HEY Someone Please Help?
Old Feb 3, 2003 | 12:32 AM
kev311's Avatar
Angry HEY Someone Please Help?
I have a 97 v6 Camaro. My car got really hot and i got stuck on the side of the road. It will start now but it doesnt sound right and im getting coolant in my oil. Would this just be the head gaskets or is my block possibly cracked? I appreciate any help. Thank you.
Old Feb 3, 2003 | 09:28 AM
Wolfie's Avatar
head gaskets
Old Feb 3, 2003 | 09:52 AM
kev311's Avatar
thanks for the info. i would just like a couple more opinions to be 100% sure. also does anyone know a site with a tutorial for replacing the head gaskets. ive never done it before but i know it will probably be a long task.
Old Feb 3, 2003 | 10:15 AM
MustangEater82's Avatar
It sounds to be a head gasket....
as for a tutoriol, I would jsut go buy a Haynes or Chiltons Manual for your car, maybe even both, they will give you a very detailed description of what to do.
Quick right up is you are going to have to remove, the Thorttle body, upper, intake, lower intake fuel rail aand all injectors, vavle covers, pushrods(they need to go in the same spot you took them out of so have a system to remver how they go back in. take off the exhasut manifolds take of hte cylinder heads, scrap off old gasket, and put everything back on.
I am pretty sure you will have to remove the alternator and probable the bracket too.
good luck expect to spend som serious time doing this especially if you do no know what you are doing.
Old Feb 3, 2003 | 10:29 AM
ImportKILLER's Avatar
Head gasket...
Old Feb 3, 2003 | 12:30 PM
kahouna23's Avatar
I'll second ImportKillers motion.........head gasket.
Old Feb 3, 2003 | 02:38 PM
nikkev's Avatar
Cool
Defiantely a head gasket and it shouldn't be too hard to do yourself.A gasket set is probably around $75 and you can do it in your driveway if you have a few tools.You need a torque wrench though to make sure you get the heads torqued back to spec.Good luck.
Kevin
Old Feb 3, 2003 | 02:52 PM
blue95's Avatar
A haynes or Chilton manual should be the first thing....the biggest thing with this is whether or not you have the right tools for the job and don't mind getting some busted knuckles......this one make take awhile and if you have never done it before its not a bad idea to drag that a friend that has worked on cars to sorta look over your shoulder.
Old Feb 3, 2003 | 03:08 PM
ibanez6rg's Avatar
Watch out, because coolant can freeze up everything that touches oil
Old Feb 3, 2003 | 10:21 PM
kev311's Avatar
thanks to everyone for the input. i should have my car going soon. check out my car at the site on my sig.
Old Feb 6, 2003 | 11:43 AM
1981zzz's Avatar
you should have the heads checked to make sure thy are not worped or cracked
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
alex5366
Jun 14, 2015 10:31 PM
jocamino
Jun 4, 2015 09:33 AM
G-BODYT56
Parts Wanted
May 31, 2015 12:09 PM
mike24
Aug 7, 2002 10:06 PM
