Old 01-26-2003, 05:04 PM   #1
Omega
60-1 turbo specs
What is the exhaust and compressor a/r for this turbo?
Is the 62-1 much different? What are the specs on that turbo?
I am looking for 450-500 HP out of a 355.
__________________
  • 89 Formula 305 WS6
    No engine, no trans, no money.... yet.
  • 98 Talon TSi
    PTE SCM50 and a few other goodies.
Omega is offline   Reply With Quote
Old 01-26-2003, 10:34 PM   #2
BigDaddy
Member
try looking here www.turbonetics.com
BigDaddy is offline   Reply With Quote
Old 01-26-2003, 11:50 PM   #3
Omega
That was the first place I looked This is as useful as it gets:
Available with either the standard (4” inlet, 2.5” discharge) compressor housing or the 60-1 Hi-Fi ( 2 3/4” inlet, 2” discharge) compressor housing, the 60-1 will outflow any standard T04B with ease! (The 60-1 Hi-Fi will deliver approximately 90-95% of the flow capacity of the standard 60-1.)
Old 01-27-2003, 12:19 AM   #4
89ProchargedROC
Send a message via AIM to 89ProchargedROC
Re: 60-1 turbo specs
how good are your heads and how much boost do you plan to run?
you could probably get away with a T04b h-trim turbo which is a 58mm turbo....maxes out right around 550hp or so. Would spool like mad too
My suggestion is to use a 60-1. If you have room, go with the larger compressor housing version (4, 2.5). The hi-fi is just sticking the 60 wheel in a smaller housing for space reasons...it cuts down the airflow about 15%
The 62-1 uses the same compressor housing as the 60-1, just a larger wheel. After that i *believe* you get into the T series housings that are .70a/r on the compressor side are are a tad bigger than the 60a/r compressor housings
hope that clears some things up
89ProchargedROC is offline   Reply With Quote
Old 02-05-2003, 02:25 PM   #5
Omega
The heads I am planning on using are the Sportsman II's. I don't think I will ever go over 10#'s.
I was leaning more towards the 60-1 myself, but I would rather "under run" a turbo than over spool.
The 60-1 comes with the LT1 kit correct? Do many people upgrade from that turbo?
Old 02-05-2003, 07:24 PM   #6
Mikey 97Z M6
Here is a link showing comparisons for different turbo sizing etc.. Most of these are used on the Supra's but it's still good info when comparing compressors/turbine sizes.
http://moreboost.org/turbos.htm
Hope that helps,
Mike
__________________
-97 Z28 My LS1 Swap Thread - Darton MID-Sleeved 387 LS1, 236/236, Ported L92's, L76, NW90, Grott LT's
Mikey 97Z M6 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
