the pads with one bolt like stock.
Old Feb 12, 2003 | 09:03 PM
lateapex's Avatar
Gale at Team Chevrolet sells the GM C5 front rotors for less than $50/ea, plus shipping. 800 658-4017.
Bob Bishop
Old Feb 14, 2003 | 11:38 PM
BobC2's Avatar
Get the Perf Friction Z rated pads. They are lifetime warranty, none of the others are.
BobC
Old Feb 14, 2003 | 11:49 PM
JSK333's Avatar
My PF Street (non-Z) pads from AutoZone have a lifetime warranty. They work great cold and hot, but pretty much are HORRIBLE in the rain.
Old Feb 15, 2003 | 11:29 AM
Super Moderator
I ordered everything yesterday. I ended going up with the GM rotors and the GM Z06 pads.
I had to get either the GM Z06 ones or the GM Durastop Ceramic, because they are the only ones that you can get the springs and shims that I needed.
According to Jason you can't just buy those springs and shims seperate, you have to get them with some pads.
The GM rotors were only ten extra bucks to ship, so I went with those.
Is there anything with the ABS or proportioning that I am going to have to mess with for these to work good?
