My First Camaro
Old Jan 31, 2003 | 01:40 PM
CamaroCutie's Avatar
Question My First Camaro
Hello everyone. I have been a mustang owner all of my life and always had 5.0's. I recently purchased my first camaro because I was tired of my mustangs breaking down all of the time. I just couldn't afford the maintenance. I purchased a 97 v6 and so far I love it. Not used to owning an automatic but it's still pretty fun. I was just wondering if anyone could suggest some cheap mods that I can do to her whether it be to make her look nicer or for a performance boost. I am a Chevy virgin I guess you could say so any help would be greatly appreciated!! Thanx!
Old Jan 31, 2003 | 01:48 PM
darkoverlift's Avatar
It is the same for all cars, free up the exhaust and get some HP... A nice cat back and headers might net you 20HP.. Cold Air intake everyone will scream, synthetic fluids, ect..
Old Jan 31, 2003 | 02:18 PM
nothingeined's Avatar
Hey, welcome to board! like he said, go with an exhaust and CAI, whisper lid setup. that will definately wake the car up. you can probably get everything under 500 depending on the exhaust setup you want. also if you go to camarov6.com i think it is, they show a couple of free mods you can do in the meanwhile. they also show how to make your own CAI. pretty helpful. well good luck
Old Jan 31, 2003 | 04:25 PM
Thanx for the info I will definitely check out that website.
Old Jan 31, 2003 | 04:52 PM
ImportKILLER's Avatar
Thumbs up
Welcome, Cutie!
The other site has a good modification section that breaks it down real nice. But this site has the better board...
You might want to make sure your car isn't leaking any oil before you put in any synthetics. Synthetics will find the little holes and cause leaks you didn't know you had.
Intake and exhaust are the first mods to consider and will really wake your car up!
Again, welcome to the board!
Old Jan 31, 2003 | 09:52 PM
PullmeOverRed's Avatar
You can port your Tb and do a free ram air. if you have 308 gears go to 342s aleast i have 410s and love them. also go for a torque converter. they pick v6s up a bunch.
Old Jan 31, 2003 | 09:59 PM
MustangEater82's Avatar
welcome to the board... funny thing was I was looking at 5.0s the other day , kinda the reverse situation.
www.fbodyv6.com also has some good info as well.
I would do exhaust and some sort of CAI first on your car, maybe plugs and wires as well because it might have the stock set still on it.
jsut to warn you ahead of time a common misconception of former stang now 4th generation F-body owners is that Dual exhaust. 98% of Camaros and firebirds have a single I-pipe, that goes into one muffler and comes out as 2 tailpipes. Its kinda hard and costly to do a truel dual setup found on most stangs, some have done it but it is by far the minority.
good luck.
P.S.
as for what gears you have check your glove box, and look for the code GU4, or Gu6.
Gu4 = 3.08 gears
Gu6 = 3.42s
both were found on automatic f-bodies.
Old Jan 31, 2003 | 10:04 PM
Wow. This has turned into quite the learning experience for me. I had no idea how different it would be switching from a stang especially a cobra to a camaro. I want to thank everyone for your awesome advice and for welcoming me to the board and plese keep it coming!
Old Feb 1, 2003 | 12:17 PM
yeah its a huge huge huge difference....
those mustangs are made completely backwards... while GM made the Camaro perfect
Its very similar jsut a couple differences.
Old Feb 1, 2003 | 02:31 PM
Well the first day I owned the car, I brought it to work, put it up on the lift, and called my local chevy dealer and had the following parts delievered the same afternoon...spark plugs, wires, pcv valve, auto tranny filter kit, ATF, fuel filter, oil filter, 10w40, anyway my point being it has had a full tune up and then some and I used all of the best stuff you can get. Now my only other thing I didn't do is I want to swtich to Mobil 1 synthetic oil so that my motor will last longer b/c it already has 91k but I was told that I have to buy a conversion kit which includes mods to my motor is this true or can I just make the switch on my next oil change???
Old Feb 1, 2003 | 02:33 PM
I almost forgot the most important thing.....the K&N air filter, the one I pulled out was nasty as hell!!!
Old Feb 1, 2003 | 03:29 PM
MysticTeal 95 V6's Avatar
Yeah, I'd definately check out www.firebirdv6.com *same as camarov6.com * Most of the mod's and admins are from the VA Beach area. They have a kick *** car club for the V6 f-bodies.... that'd be a good chance for you to meet some other F-body people and swap some idea's I'm in southwest VA, too bad VB is bout a 4 1/2 hour drive for me other wise I'd make it out to some of their meetings
EDIT:: also I saw where you asked about a conversion kit to switch to synthetic?? I've never heard of that before. I run Mobil1 TriSynthetic in mine and have been doing so for over 2 1/2 years now. There was a noticeable difference for me after switching... everything seemed to run/rev smoother. The difference is very small but I suppose where I used to travel ~150 miles round trip a day to work and back you sort of get a feel for whats normal for your car
Old Feb 1, 2003 | 03:35 PM
Sephiroth's Avatar
Ok, i dont care about the flames............screw a flame suit.........if your female...........which i doubt.............going from a Cobra..........to a V6Camaro?
If you want the pull and thrill like you had with the Cobra, you need a SC...........or a NX kit. Im in awe at the moment............go ahead and flame sixers........but you should know even by your "bigger 5.7 brethren" going from a V8 and asking this is kinda tar tar
And i do own both a Z and GT so, my statement stands, if u truly are that ignorant about it..............go for FI..........Nitrous or a SC(supercharger) only way you'll get the power you 'should' be used to.
Old Feb 1, 2003 | 04:26 PM
bigsteve7's Avatar
Took the words out of my mouth... except for the doubting that youre female. I assume you are with a name like "camarocutie." Whyd you go from a Cobra to a V6 Camaro?
Old Feb 1, 2003 | 05:38 PM
With an IM name like gsxrncbrgirl I hope she's a chick
