Fuel system upgrade?
Old Jan 29, 2003 | 02:53 PM
BLOWN25TH's Avatar
I have a 12psi 355 TPI w/200cc pro1 heads, blower cam and free flowing exhaust. Currenlty i have ATI's fuel pump along with 24lb injectors. Can i get away with these injectors with a custom chip or do i need larger ones. ? I know dyntuning will tell me but i am trying to find out before i put it together and start burning chips and money. Suggestions would be helpful. Thanks
Old Jan 30, 2003 | 08:21 AM
IDOXLR8's Avatar
Are you still running an FMU? WHat is your injector duty cycle?? From your setup it seems like you should be running 42 lb injectors. I would eliminate the ATI inline pump and install an Walbro 340 intank.
Old Jan 30, 2003 | 08:43 AM
BLOWN25TH's Avatar
I dont really know the duty cycle of my injectors are. I dont know the formula. Yes i do have a FMU.
Old Jan 30, 2003 | 12:59 PM
Ben383's Avatar
As what was stated earlier by IDOXLR8 , I would say 42lb injectors would be right for you .
Ben
Old Jan 30, 2003 | 02:05 PM
IDOXLR8's Avatar
What do you use to scan your car?? Ideally you want to be around 80% duty cycle. If you are over that many people tend to raise the fuel pressure to lower the injector duty cycle.
Old Jan 30, 2003 | 02:13 PM
BLOWN25TH's Avatar
The dyno will be my scan tool. Would i still have to use the FMU if i went with 42lb injectors?
Old Jan 30, 2003 | 02:27 PM
94SLUG's Avatar
Do you have stock pump? I have a 255 with 42s i(no FMU) have only spun to 4k due to a new motor, but i think i will be ok. Tell you in a 1000miles
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
