Recommendations needed
Old Feb 4, 2003 | 10:04 PM
Central PA Z's Avatar
Well, the parts are in and the block work is done, assembly is in the process. 355cid w/ forged JE pistons, Eagle 6" H beams, stock crank (for now), PP Stage II heads, XE 230 / 242 113lsa, 30# SVO's, Strange 12 bolt, skinnies and fats with a GM rebuilt 4L60E (Running out of $$$$) Anyway..... just wondering how brave I should go with a N2O setup?? I'm thinking NA I should be somewhere around 425hp. A N2O setup is new to me and of course I will have all the safety items in place. I've picked out a kit w/ some extra goodies for around 1200, just wanna know how big of a shot I could work my way up too. Any other advise is appreciated.
~John
Old Feb 5, 2003 | 12:29 AM
GhostZ's Avatar
I don't know if you're going to see 425 at the wheels. What compression are you running?
As long as you have all the goodies to include fuel pump you shouldn't have a problem running upwards of a 200 shot. Since you have forged pistons and H-beams, you shouldn't be too worried and the stock crank is pretty damn tough.
Just make sure all your ducks are in a row as far as timing, race gas for a bigger shot, fuel pump and the safety goodies.
Work your way up and keep an eye on your setup.
Old Feb 5, 2003 | 08:34 AM
RacinLT1's Avatar
Guys are spraying upwards of a 300 shot with a stock crank.
With the parts you have 200 would be good,but the trans wont last. Start off with a 100 and go from there,make sure you have a BIG trans cooler,that will help the trans some.......
Old Feb 5, 2003 | 11:58 AM
COMNBYU's Avatar
yea, the stock crank is pretty strong, as has already been stated. the tranny will be your main problem. to be completely honest, if its a "mostly stock" rebuild, i wouldnt be suprised if it doesnt hold your NA power too long, much less the gas.
if your a betting man (and you have somthing else to drive), id get it really broken in well NA, and then start out with a 100shot.
you really need a race-prepped 60E or a built R4/350/400 to harness all that power.
good luck!
jon
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
LS1 RULZ
Aug 11, 2002 11:15 PM
mjcent922
Jul 27, 2002 12:42 PM
