Rear end thumping
Old Jun 17, 2010 | 02:30 AM
A15DollarBurger's Avatar
Rear end thumping
Hi All,
Whenever I go over bumps, there is this thumping sound somewhere around the rear of the car. It also happens sometimes when I get in the car too...
I have been under the car 3 times to check/fix the problem but to no avail. My best guess was the torque arm bolts were loose but I tightened them as hard as I could, same problem and I'm no pro when it comes to suspension.
Is there a specific place I should check? LCAs? Panhard rod? Has anyone else have this problem?
All parts are stock except for the Spohn adj TA. Also has new(ish) rear shocks.
Was thinking of replacing the bolts from the relocation bracket of the TA (scraped it a couple of times with the horrible road conditions here) but wanted to be sure...
Thanks,
Old Jun 17, 2010 | 04:45 AM
jasonface's Avatar
The LCA's and panhard rod both have bushings that can wear out, so yes, check them
Old Jun 17, 2010 | 12:02 PM
n2ceptor's Avatar
Have you check the exhaust system???
Old Jun 17, 2010 | 03:20 PM
firebirdStud's Avatar
something dumb.. but how about the spare tire? mine came loose last year and it drove me nuts figuring out the noise!
Old Jun 18, 2010 | 01:25 PM
Hello,
Thanks for the responses, I will check the bushings of the control arms.
I thought that it might have been the exhaust but the thumping is still heard whenever I jack the car up with the rear end unloaded.
It's not the spare tire because I took it out.
If it is the bushings, I will just replace the entire part... should I get adjustable parts although I don't plan to lower the car?
Thanks,
Old Jul 5, 2010 | 08:55 PM
Update:
I replaced the LCAs, PHB, and rear sway bar, all UMI stuff. When I took off the stock LCA, I heard the same thumping when the rear end moved slightly forward and backwards. After the new parts were in, smame thumping, but less frequent now. I have no idea now what it is.
Any suggestions?
Thanks,
Old Jul 6, 2010 | 02:26 PM
OBE1 95Z28's Avatar
Check the U-joints on your drive shaft as it moves around when you move the rear end.
Old Jul 13, 2010 | 11:16 AM
I will check the u-joints. It does seems that it thumps/clunks less when I accelerate, but it may just be because I can't hear it over the engine. Lol at this point I'm so used to it that I know WHEN it'll thump, but i guess that's better than having random sounds.
Thanks,
Old Jul 13, 2010 | 11:42 AM
RUDEDOG's Avatar
Is the Spohn ADJ TA a chassis mount? If so I had the same thump with mine. I had a Spohn ADJ TA chassis mount with poly bushing. Replaced it with a BMR ADJ trans mount type with poly bushing. Thumping gone.
Old Jul 16, 2010 | 02:44 AM
Yes it is! Did you know exactly what part was making it thump? Front rotator mounts? just added grease to them to see if it would stop, it didn't.
Thanks,
Old Jul 16, 2010 | 04:38 AM
RUDEDOG's Avatar
I tried that too. The only way I could get it to stop was changing to a trans mounted piece. It gave it some heavy weight to mount to instead of a flexable floor pan.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
