Finally Got Boost!!!!!!!!!
Old Nov 20, 2009 | 05:10 PM
a4z28's Avatar
I just picked a D-1SC and am looking to see what kind of numbers and 1/4 mile times should i see and what have you guys gotten from it also. Here is a basic rundown of my current setup.
Stock long block.
walboro 255 lph fuel pump
Pacesetter long tubes off road y pipe cut out and flowmaster catback
3.73 gears
ls1 aluminum driveshaft
42 lb svo injectors
tune
slp lower control arms
drag radials
Winter build 355 with stock crank scat i beams with 7/16 bolts je forged dish pistons arp on the mains as far as the heads gonna send them to loyd and have him work them over and get a nice cam from him for boost. Alo gonna invest in a 12 bolt or 9 inch. And gonna shoot for some 10 second ets.
I am gonna try my performa built auto with 3000 stall with the stock setup but i am gonna swap a t-56 and spec stage 3+ clutch and flywheel.
Thanks
Old Nov 20, 2009 | 08:44 PM
jay_rich's Avatar
Sweet! I suggest some H beams over the I beams and a forged crank.
Post some pics!
Jay
Old Nov 21, 2009 | 07:32 AM
blown94's Avatar
or at least have the crank cut .010 under and have them radius the edges of the journals, but for a D1SC you will max out the bottom end and the crank still might give out. The scat 7/16 I beams are a goo choice though, theyre lighter than H beams and they rate them to 700 HP.
Old Nov 21, 2009 | 02:28 PM
97s10ondubs's Avatar
save your money on the spec and get a twin disk
Old Nov 22, 2009 | 01:12 AM
MysticBowtie's Avatar
I have to agree with Jay. Your going to want to use that D-1, and since it's a DD you're going to probably use it a lot. I had a very similar rotating assembly to the 355 you were talking about, and I just pulled it for a fully forged short block. I wish I bought the good stuff first, I would have saved a bunch of cash, especially after paying for the machine shop twice... Just my $.02
Old Nov 22, 2009 | 09:45 AM
a4z28's Avatar
Will a F1A bolt on to a D-1SC backets and be a direct fit if i want to upgrade in the future? Thanks
magman
Apr 15, 2016 03:08 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
